Single or Dual pumps? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 71 (permalink) Old 03-18-2020, 10:08 AM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Quote: Originally Posted by sakete View Post
But if I use rads as intake, then the heat from the rads will just be blown into the case, raising the case temp and water as well.
To me it makes more sense to take in ambient air, and exhaust rads heat out of the case.
Hi,
Majority of cases are open in the back so hot air is forced out
Room ambient air through a rad will be roughly the same as the water temp say between 25-35c
Most components heat way more than that
Just memory 40c oc'ed if you're lucky
CPU block crips 110c tj max oc'ed to death
GPU another heat producer on water 40c minimum oc'ed
Top intake directs air straight down
Front fans direct air straight back
With that why would you want to push hot case air through a rad ?
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #22 of 71 (permalink) Old 03-18-2020, 10:56 AM
sakete's Avatar
Rep: 10 (Unique: 9)
Quote: Originally Posted by ThrashZone View Post
Hi,
Alright, what I'll do then is set my top-mount 360 rad as intake. I have 3x140mm fans in the front, those will be intake as well. Bottom 120mm rad (for GPU using Kraken G10 universal mounting bracket) will be intake, as well as a separate standalone 120mm fan on bottom intake as well. There is one side-mounted fan that will be intake as well, and then one 140mm fan in the upper back as exhaust, as well as a separate 120mm slim fan in the lower back as exhaust (it's there for my hard drives to keep them extra cool). This should create a ton of positive pressure so any excess air should be pushed out the back and any other cracks.
Main
(17 items)
AMD Ryzen 9 3900X
Asus X570 ROG Crosshair VIII Formula
EVGA GTX 980Ti SC+
2x 16GB G.Skill Ripjaws DDR4-3600 C16
1TB Samsung 970 EVO+ NVMe
1TB Samsung 850 EVO SSD
480GB SanDisk Extreme Pro
3x 4TB HGST Deskstar NAS (2 in RAID 1)
Seasonic Prime PX-1000
Optimus Foundation AM4
HWLabs GTS 360 XFLOW
Phanteks Enthoo 719/Luxe 2
Acer XB270HU
Keyboard
Corsair K70
Mouse
Logitech G502
Audio
Motu M4
Audio
JBL LSR305
sakete is offline
post #23 of 71 (permalink) Old 03-18-2020, 08:15 PM
Moose-Tech's Avatar
Rep: 9 (Unique: 9)
Ehh, in general watercooling makes 0 sense. But we do it anyway
Quote: Originally Posted by sok0 View Post
2 - 480 and 2 - 360 radiators for a single cpu / gpu build. Makes 0 sense.
MOAR!
MOAR!
MOAR!
Build: Z390 ACE
Core i9-9900K OC 5 GHz, MSI Z390 ACE Mobo, AMD Radeon VII GPU OC 2K MHz
Corsair Vengeance RGB 32GB 3200 RAM, Phanteks Enthoo Pro M SE.
EKWB Z390 ACE Monoblock, Bykski Radeon VII GPU w/b, 2x EKWB 140 Revo D5 Pump & Res.
Aquacomputer Aquaero 6 LT USB Fan-Controller, Quadro, Vision Touch and 'High Flow' Sensor.
(2x) HWL Black Ice Nemesis 280 GTS XFLOW and (1x) Alphacool XT45 X-Flow 280 radiators.
Moose-Tech is offline
post #24 of 71 (permalink) Old 03-18-2020, 08:21 PM
u broke 666 rep :(
skupples's Avatar
Rep: 681 (Unique: 361)
Quote: Originally Posted by Shawnb99 View Post
Add a flow meter and temp sensor for the water as well.
For dual pumps you can either buy one that’s dual already, buy a new top for both or run them each separate. More run them in serial, one pump feeding the other as it creates more head, or you can run them in parallel and get double the flow
yay you didn't beat me to it.
MCP35x2, n save yourself some money.
then you forget where you are.
the parts are expensive, n people dream of scaling up.
people also dream of silent operation, while still overclocked = lots of radiators.
you always want your radiators pulling the coolest air possible, n said air is pretty much always outside the case.
even radiator wash is enough to keep most board components cool enough these days. If not? Zip tie a fan, or get a VRM block/southbridge blocks and go dual loop.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is offline
post #25 of 71 (permalink) Old 03-18-2020, 08:22 PM
Moose-Tech's Avatar
Rep: 9 (Unique: 9)
Both of my 280 rads are on intake. Plus I have an external 280 that also runs off ambient.
