Flow rate and temps problems - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 03-24-2020, 07:33 AM - Thread Starter
LeoYunta's Avatar
Rep: 11 (Unique: 11)
Hi guys,
A couple of months ago I finished this build :
LeoYunta is offline
post #2 of 13 (permalink) Old 03-24-2020, 08:59 AM - Thread Starter
LeoYunta's Avatar
Definitely a problem of flow, the first tube starting at the pump, I can really feel the flow, when I press the tube with my finger, the second tube, the outlet one on the CPU I can feel nothing, no flow, how is that possible ? I'm not inverted I triple checked on the waterblock, problem with the waterblock ? Actually, the only one tube where I can feel the flow is the first one (the output of the pump) I should feel it all over the tubes right ?
LeoYunta is offline
post #3 of 13 (permalink) Old 03-24-2020, 10:24 AM
toolmaker03's Avatar
Rep: 95 (Unique: 72)
take the CPU water block apart it may be clogged up with stuff. I don't know what stuff, but it sounds like it is clogged up.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #4 of 13 (permalink) Old 03-24-2020, 11:09 AM - Thread Starter
LeoYunta's Avatar
Yeah, that is what I'm doing right now, but it's black so I cannot see if it's clogged, so I blew up with my mouth to see if the air was passing, and its sound normal, I mean the air is passing, not a huge amount, but I tried with an old waterblock which is working good and it's seems to have the same behavior when I blew some air, I'll try to rebuilt the computer now after draining everything
LeoYunta is offline
post #5 of 13 (permalink) Old 03-24-2020, 11:42 AM
u broke 666 rep :(
skupples's Avatar
Rep: 681 (Unique: 361)
first thing I'd do is remove whatever that fitting is directly off of your pump, replace it with one of those snake 90s you have on your top radiator.
90s directly off of pumps can drastically inhibit total flow potential. specially a hard 90 like that. I've found a couple inches, and or a snake 90 helps this quite a bit.
example - removing the 90 directly from my MCP35x2 added ~50lph.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is offline
post #6 of 13 (permalink) Old 03-24-2020, 12:37 PM - Thread Starter
LeoYunta's Avatar
You talking about the fitting on the right ? the Inlet ? It's weird, cause before all that, everything was working good, well I just take opened my waterblock, and yeah there was some dirt in it, which is really weird, since it's kind of new, and I used anti-corrosion and biocide, so... I'll clean up, do you think I need to do the same with the graphic card ? Just to make sure ?
LeoYunta is offline
post #7 of 13 (permalink) Old 03-24-2020, 12:41 PM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Hi,
Yeah too many 90 degree fittings.
Inlet/ outlet/ cpu block/ rad/ no telling what's on the front rad ? more 90's I'd guess.
Add a T valve off the bottom front rad not off the pump.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #8 of 13 (permalink) Old 03-24-2020, 12:48 PM
u broke 666 rep :(
skupples's Avatar
you have 90s off your pump on inlet and outlet bro lol.
well, technically ones a T right? still, a hard 90.
bet spacing that out with snakes instead of those hard 90s will increase flow. It's the first tubing change i'd make.
skupples is offline
post #9 of 13 (permalink) Old 03-24-2020, 12:55 PM
ThrashZone's Avatar
Hi,
Take the T block off the outlet of the pump
Put the shut off valve where it was connect to the pump. although shut off should be at the lowest possible point otherwise system won't drain completely
Now put one end on the T valve into the pumps outlet add the 45 angle to the other end so you have a straight line outlet 45 degree up to your cpu block
Personally I'd take all the 90s off put straight barbs or 45s
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #10 of 13 (permalink) Old 03-24-2020, 02:02 PM - Thread Starter
LeoYunta's Avatar
Hum no, it's a 90 on the right, but on the left (outlet) it's a 45.
About the T on the pump, like I said, it was working perfectly fine before all this, actually it was the exact same configuration and I had really low temperature, since I added the flowmeter it all went crazy and weird. But yeah, I can try this but I don't understand why it was running like a charm with all the 90 and the T on the pump.
LeoYunta is offline
