Help me build my first custom loop - Overclock.net - An Overclocking Community
post #1 of 56 (permalink) Old 03-15-2020, 09:01 PM - Thread Starter
Crazy
CrazyDiamond's Avatar
Rep: 17 (Unique: 16)
Finally want to liquid cool my wallmounted Core P5 rig. I really need help, I'm losing my marbles looking at all the different options.
-I want CPU and GPU in the loop. An i7-6700k and an ASUS Strix RX 5700XT. I intend to overclock both.
-I have room for a quad rad but would prefer to go with a triple, for compatibility with future rig plans.
-Quiet operation is very important, as it is an open-air chassis and I use an open-back headset.
Budget is fairly flexible but I don't want to go crazy.
I am having trouble deciding on components and want to make sure it is designed properly for easy filling/draining etc. I'm unsure which brands to go with and some of their product lines are obscure.
Planning to use pump from Thermaltake for mounting compatibility with case.
So far I'm thinking (will update as it goes):
Pump: Pacific PR22-D5 w/ Silent Kit Reservoir/Pump Combo (https://www.thermaltake.com/pacific-...ump-combo.html)
Rad: Hardware Labs Black Ice SR2 MP (http://hardwarelabs.com/blackice/sr2/360-mp/)
CPU Block: Optimus FOUNDATION CPU BLOCK - INTEL (https://optimuspc.com/products/found...16106225074225)
GPU Block: EK-Quantum Vector Strix RX 5700 +XT D-RGB - Nickel + Plexi (https://www.ekwb.com/shop/ek-quantum...b-nickel-plexi)
Tubing: PrimoFlex Advanced LRT Flexible Tubing - 3/8in.ID x 5/8in.OD - Retail Bundle (10ft pack) - Crystal Clear (https://www.primochill.com/products/...nt=29219308176)
Fittings/Connectors: EK Torque Series
Coolant: Distilled Water w/ Mayhems Inhibitor+ & Biocide+ (https://www.mayhems.net/collections/algaecides)
Dye: Mayhems Non Stain Pink / Red Dye 15ml (https://www.mayhems.net/collections/...k-red-dye-15ml)
Fans: 3 x Corsair ML120 Pro LED, Red (Will switch for Noctua NF-F12 PWM if needed)
Missing anything? Recommendations?
CrazyDiamond is offline
post #2 of 56 (permalink) Old 03-15-2020, 09:49 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 612 (Unique: 504)
For soft tubing get the PrimoChill PRIMOFLEX Advanced LRT. Used those for 6 years. Disconnected and cleaned and I kept them for another potential loop. Never had a problem with fading or plasticizer issues.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
PC-JMK5-Cool 5 Open Frame Case
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
post #3 of 56 (permalink) Old 03-15-2020, 10:41 PM - Thread Starter
Crazy
Thanks! Added it to the list, seems like a great option. Will likely have to order it straight from them, seems much cheaper than what other retailers are selling it for.
Noticed they also sell some products for "pre-treating" a loop or for cleaning out a rad. From what I understand, I should be cleaning my rad out (any maybe other parts??) before putting it in the loop. Are these products good to use for that? Should I just use distilled water?
post #4 of 56 (permalink) Old 03-16-2020, 04:44 AM
Rep: 145 (Unique: 128)
To address some of your uncertainty, I have a HWLabs Black Ice GTX 360 and it's been great. I have zero complaints.
As for fittings, Bitspower is the creme de la creme. If you can't swing it that's totally fine, I used traditional barbs on my first loop for about 11 years and never had a single issue.
To clean your rad, just add some white vinegar to some distilled water and flush it through the rad a few times. All you're really trying to do is get any gunk that was introduced from manufacturing or sitting on a shelf out.
Xfire: grmnasasin0227
Steam: PWNY
I fold for a cause.
grmnasasin0227 is offline
post #5 of 56 (permalink) Old 03-16-2020, 07:18 AM
I Love this Hobby!
If I remember correctly, my tubes came with a cleaning kit that I never used.
Just use tap water (boil in a tea kettle) to clean all the water components including flushing the rads and then once everything is clean finish with distilled water (room temp).
