I7 7700k running hot on custom loop - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 03-26-2020, 01:16 AM - Thread Starter
Rep: 0
I have a custom watercooling with an Alphacool waterblock, i have the bitspower distribution block for lian li pc o11 dynamic case which i have to and the Thermaltake CL-W010-AL00BL-A R360. Now that you know that, I have an i7 7700k sitting on an asus z270-e motherboard with some arctic MX-2 thermal paste. I use distilled water as coolant. I have the ventilators in a pull configuration with air coming from the outside not the inside of the case. I haven’t done a stress test but i can already tell it doesn’t cool very good because at idle it runs at 30/35 degrees C and at 30% load ut already runs at 65 degrees C. I have the system running in quiet mode but as it runs pretty hot it never really is quiet because the ventilator rpm jumps sometimes while the temps randomly spike at 66 while the cpu goes from idle to 30% for no reason. If you have any idea why it runs so hot please because when i play and have the ventilators do their own thing i some time got 100/110 degrees C at which point i really flipped out 😂.
simon w is offline
post #2 of 4 (permalink) Old 03-26-2020, 01:37 AM
Meep
Gilles3000's Avatar
Rep: 327 (Unique: 234)
Sounds like either a poor contact or flow issue.
Alright, lets do some troubleshooting:
  1. Did you remove the plastic protective foil from your block? sounds stupid but people forget it sometimes.
  2. Did you check the thermal paste spread on your block, it might not be sufficient
  3. Is your pump running and is the coolant flowing properly?
  4. Did you check your coolant temperature, if so what is it?
And some extra advice:
Ask help with building your loop next time, there's no shame in it.
The Thermaltake R360 is an AWFUL radiator its aluminium so without corrosion inhibitors it will destroy your blocks and fittings! Do not run straight distilled water with this thing, you need a corrosion inhibitor! If possible i'd get rid of it and replace it with a proper copper radiator like the HWL GTX for example.
Gilles3000 is offline
post #3 of 4 (permalink) Old 03-26-2020, 02:43 AM
Graphics Junkie
UltraMega's Avatar
Rep: 49 (Unique: 44)
7700k is one of the chips that usually benefits greatly from a delid. Delidding mine dropped the temps about 25c.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is offline
post #4 of 4 (permalink) Old 03-26-2020, 03:30 AM
Bench, Dead, Squat
Bad5ector's Avatar
Rep: 20 (Unique: 15)
I agree with UltraMega here. My 7700k had similar temps under water, and there was nothing wrong with my loop. Many different configs later I finally got a delid kit and some liquid metal and bam, instantly afterwards instant 10 to 15 degree drop in all temps. Couldn't run adia64 stress test before without cpu reaching hi 80s under water. Now barely goes above 60c.
Just a thought.
ShadowMoses
(21 items)
i7 7700K
ASUS ROG Maximus IX Formula LGA1151
EVGA GeForce GTX 1080 Ti Founders Edition
Corsair Vengenace Lpx 32GB DDR4 3200MHZ
Seagate ST1000DX001 SSHD 1TB 3.5in SATA3 64MB Cache Internal Solid State Hybrid Drive
Kingston HyperX Predator 240GB
EVGA SuperNOVA 1000 G1 80 Plus Gold Certified 1000W Fully Modular
RAD - EK-CoolStream XE 360
CPU Block - EK-Supremacy EVO - Nickel
GPU Block - EK-FC Titan X Pascal - Nickel
Pump / Res - EK-XRES 140 Revo D5 PWM (incl. sleeved pump)
Fans - 3 x EK-Vardar F4-120ER (2200rpm)
Coolant - EK-Ekoolant Pastel BLUE (concentrate 250mL)
Tubing - EK-DuraClear 11,1/15,9mm
Thermaltake Core P3 SE Snow Edition
Operating System
Microsoft Windows 10 Pro 64Bit
BenQ XL2720Z 27in LED 144HZ 1ms GTG FPS Gaming Monitor
42" LG TV
Keyboard
Corsair Gaming K65 Lux RGB Compact Mechanical Keyboard
Mouse
Corsair Gaming M65 Pro RGB Optical Gaming Mouse
Mouse
Corsair Gaming MM300
Bad5ector is offline
