Single or Dual pumps? - Page 5 - Overclock.net - An Overclocking Community
post #41 of 71 (permalink) Old 03-21-2020, 07:15 AM
New to Ryzen
chas1723's Avatar
Rep: 2 (Unique: 2)
Quote: Originally Posted by TeslaHUN View Post
You want MOAR ?
Check my system
1 CPU +1 VGA > 7 x 420mm rad / 420*140 *45 Alphacool + 420*420 *45mm Mo-Ra (2x)
xd
https://www.youtube.com/watch?v=XYg0...ature=youtu.be
That is awesome. I want to switch over to just a single MORA 420 so I can finally put my computer case under my desk rather than behind it. I plan on using 9 pwm eloops. I currently run a 360x45 and 420x45 rad with pwm Eloops. My case starves for cool air under the desk with the rads in it. Being able to remove the rads from the case will allow the move under the desk.
I run a 3800x and a 980ti currently but will upgrade to a 3000 series gpu this year or next.
Sent from my SM-N950U using Tapatalk
3800x
(18 items)
3800x
Asrock x570 Taichi
EVGA 980ti
G.Skill Trident Z Neo
Western Digital BLACK SERIES
Samsung 830 Series
Samsung 850 Pro Series
Silicon Power M.2-2280 NVME Solid State Drive
Optical Drive
LG UH12NS29 Blu-Ray Reader, DVD/CD Writer
SeaSonic PRIME Ultra Titanium 750 W 80+ Titanium Certified Fully Modular ATX Power Supply
EK EVO Copper CPU block
EK Titan X Copper GPU block
Alphacool NexXxos XT45 360 Radiator
Alphacool NexXxos XT45 420 X-Flow Radiator
Aquacomputer Aqualis 150mm
Phanteks Enthoo Series Primo Aluminum ATX Full Tower Case
Operating System
Windows 10 Home
BenQ SW271 27.0" 3840x2160
chas1723 is offline
post #42 of 71 (permalink) Old 03-24-2020, 08:02 PM
owcraftsman's Avatar
Rep: 86 (Unique: 76)
Quote: Originally Posted by RoivonPC View Post
A 3950x already runs hot and we don't know how hot the next Nvidia card will be. Plus I've repeatedly read more rad area means more cooling potential means fans running lower RPM.
This is the point most are missing... Silence
I have dual D5 pumps for a Phoyba 1080 that has 9 pwm fans which cools overclocked 3900x 4450 all cores and a 2080 Ti XC Ultra +150cc +1000mc. Due to the 1080 being external it is very efficient.
Even while gaming I can barely hear it so your point makes perfect sense to me.
My last loop had a single d5 with 360 monsta and 480 in a Phanteks Enthoo Primo and had 12 fans in push/pull which was good but a bit noisy after three hours of gaming. Point being your config is key to keep that noise down.
Crosshair VIII Hero WiFi @4450 /1201 bios | 3900x /EK-Quantum Momentum | G.Skill Trident Z Neo 32GB (4x8) 3600 C16 | EVGA 2080Ti Ultra w/HydroCopper +100cc +1000mc | Corsair MP600 M.2 Gen 4 1TB (OS) 970 EVO 1TB M.2 (Games) | Custom Painted Entho Luxe with Under desktop cart with: Phoyba Xtreme Nova 1080 & Bitspower D5TopX2 (dual D5 Vario Pumps) & 1/2 ID 3/4 OD clear flexible tubing & XSPC LCD Temp Sensors & Koolance Quick Disconnects & Mayhem Clear UV Blue coolant & EK and Monsoon Fittings & DarkSide UV Lighting | Win 10 Pro x64 oem 1909 RiG PICS Benchtop to Cart
Ryzen 3900x Build
(34 items)
Luxe Kaby Lake
(33 items)
R9 3900x
Asus Crosshair VIII Hero (WIFI)
EVGA 2080Ti Ultra
G.Skill Trident Z Neo F4-3600C16Q-32GTZNC
Corsair MP600 M.2 Gen4
Samsung 970 EVO M.2
Optical Drive
Ausu BC-12B1ST
EVGA Supernova 1000G2
EK-Quantum Momentum ROG Crosshair VIII Hero D-RGB - Plexi
Xtreme NOVA 1080 Radiator - Full Copper
EVGA Hydro Copper
Bitspower D5TopX2
Custom size magnetic DEMCifilter fan filter
Corsair Air Series™ SP120 High-Performance Edition High Static Pressure 120mm Fan
Bitspower 150mm clear Reservoir
Barrow Special Aluminum Heatsink D5 Top Kit- Sapphire Blue
Koolance QD3 Quick Disconnect No-Spill Coupling Male Threaded G 1/4 BSPP
Koolance QD3 Female Quick Disconnect No-Spill Coupling, Male Threaded G 1/4 BSPP
PrimoFlex Advanced LRT Tubing - 1/2in. ID X 3/4in. OD - Crystal Clear
1-Monsoon Free Center Compression Fittings, 1/2" x 3/4"
Phanteks Enthoo Luxe
EZDIY-FAB Vertical Graphics Card Holder Bracket
Sargent Art 29-3166 16oz Neon Acrylic Paint
Operating System
Win 10 Pro oem
Asus ROG Swift PG278Q
Asus PB278
Keyboard
Corsair K70 RGB Cherry Blue
Mouse
Corsair M65 Pro RGB
Mousepad
Corsair MM800 RGB Polaris
Audio
Logitech Z 906 5.1
Audio
HyperX Cloud II Gaming
Audio
Creative SB Zx
Audio
Corsair ST100 RBG
Other
Custom Cart
i7 7700k
MSI Z270 Gaming M7
Asus GTX 1080Ti FE
G.SKILL 32GB (4 x 8GB) Ripjaws V Series DDR4 PC4-25600 3200MHz Desktop Memory Model F4-3200C14Q-32GVR
