Emergency diy cooler, please help with suggestions - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 03-30-2020, 01:36 PM - Thread Starter
robinlawrie's Avatar
Rep: 0
Hi all, im in italy, as you all know things are pretty s***t here at the moment. Luckily i have work, however, in the middle of a large animation job (my only work on the horizon). My external watercooler (2x mora3 in parallel) has decided to crap out. First i noticed a leak from inside one rad. (corrosion from using a silver kill coil for 5+ years, according to manufacturer)
Ok, i thought, thats why i doubled every component, redundancy! So i clamped the tubes to the leaking rad. Then the other started drippping. F***k.
The manufacturer kindly offered a discount on replacements, which i ordered (the only rads that will fit the box i built) these are coming from germany, due to arrive thursday. Dropping my dual d5 pumps to mimimum reduced the leak to a few mm in the res every day.
However now, the shipping of the replacements seems stuck at starting point (hardly a surprise at the moment) and today the leak accelerated to losing a cm an hour from the res. I have to basically render 24/7 for the next 2 weeks, and my new 3990x cpu would not appreciate being starved of water in the middle of the night. I *cannot* afford to risk damage to that chip.
So i either shut doen my machine and lose my job, set an alarm for every few hours during night to top up water (and destroy the mdf case of the cooler with damp in the process). Or..
I come up with a temporary solution to replace the rads, that i can achieve from the local hardware store, which is thankfully, open. Ive not been so ive no idea what they have in stock.
Im currently thinking a (very) long hosepipe spread out on the floor might do it? A long piece of copper pipe would be best, but, if they have it, very expensive for a temp solution. Dunno if a pvc pipe would work if long enough. Given the cpu puts out 280w, and i also have dual titan x gpus in the loop ( i can avoid gpu rendering for now) it needs to have a fair capacity.
I also have an ancient (18 years old) black ice triple rad from my first watercooling build. However it was never very good, and definitely wouldnt handle the load i have now, probably even at idle. . Dont even know if its still healthy.. When i dug it out it amazingly still had some water sitting in it.
So, creative solutions with easy to get local parts so i can keep working till my new rads arrive? Appreciate any help i can get.
Many thanks and keep safe all.
robinlawrie is offline
post #2 of 13 (permalink) Old 03-30-2020, 01:51 PM
Invalid Media
J7SC's Avatar
Rep: 73 (Unique: 31)
...now that's a novel problem you're having, even when framed within the times we live in...
Watercool / MoRa warranty stuff is usually great and replacements are the light at the end of the tunnel, subject to delivery in this weird age. But for immediate use needed now, you need as much surface cooling area as possible (copper coil from hardware store ??), and also as many fans as you can throw at it.
Also use as many older rads (ie BlackIce) as you have available...but if using OLD rads and such, first flush them out in the bath tub several times using regular water, then follow up with 2x distilled water flushes if available. Also, two D 5s should be up to the job of any reasonable custom-rigging until new rads arrive...
Best of luck, and stay safe...
J7SC is offline
post #3 of 13 (permalink) Old 03-30-2020, 02:32 PM - Thread Starter
Rep: 0
I was also considering the idea of using a bathtub full of water with a (shorter) copper coil in it. I cant imagine even a 3990x would heat a bath up much.
However its a long (15+m across the kitchen) and really annoying route to the bath from machine, and a 7 year old running round all day with cabin fever (and needing baths) makes this idea less than ideal.
