RTX 2070 XC Ultra NZXT G12 questions - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 04-01-2020, 11:20 PM - Thread Starter
hotripper's Avatar
Rep: 1 (Unique: 1)
So I'd appreciate some answers to some questions I have if possible. See my rig specs below.
I am so over the noise of the XC Ultra cooler. I ordered the G12 should be here in a week hopefully and watched countless videos of installs etc. Please, yes I am aware the card vrms dont get cooled on one side blah blah blah. For reference with stock cooler I get about 30-40c idle depending on the temp for the day and 65-70c load with 100% jet engine fan with a +95mhz oc and +799 on vram resulting in 2040mhz. On to my questions:
1. Is it worth $15-$25 replacing the g12 stock fan with a noctua?
2. From what I have seen the Back and Front plates can be left on, my theory is this can act as EVGA intended heat sink for the vrm blaha blah blah comment above, I was thinking of strapping another fan on or getting a pci fan bracket near the side with no fan. Or better to take the plates off and not over think it?
3. Does anyone know if there is an adapter for the "newer fan connection" on the card anywhere to buy. The XC ultra has the same connector as the FE. No longer can use those Gelid vga to 4pin adapters people have.
4. So looking for Asetek coolers. I am leaning towards EVGA CLC240 for $99, I have some extra Noctua fans already so I will be slapping those on. I was also thinking Kraken x53 or whatever it is called for $129 ( I also heard that they do not come with AM4 bracket?) if I can get it for $99. Or any $99 or less 240mm Asetek cooler for that matter. I am also thinking if down the road I may use it as a CPU cooler so I would prefer to stay away from single fan coolers.
5. If anyone could comment on pump speed settings etc.
Thanks!
Couch Rig
(12 items)
3700x
X570 Aorus Elite Wifi
RTX 2070
Trident Z Neo F4-3600C16D-32GTZNC
970 EVO
EVGA Supernova 750 G2
Thermalright TrueSpirit 140 Direct
Kraken G12 Fractal Celsius S24
NZXT H500
Operating System
Win10 Pro
Sony X720E
Audio
Yamaha RX-V379
hotripper is offline
post #2 of 5 (permalink) Old 04-02-2020, 09:11 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1399 (Unique: 722)
the VRM needs a heatsink, if you take them off then you need to add a replacement.
you can leave your front plate on, it'll cool your vRAM fine.
the silver/white part cools your VRM and it looks like it's secured by the stock heatsink (assuming the heatsink screws in on the 6 holes on the edge), so if you swap the heatsink you'll need to take it off and find a way to cool the mosfets that are underneath. the G12 should come with either thermal tape or thermal epoxy/adhesive (never bought a G12 but my Raijentek Morpheus did) but if it doesn't then you need to buy some.
you don't need to replace the fan unless you want to, they wouldn't include it if it was inadequate.
can't help you with a fan adapter, I used a cheap $4 cable on Amazon for my 1080 TI but it was normal 4-pin mini-PWM.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Gigabyte GA-H55N ITX
EVGA GTX 950 2GB
G.Skill DDR3-2133 8GB
Dierya 120GB SSD
Seagate Momentus 2.5" 500GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
CoolerMaster MasterKeys Pro S (Browns)
Mouse
Logitech M512
The Pook is online now
post #3 of 5 (permalink) Old 04-02-2020, 09:48 AM
Overclocker
JackCY's Avatar
Rep: 358 (Unique: 255)
I would:
  1. not do it as you could as well buy a 2080/Super instead with that much extra money
  2. leave all heatsinks on the card, if some are in the way of the cooling plate of water cooler, well cut the offending parts away
  3. you don't need to replace fans duh, noctua is overhyped and overpriced too
  4. you can control fans on your mobo with GPU temperature as source, make your own curve etc. look for Speedfan or similar software
  5. not buy cards with proprietary connectors if I plan to mod them and if I had to well, snip snip, chop off the old connector and hook up what ever fans I want to it, screw RGB off with that FAD
JackCY is offline
post #4 of 5 (permalink) Old 04-02-2020, 10:03 AM - Thread Starter
hotripper's Avatar
Rep: 1 (Unique: 1)
Thanks for your re.
Evga actually designed the heatsink to be super easy to service the card. Only held on by the 4 screws around the gpu. Only 2 points of contact: GPU and that thermal pad, thats it. The vrm arent even getting direct air with the stock cooler, only air that makes it through the fins and even then the vrms are under the plate which like you said is acting as the heatsink for the vrm and mem.
That stock thermal pad is probably doing very little although is there to transfer some of that heat to the fins.
After looking at that pic and reading your post, I think the G12 will actually do a better job at cooling those vrms with direct air pushing on it. It doesnt have to go through fins as the stock cooler does. Also I will leave both plates on. I will remove the pad and let the direct air hit it, I may add some low profile copper sinks to that strip if I have the clearance.
Yeah about the G12 fan, I am sure it is capable but thinking Noctua might be quieter, generally saying they are more efficient. Guess I'll cross that bridge when I get to it.
Gonna see if I can take apart that stock heatsink, maybe I can poach that fan connector from it.
Couch Rig
(12 items)
3700x
RTX 2070
970 EVO
NZXT H500
Operating System
Win10 Pro
Sony X720E
Audio
Yamaha RX-V379
post #5 of 5 (permalink) Old 04-02-2020, 10:08 AM - Thread Starter
hotripper's Avatar
Rep: 1 (Unique: 1)
Quote: Originally Posted by JackCY View Post
I would:
Couch Rig
(12 items)
3700x
RTX 2070
970 EVO
NZXT H500
Operating System
Win10 Pro
Sony X720E
Audio
Yamaha RX-V379