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
Optical Drive
Noctua NH-D15
Operating System
Win 10 Pro 64bit
Keyboard
Mouse
Logitech G502 Hero
Mousepad
Audio
Other
Optical Drive
Operating System
Win 7 Pro 64bit
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Audio
Optical Drive
LG DVD R/W
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Mouse
Mousepad
Audio
post #6 of 56 (permalink) Old 03-16-2020, 07:54 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 427 (Unique: 284)
Quote: Originally Posted by CrazyDiamond View Post
Pump: Pacific PR22-D5 w/ Silent Kit Reservoir/Pump Combo (https://www.thermaltake.com/pacific-...ump-combo.html) Should I go with DDC instead??
Rad: Hardware Labs? 120x360 (No idea which, confusing product lines)
CPU Block: EK-Quantum Velocity - Nickel + Plexi (https://www.ekwb.com/shop/ek-velocity-nickel-plexi)
Fittings/Connectors: ?????? EK? Bitspower? Other?
Coolant: 2x EK-CryoFuel Blood Red (Premix 1000mL) (https://www.ekwb.com/shop/ek-cryofue...-premix-1000ml)
Fans: Chromax NF-F12 PWM? Corsair ML120 Pro RGB? Other?
A couple of things of note....
1. I feel like the Tt res/pump had leakage issues, but I don't recall definitively. Either way, unless you are getting some ridiculous price on it, I would steer clear of any Tt watercooling components as the quality is below par.
2. Just say no to Cryofuel, there are plenty of posts in this forum of gunked up systems due to it. If you must have red, use Mayhems. Even if you don't need red, use Mayhems coolant.
3. BitsPower fittings are top of the line, and I wouldn't use anything else for rotaries. If you want to save a few dollars, go with BP rotaries where needed and use Barrow compression fittings as they are good quality and closely match the look of the BP.
ciarlatano is offline
post #7 of 56 (permalink) Old 03-16-2020, 10:46 AM - Thread Starter
Crazy
Thanks! Will do!
I'm definitely wanting to go with compression fittings, seem like the best option. When I look at Bitspower's line they have a bunch of non-descriptive versions of their fittings. I have no idea what the regular vs CC2 vs CC3 means?
I've narrowed it down to 3 rads from HWLabs that seem like a good fit. The Nemesis GTR360, Nemesis GTX360, and the Black Ice SR2 360 MP. From what I understand, the Nemesis line is just the latest version of the older Black Ice?
Thanks for the info!
I've read that the first version of that pump/res had a leakage issue with the res cracking but that it was addressed shortly after release. From what I understand, by and large a D5 is a D5 regardless who it's from, it's mostly just a different res and mounting? I know my case, the Core P5, can't use other pumps without drilling because of the mounting setup. But the case is compatible with the Tt pumps.
I've heard the cryofuel can stain but I haven't heard it causing gunking. Either way, I'll be checking out Mayhems, thanks!
post #8 of 56 (permalink) Old 03-16-2020, 11:56 AM
ciarlatano's Avatar
The Nemesis line is a newer line, but not a direct replacement for the older Black Ice line. The rads you list have some very distinct differences, and are all aimed at a different type of user. The SR2 is aimed at the low noise user, and it is an absolute beast at low noise levels. The GTX has less than stellar performance at very low noise levels, but is great with medium~high fans speeds. The GTR is the best all out performer....but your PC needs to sound like a vacuum cleaner to get that performance. You can get a great overview of the SR2 and GTX performance (GTR was not released at the time of these tests) here - https://www.xtremerigs.net/2015/02/1...-round-2015/5/ . Some GTR vs GTX info is here - http://thermalbench.com/2016/11/22/h...80-radiator/5/
post #9 of 56 (permalink) Old 03-16-2020, 01:24 PM - Thread Starter
Crazy
Thanks, that's very helpful. I'm definitely crossing the GTR off the list. So I've got to decide between the GTX or SR2. I want the system to be very quiet but I also don't want to sacrifice OC headroom or have crappy temps.
post #10 of 56 (permalink) Old 03-16-2020, 01:28 PM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Hi,
I'd go heatkiller 4 pro instead of velocity.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is online now
