Draining the loop - Overclock.net - An Overclocking Community
Draining the loop
post #1 of 12 (permalink) Old 03-16-2020, 05:29 PM - Thread Starter
reaper7534's Avatar
Rep: 0
Draining the loop
Going to redo my bends and also new GPU will not be watercooled. I have a drain valve bottom right and it is dreadfully slow at draining. Apparently I need a vent. Where would be the best place for a vent ?
reaper7534 is offline
post #2 of 12 (permalink) Old 03-16-2020, 05:52 PM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Hi,
Usually some where on the top.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 12 (permalink) Old 03-16-2020, 07:13 PM
Rep: 13 (Unique: 12)
Just open the fill port while draining.
Open Air Build
i9
ASUS ROG Strix Z390-H Gaming
MSI GEFORCE GTX1080 TI GAMING X 11G
Corsair Vengeance LPX DDR4 DRAM 3000MHz
Samsung 970 EVO
WD Blue
EVGA SuperNOVA
All PrimoChill parts (Rad 360, Pumps D5, Fittings, and Acrylic Tubing), Byskey CPU&GPU Blocks
Praxis Wet Bench
Operating System
Windows 10 Pro
Asus Predrator
Other
Thermaltake Commander F6 Fan Controller
Other
DIY Sleeved Cables
smilinjohn is offline
post #4 of 12 (permalink) Old 03-16-2020, 07:46 PM
sultanofswing's Avatar
Rep: 2 (Unique: 2)
I don't see the issue here, Just connect your line to your drain with the case standing normally and then open the cap or the fill port.
sultanofswing is offline
post #5 of 12 (permalink) Old 03-17-2020, 04:14 AM - Thread Starter
reaper7534's Avatar
Rep: 0
I open the res and drain but it is still very slow and doesn't get anything...... gravity is confusing. Just noticed since I uploaded this from my phone it needs to be rotated 90 degrees clockwise
post #6 of 12 (permalink) Old 03-17-2020, 04:32 AM
Bench, Dead, Squat
Bad5ector's Avatar
Rep: 20 (Unique: 15)
Try removing the fill port cap entirely, don't just unscrew it a bit.
ShadowMoses
(21 items)
i7 7700K
ASUS ROG Maximus IX Formula LGA1151
EVGA GeForce GTX 1080 Ti Founders Edition
Corsair Vengenace Lpx 32GB DDR4 3200MHZ
Seagate ST1000DX001 SSHD 1TB 3.5in SATA3 64MB Cache Internal Solid State Hybrid Drive
Kingston HyperX Predator 240GB
EVGA SuperNOVA 1000 G1 80 Plus Gold Certified 1000W Fully Modular
RAD - EK-CoolStream XE 360
CPU Block - EK-Supremacy EVO - Nickel
GPU Block - EK-FC Titan X Pascal - Nickel
Pump / Res - EK-XRES 140 Revo D5 PWM (incl. sleeved pump)
Fans - 3 x EK-Vardar F4-120ER (2200rpm)
Coolant - EK-Ekoolant Pastel BLUE (concentrate 250mL)
Tubing - EK-DuraClear 11,1/15,9mm
Thermaltake Core P3 SE Snow Edition
Operating System
Microsoft Windows 10 Pro 64Bit
BenQ XL2720Z 27in LED 144HZ 1ms GTG FPS Gaming Monitor
42" LG TV
Keyboard
Corsair Gaming K65 Lux RGB Compact Mechanical Keyboard
Mouse
Corsair Gaming M65 Pro RGB Optical Gaming Mouse
Mouse
Corsair Gaming MM300
Bad5ector is online now
post #7 of 12 (permalink) Old 03-17-2020, 04:53 AM
Tech Enthusiast
oreonutz's Avatar
Rep: 70 (Unique: 49)
You need to allow for air to take the place of the water. Its often best to open a port at the very top of the loop, then opening your drain valve and air will then be allowed to draw in to replace the water as the water exits. Your Fill Port will work for this, you need to open it all the way and crack your drain port completely. You are still going to have water stuck in places where the block or rad's outlet/inlet is above the water, in these cases you need to tip your case to move the water above a port on that component so that it will flow into your res or drain valve and flow out.
You can also connect a tube to the fill port and blow, however you should probably flush if you do this. Once you get as much water out as you can, start taking off tubes and blocks carefully, and emptying each component/tube one at a time until fully disassembled. Remember as long as you keep the water level below the outlet/inlet port, it will not flow out when disconnecting your tubing, use gravity to your advantage to keep your components dry as you disassemble. Good Luck!
-MattTheTech
Offical Ryzen 9 3900x Owner!
Offical Ryzen 9 3950x Owner!
DodekaZen3000
(34 items)
Ryzen 9 3950x
ASUS Crosshair VII Hero
EVGA 1080ti FTW3 Hybrid
G.SKILL Flare X Series 32GB (4 x 8GB) 3200Mhz (PC4 25600) - F4-3200C14D-16GFX (x2 Kits)
Samsung 970 Pro 512GB
Samsung 970 Evo 1TB
Samsung 850/860 Evo (x3 Raid 0 Game Drive)
WD Black 4TB (x2 Raid 0 Storage Drive)
860 Evo
Optical Drive
LG Blu-Ray Burner (Model BH16NS40)
Optical Drive
5.25" to One 3.5" and One 2.25" Bay (Model Syba SY-MRA55006)
Corsair RM1000i
EKWB Phoenix 360mm Modular Cooler
280mm Alphacool UT60
280mm EKWB Coolstream CE
Optimus Foundation AM4 CPU Block
x2 Corsair Pump/Res Combo
EKWB Acrylic 1080ti FTW Block
Aquaero 6xt
Old Jonesbo Case
Operating System
Windows 10 Enterprise
Samsung NU8000 55Inch TV (Its a 4k TV But I run in it 1440p 120hz)
LG 1080p 34 Inch Diplay
Keyboard
Corsair k70 RGB Lux Mk2
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Custom Built 7.1 Surround System
Audio
HT-Omega eClaro 7.1 Sound Card
Audio
Focusrite Scarlett 18i20
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
10 ML120 + 6 ML140 Corsair Maglev Fans
Other
Phanteks Halo aRGB LUX x5
oreonutz is offline
post #8 of 12 (permalink) Old 03-17-2020, 05:23 AM - Thread Starter
reaper7534's Avatar
Rep: 0
My fill port is basically the res. I ordered a a T to put in line at the top so it should be easy from now on. I guess my last water cooling system was dumb luck, it would drain in about 15 seconds, my res did sit a lot higher in that one though.
post #9 of 12 (permalink) Old 03-17-2020, 06:05 AM
ThrashZone's Avatar
Hi,
Clogged cpu block can cause bad draining
To say where exactly you'd have to post an image of your loop
But i can say a T valve would have to be piped to the highest point of the loop
Some I've seen go through the top of the case but not going to the reservoir like a fill port it doesn't work well.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #10 of 12 (permalink) Old 03-17-2020, 07:18 AM - Thread Starter
reaper7534's Avatar
Rep: 0
Quote: Originally Posted by ThrashZone View Post
Hi,
Picture is first post, need to rotate 90 degree. I plan to put the T on either radiator inlet or outlet. The CPU and GPU block were just recently cleaned so no build up on those, just piss poor loop design on my part.
