Vortex in my reservoir - Page 2 - Overclock.net - An Overclocking Community
post #11 of 13 (permalink) Old 03-21-2020, 05:36 PM - Thread Starter
Rep: 0
Thanks skupples. I plan to run at reduced speed. The dual pumps are for redundancy; it flows just fine on one pump. I've got the Aquaero 6LT to control fans and pump speeds. Four temp sensors to monitor the points between GPU, 1st radiator, CPU, and 2nd radiator. Plus the AquaComputer flow sensor. It's going to be my work machine, so reliability is important to me.
ICPete is offline
post #12 of 13 (permalink) Old 03-21-2020, 06:10 PM
I can count to potato
Fluxmaven's Avatar
Rep: 49 (Unique: 20)
Quote: Originally Posted by ICPete View Post
If noise level doesn't drive this, would there be reasons not to simply run full tilt? Like, IDK, velocity erosion in the blocks or fittings?
As already mentioned, there are diminishing returns at higher flow rates, but it wont hurt anything to run it flat out. D5's are cooled by the liquid so it will add more heat and use more electricity running them faster.
I had a fixed speed D5 Swiftech MCP655-B from 2010 that finally died last year. Reliability at any speed isn't really a big concern for D5 or DDC pumps.
Sounds like you made up your mind to run them slower, which I think is the best move. Even though the pumps are reliable running flat out, if you don't need the extra flow it just makes sense to save a bit of electricity.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
TridentZ B-die 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is offline
post #13 of 13 (permalink) Old 03-21-2020, 06:12 PM
u broke 666 rep :(
skupples's Avatar
Rep: 677 (Unique: 360)
sounds great
yeah, just run them both right above lowest speed (on the Aquaero it'll be somewhere in the 35-45%)
my MCP35x2 is pushing 10 years now. I'd like to say thank you to Mayhems, the Academy, and say screw you to the distilled water purists in the watercooling mainthread!
the only rule of thumb I've gotten with DDCs is they can over-heat if you run them too fast in a small/low restriction loop. i'd just add a mechanical high flow meter from aquacomputer when you get a minute, and make sure you aren't going over 2GPM. unnecessary wear, tear, & heat.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is offline