As long as you have airflow across your RAM and MOS you should be OK. I i have front and top on intake and rear on exhaust.
Build: Z390 ACE
post #26 of 71 (permalink) Old 03-18-2020, 08:24 PM
sultanofswing's Avatar
Rep: 2 (Unique: 2)
I have all rads as intakes, I don't even have an exhaust fan as it's not needed.
sultanofswing is offline
post #27 of 71 (permalink) Old 03-19-2020, 12:06 AM
Bartdude's Avatar
Rep: 4 (Unique: 3)
+1 top n side rads intake, front intake and rear exhaust. Here is a good review of intake vs exhaust for rads
"No s*** lady, does it sound like I'm ordering pizza!"
Corsair 900D
(29 items)
Intel E4790k Haswell
Asus ROG Maximus VII Watchdogs
EVGA 1080 SC Gaming
Corsair Dominator Platinum
Samsung SSD
Samsung SSD
Samsung SSD
Optical Drive
LG Blu Ray Rewriter
Corsiar AX1200i
EK XTOP Revo Duel D5
2X EK Radiator 360 PE
EK Supremacy EVO
EK 1080 Full Cover Waterblock
Aquero 6 XT
Aquero MPS 400 Flow Sensor
9X Gentle Typhoon Fans
Aquacomputer Hubby7
4x Aquacomputer Splitty9
Aquacomputer Poweradjust USB 3 Ultra Version
Corsiar 900D
Operating System
Win 10 Pro 64
Asus ROG Swift PG279Q 27" 2K WQHD 165Hz IPS G-Sync 2K Gaming Monitor
Keyboard
Razer Blackwidow Soft Touch
Keyboard
Razor Orbweaver
Mouse
Razer Deathadder 3500DPI
Mouse
Razer Mouse Mat
Audio
Sound Blaster X-Fi Titanium Fatal1ty Champion Series
Audio
Yamaha RX-V381 5.1 Channel Receiver Amplifier
Audio
Tannoy 5.1 Speakers
Bartdude is offline
post #28 of 71 (permalink) Old 03-19-2020, 03:15 AM
ThrashZone's Avatar
Hi,
That is exactly what happens
If it were the other way outside air would be sucked through the cracks where there is no filter
Top & front are filtered with a screen but better than nothing
If you want added dust prevention use some speaker cloth or something behind the cases screen filters.
Otherwise just blow out the rads once a month or so depending on how dusty it is where you're at.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #29 of 71 (permalink) Old 03-19-2020, 04:09 AM
TeslaHUN's Avatar
Rep: 21 (Unique: 19)
Quote: Originally Posted by Moose-Tech View Post
MOAR!
MOAR!
MOAR!
You want MOAR ?
Check my system
1 CPU +1 VGA > 7 x 420mm rad / 420*140 *45 Alphacool + 420*420 *45mm Mo-Ra (2x)
xd
TeslaHUN is offline
post #30 of 71 (permalink) Old 03-19-2020, 06:07 AM
Rep: 3 (Unique: 3)
I have a similar loop in a 719 case and so far a single D5 seems to be working fine as far as I can tell. I do like the idea of dual pumps so you have a backup just in case and also since you can run them at a lower speed.
I currently don't have a flow meter installed so I can't provide any specific numbers on flow or temp. Waiting for the 3080/3080ti to be released and then I will add the gpu into the loop. 3600x will probably also be upgraded once the next gen of ryzen cpus come out.
I have all my radiator fans installed as intake with a 140mm fan at the rear for exhaust.
Optimus Foundation Waterblock
HWL 420 GTS
HWL 360 GTS
EK- XRES d5 vario pwm
EK ZMT
Barrow fittings
MSI MEG x570 Unify
Ryzen 3600x
Viper Steel Series DDR4 16GB (2 x 8GB) 4400MHz
EVGA GeForce RTX 2070 Super Black Gaming
Fractal Design Ion+ Platinum 760W
Phanteks Phanteks Enthoo 719
LOKI23NY is offline