Samsung 950 Pro M.2
WDC WD1003FZEX-00MK2A0
Seagate Backup+ Desk SCSI Disk Device
Optical Drive
asus bc-12b1st
CORSAIR HX Series HX850W
corsair sp120 high performance led
kryographics Pascal for NVIDIA TITAN X and GTX 1080 Ti acrylic glass edition, nickel plated version
Monsoon center compression fittings
Alphacool NexXxoS XT45 Full Copper 280mm radiator
Alphacool NexXxoS UT60 Full Copper 240mm radiator
Phanteks PH-F140SP Case Fan
Aquacomputer backplate for kryographics Pascal NVIDIA TITAN X und GTX 1080 Ti, active XCS
XSPC Raystorm Pro
PrimoFlex Advanced LRT 1/2 ID x 3/4 OD UV Blue Soft Tubing
Mayhem X1 UV UV Blue
Monsoon Series Two D5 Premium Dual Bay Reservoir, Blue
Phanteks Enthoo Luxe PH-ES614L
Operating System
Windows 10 Pro x64
Asus MG279 (Primary) (GSync & FreeSync)
Asus PB278Q (Extended)
Vizio E55-E1
Keyboard
Razer BlackWidow Elite Mechanical Gaming Keyboard: Green Mechanical Switches
Mouse
Razer Mamba Elite
Mouse
Audio
Creative Sound Blaster Zx 116dB PCIe Gaming Sound Card with 600 ohm Headphone Amp and Desktop Audio Control Module
Audio
Logitech Z906 5.1 Surround Sound Speaker System - THX, Dolby Digital and DTS Digital Certified
Audio
HyperX Cloud Flight Headset
Other
Darkside dimable LED strips
Other
Modsmart Kobra Cables
owcraftsman is offline
post #43 of 71 (permalink) Old 03-24-2020, 08:03 PM
u broke 666 rep :(
skupples's Avatar
Rep: 677 (Unique: 360)
more pumps, more rads, more fans, = more cooling with less noise.
unless you're like me, & still run everything at full blast.
room's too quiet without wirrrrr. I just cut to an idle profile @ night. cuz MCP35x2 is anything but quiet.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is offline
post #44 of 71 (permalink) Old 03-24-2020, 08:16 PM
NewUser16's Avatar
Rep: 53 (Unique: 36)
I know this, you don't like to quiet do you
Would my assumption be wrong, you in your 50's, maybe I'm whey off
NewUser16 is offline
post #45 of 71 (permalink) Old 03-24-2020, 10:15 PM
George Jensen's Avatar
Rep: 0
I have 2 Hardware Labs 560 rads and 2 360 My Gigabyte water force 2080 doesn't flow well. I put my 3900x with EK Monoblock on one loop and 2080 on a separate identical loop, both with Aquacomputer nD5 Next pumps. I find that there is such a difference in the flow rate by separating them I can better control each one. I have a Rainintek Eris Evo case. Yes, some of the Hardware Labs rads are dual-pass so it takes a little more juice in the pump.
George Jensen is offline
post #46 of 71 (permalink) Old 03-24-2020, 11:10 PM
Rep: 0
I have 2950 with 2080 ti one rad 360 with one D5 temp never go more then 4 Deg C above ambient even under heavy loads, video editing or games you can check my build hire
"https://www.youtube.com/watch?v=PpEQI1LSfhE&t=23s" for some reasons mod remove link to my build as he thinks is some type of advertising I DO NOT sale anything or offer anything it is only
to show people compability of components and proper assembly
MadMax_S is offline
post #47 of 71 (permalink) Old 03-24-2020, 11:36 PM
sultanofswing's Avatar
Rep: 1 (Unique: 1)
That must be one hell of a 360 radiator, I run a 480 and 3 360's in a Enthoo Elite and my water temp goes to around 7-8c over ambient under full GPU load (350ish watts). Maybe open air helps that much.
sultanofswing is online now
post #48 of 71 (permalink) Old 03-24-2020, 11:55 PM
Rep: 0
we use push-pull system total of 6 fans this make a lot of difference also back of the case is open
MadMax_S is offline
post #49 of 71 (permalink) Old 03-25-2020, 04:58 AM
New to Ryzen
chas1723's Avatar
Rep: 2 (Unique: 2)
No way a 360 would keep water 4 degrees over ambient with that setup. It would not be able to do it with only one of the components.
3800x
(18 items)
3800x
Asrock x570 Taichi
EVGA 980ti
Samsung 830 Series
Optical Drive
Operating System
Windows 10 Home
chas1723 is offline
post #50 of 71 (permalink) Old 03-26-2020, 04:09 PM
CrazyJoe's Avatar
Rep: 97 (Unique: 61)
Looks like the planning / ideas are coming along nicely !
I'm running a Thermaltake Tower 900 ( so lots of room ) and have a BlackIce 560 and a BlackIce 280. Each has dual D5's attached to a BitsPower Dual D5 acrylic Top for redundancy. Everything runs very cool and very quiet, but more is always better !
If you can afford more … by all means go for It !
Old enough to know better ... still young enough not to let that stop me !
CrazyJoe is offline