Do you think a 30m+ hosepipe would just be a waste of time? It would be a ton cheaper than copper and i could use one for the garden this summer anyway. I cant imagine it would shed much heat..
post #4 of 13 (permalink) Old 03-30-2020, 03:18 PM
Invalid Media
J7SC's Avatar
...bathtub for bigger temp storage should be ok for quite a while (subject to 7 yr old running around...). But if bathtub heats up more than 2c above ambient with copper cooling coils etc, replace bathtub cooling water right away with fresh, cold water in bathtub
...just to let you know, I'm flying absolutely blind with this, even with quad D5 weirdo custom wc setups in my builds, and living on Canada's Pacific Coast
J7SC is offline
post #5 of 13 (permalink) Old 03-30-2020, 03:22 PM
Food Editor
skupples's Avatar
Rep: 719 (Unique: 378)
that could work... n yep, you could just slowly refill the tub with "cold" water, endlessly really... until the water police come to haul you away.
how much down time can you afford? JBWeld (2 part metal epoxy)usually works to hold back the low pressure leaks our hobby can form over the years, if you can find em all, and give it 16-24 hours to cure.
tough luck on the kill coil. Should've NOT told them about that. Seems most companies are now using admittance of kill coils as a reason to deny warranty
(IDR the specifics now, but there was something about how silver can actually increase and promote galvanic corrosion after a period of time.)
the water left in your black ice isn't water. it's acid, and has probably caused multiple microscopic holes to form in the fins section over the years. It would most likely work like a sprinkler.
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #6 of 13 (permalink) Old 03-30-2020, 04:16 PM
Missing the Old days
Cerberus's Avatar
Rep: 258 (Unique: 218)
just get a 5 gallon jug of water (or the equivalent) and swap water every few hours, i'd say one with ice and water will last overnight.
"But I, being poor, have only my dreams. I have spread my dreams beneath your feet. Tread softly because you tread on my dreams."
Work Folder
(7 items)
AMD r7 2700x
MSI X470 Gaming PRO
EVGA GTX 1080Ti
PNY Anarchy-X 2x8GB 3200Mhz
256GB Plextor M8Pe m.2
Corsair RM750X
big metal box
Operating System
Microsoft Windows 10 x64
DELL S2716DG
Keyboard
Logitech G910
Mouse
Logitech G604
Mouse
Steelseries Mat
Audio
Logitech G602
Other
steam controller
AMD FX8350
BIOStar TA970
AMD FURY X
Zotac GTX 960
Gskill 2x8GB DDR3
Western Digital Blue 2TB
Corsair 650w
Cerberus is offline
post #7 of 13 (permalink) Old 03-30-2020, 04:28 PM
Food Editor
skupples's Avatar
get a bunch of hose and just drop the radiators into the tub.
combining some of these theories... building a copper coil is gonna be expensive and time consuming. Instead, just get a good length of tubing, and drop the rads & res in the tub.
skupples is offline
post #8 of 13 (permalink) Old 03-30-2020, 04:51 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1390 (Unique: 720)
sink tap -> hose
hose -> water pump
water pump -> blocks
blocks -> back into sink
water temp shouldn't go much above whatever temperature your tap water is naturally at, no need to gunk up your radiator with the stuff that's in tap water so you can remove it out the loop.
not a great idea considering it's tap water but if your job depends on it then ¯\_(ツ)_/¯
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Gigabyte GA-H55N ITX
EVGA GTX 950 2GB
G.Skill DDR3-2133 8GB
Dierya 120GB SSD
Seagate Momentus 2.5" 500GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
CoolerMaster MasterKeys Pro S (Browns)
Mouse
Logitech M512
The Pook is offline
post #9 of 13 (permalink) Old 03-30-2020, 07:58 PM
sok0's Avatar
Rep: 5 (Unique: 5)
A triple radiator can easily handle just that CPU with minimal overclock. Rerun the CPU to the triple with a single d5 pump, disable the GPUs and run onboard video until you fix it.
sok0 is online now
post #10 of 13 (permalink) Old 03-30-2020, 10:01 PM
ltpdttcdft's Avatar
Rep: 37 (Unique: 31)
Set the rads on top of a large heavy duty plastic container. (tote, bin whatever you call it).
Remove any fans or anything electrical from the rad. Passive cooling only for safety.
Fill the bottom with water.
Set the hose to suck from the bottom of the container into your pump.
The container is now your reservoir. Anything dripping from your rad goes into the bin and is sucked back into the loop.
ltpdttcdft is offline
