Nickle Plating Removal - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 04-01-2020, 10:06 AM - Thread Starter
Sekkusu's Avatar
Rep: 0
Hello all. I just bought an Ek GPU Waterblock and I want to remove the nickel plating. The reason is I had to buy this block because EK are the only ones that make a block for it. I know I could have gotten a universal one but I wanted full coverage for the VRMs. It's an EVGA 1080ti FTW3 based card.
I'd like to be able to run minimal coolant additives and get as close to plain distilled as I can. I am going to run Mayhems x1 clear/uv blue for now. Maybe I shouldn't even bother but just wondering if anyone has done this? If so how?
I've done some mild research. Most things point to an acid solution but I worry about the copper underneath. Same thing with any type of media blasting.
Sekkusu is offline
post #2 of 7 (permalink) Old 04-01-2020, 10:21 AM
Food Editor
skupples's Avatar
Rep: 720 (Unique: 378)
seems like a waste of time and effort if you have proper coolant to prevent flaking. X1 won't affect cooling potential, and will drastically reduce evaporation.
it does not affect temp in any meaningful way. you'd need stupidly expensive scientific equipment to judge that difference.
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #3 of 7 (permalink) Old 04-01-2020, 03:40 PM
broodro0ster's Avatar
Rep: 9 (Unique: 8)
X1 is very safe for nickel. Don’t bother removing it.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #4 of 7 (permalink) Old 04-01-2020, 03:59 PM
jonkrmr's Avatar
Rep: 4 (Unique: 4)
Plus, to get the nickle plating off would require a chemical soak you would not be able to do. It would need to be done by a professional plating business. One that does chrome work and such.
jonkrmr is offline
post #5 of 7 (permalink) Old 04-01-2020, 05:16 PM
Overclocker in training
ThrashZone's Avatar
Rep: 170 (Unique: 103)
Hi,
Funny
Make a temp loop use a aluminum rad and silver coil and just use distilled water lol
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
10900k batch # X016E724
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
Operating System
ThrashZone is offline
post #6 of 7 (permalink) Old 04-01-2020, 05:48 PM
Food Editor
skupples's Avatar
just drop it in ketchup for a week. scrub, repeat. that shart will come off if its EK brand nickel.
skupples is offline
post #7 of 7 (permalink) Old 04-02-2020, 05:47 PM - Thread Starter
Sekkusu's Avatar
Rep: 0
Thanks for all the responses.
I know the chemical solutions required and the proper mixes so no I don't need a professional shop. I also have access to the chemicals. Was trying to avoid it as they are obviously not a great solution and could damage the copper underneath if left in too long.
Besides coolant I'd like to have a pure copper loop. Guess I'll wait till the GTX 4000 series and just upgrade to a pure copper block then. Maybe Optimus will have a block for it by then. If they are still around after all this.
I may still attempt this just because. Was just hoping someone had other ideas besides the standard approach.
I guess I'll just go with the company that makes the stuff straight out of Milwaukee, WI. Since I only live an hour from them.
https://www.metallinechemicals.com/p...lt.aspx?id=510
Sekkusu is offline
