Single or Dual pumps? - Overclock.net - An Overclocking Community
post #1 of 71 (permalink) Old 03-18-2020, 06:36 AM - Thread Starter
Rep: 1 (Unique: 1)
Ok so here's what I'm getting ready to build.
AMD 3950x
Nvidia 1080ti (for now) until the next Nvidia card drops.
Optimus Foundation AMD Block
Phanteks 1080 TI Water block (if I can find one)
2 x 480 HWL TS
1 x 360 HWL GTS
1 x 360 HWL L series
Singularity Res (200mm)
Aquacomputer D5 pump.
13mm Alpha Cool brass pipes/fittings.
Aquacomputer 6 to run everything.
My question is, if I can cram all 4 of these rads into a Phateks 719 case, should I consider a second pump to ease the load? This will be a serial pipe run. I've been reading that HWL rads are a bit more restrictive as is the Optimus Foundation block.
Point 2, IF a second pump is a good idea, what's the best piping config for this? Out pump 1, into pump 2 which obviously goes out pump 2? Should I get a 2nd reservoir or can I get by with one since space will become a factor?
**EDIT**
After consideration I think I'll stick with a 3 rad setup for now. 1 480, 2 360. Top, front, bottom. The tolerance for all 4 rad spots seem excessively difficult to work with.
RoivonPC is offline
post #2 of 71 (permalink) Old 03-18-2020, 06:49 AM
Shawnb99's Avatar
Rep: 50 (Unique: 32)
Add a flow meter and temp sensor for the water as well.
For dual pumps you can either buy one that’s dual already, buy a new top for both or run them each separate. More run them in serial, one pump feeding the other as it creates more head, or you can run them in parallel and get double the flow
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #3 of 71 (permalink) Old 03-18-2020, 06:52 AM
StAndrew's Avatar
Rep: 20 (Unique: 12)
Dual pump if you have the money. If not, single pump will work.
Dual pump is mostly good for redundancy; not a ton of performance to be gained but there is some if your budget allows.
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is offline
post #4 of 71 (permalink) Old 03-18-2020, 06:54 AM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Hi,
Yep lots of rads
Either make two loops 1-D5 on each or get a ek dual D5 base think there are others that make dual D5 bases too can't remember who though.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #5 of 71 (permalink) Old 03-18-2020, 06:57 AM - Thread Starter
Rep: 1 (Unique: 1)
I already have a flow sensor but I can't believe I forgot the temp sensor. I must have thought the flow sensor from Aquacomputer would do it. Oh well, back to PPCS/Amazon. Side note, where should I put the sensor that makes the most sense in the loops?
RoivonPC is offline
post #6 of 71 (permalink) Old 03-18-2020, 07:01 AM
dwolvin's Avatar
Rep: 7 (Unique: 7)
Doesn't matter where the temperature sensor is- make it convenient to you. The water in the loop will stabilize at whatever temperature as it runs around the loop- there will never be any significant delta in the water temperature as it flows, as long as you have enough flow to run the loop (and unless you have a ton of blocks any decent pump is enough).
dwolvin is offline
post #7 of 71 (permalink) Old 03-18-2020, 07:14 AM
sok0's Avatar
Rep: 5 (Unique: 5)
2 - 480 and 2 - 360 radiators for a single cpu / gpu build. Makes 0 sense.
sok0 is offline
post #8 of 71 (permalink) Old 03-18-2020, 07:16 AM
sakete's Avatar
Rep: 10 (Unique: 9)
Ehh, in general watercooling makes 0 sense. But we do it anyway
Main
(17 items)
AMD Ryzen 9 3900X
Asus X570 ROG Crosshair VIII Formula
EVGA GTX 980Ti SC+
2x 16GB G.Skill Ripjaws DDR4-3600 C16
1TB Samsung 970 EVO+ NVMe
1TB Samsung 850 EVO SSD
480GB SanDisk Extreme Pro
3x 4TB HGST Deskstar NAS (2 in RAID 1)
Seasonic Prime PX-1000
Optimus Foundation AM4
HWLabs GTS 360 XFLOW
Phanteks Enthoo 719/Luxe 2
Acer XB270HU
Keyboard
Corsair K70
Mouse
Logitech G502
Audio
Motu M4
Audio
JBL LSR305
sakete is offline
post #9 of 71 (permalink) Old 03-18-2020, 07:17 AM - Thread Starter
Rep: 1 (Unique: 1)
A 3950x already runs hot and we don't know how hot the next Nvidia card will be. Plus I've repeatedly read more rad area means more cooling potential means fans running lower RPM.
RoivonPC is offline
post #10 of 71 (permalink) Old 03-18-2020, 07:17 AM
ThrashZone's Avatar
Hi,
Which amd chip 3950x ?
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
DeltaX
