[Build log] Ghetto mora - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 04-03-2020, 01:28 PM - Thread Starter
I can count to potato
Fluxmaven's Avatar
Rep: 52 (Unique: 21)
Due to spending a lot more time at home I have realized how much water cooling stuff I have lying around and wanted a simple project. My main rig actually does great as it sits, but there's no such thing as overkill so why not add some cooling.
There are definitely parts of this that belong in the ghetto rigging shenanigans thread.
Parts:
My first radiator is coming out of retirement. A ThermoChill pa120.2
The Magicool rad was in use recently and it's already clean and ready to go.
the 3rd rad is an old Swiftech that came in a lot of stuff I bought a long time ago...
I'll Blitz and rinse all of them to be safe.
I came across the Phobya rad stand in the ModMyMods clearance section which is what originally sparked the idea to to the whole thing. I added a Barrow bracket to the top to accommodate a 3rd rad.
Heakiller tube D5 pump/res combo was a spare that I had in storage. It was a 200mm like the one in my Darling build, but I swapped to the 100mm tube/struts because I was originally going to mount it on the side of Phobya stand. Ended up not finding any of the basic tube mounting kits in stock anywhere stateside so I used the stand mount that I had.
Fans are running off a Aquacomputer Poweradjust3 Ultra going into a Splitty9. There's a g1/4 temp probe to run the fans off liquid temp.
Fans are Arctic P12's
Ghetto stuff:
Didn't feel like fabricating nice feet for the stand so I grabbed a 1in x 12in x 3ft piece of pine from Lowes and just cut it down to size and hit it with a propane torch because I couldn't be bothered to paint or stain it.
The worst part of the whole build is the decoupling mount. I bolted the rubber decoupling screws to an old wire fan grill and then screwed that straight into the base with some washers. Hey if it looks stupid but it works, it ain't stupid.
The holes for the bulkhead fittings were just a bit too small. In order to stabilize my hole saw bit to drill them out a bit bigger I stuck a conveniently pretty perfect sized piece of firewood on the back side and secured it with drywall screws because I use those for everything.
I decided to move the Poweradjust to the other side and lower. I had a perfect length cable to still run the wire up the side, through a hole in the top and into the splitty.
That's where she's at for now. Need to finalize the actual radiator placement and tubing runs, clean the rads, and do a final assembly.
Thanks for coming to my TED talk.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
64GB TridentZ 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is offline
post #2 of 6 (permalink) Old 04-04-2020, 07:16 AM
Rep: 1 (Unique: 1)
Impressive project, it looks pretty damn clean. I assume you work with this stuff regularly as in industry/hobby, I like the compactness. If the frame would be a tad bit shorter I think this would be pretty awesome if it fit in a tower case as well! Or maybe an add-in kind of thing? Damn, it would be so nice to have modular cases, like just add radiator space wherever you need it.
Asunder is online now
post #3 of 6 (permalink) Old 04-04-2020, 07:35 AM
Overclocker in training
ThrashZone's Avatar
Rep: 170 (Unique: 103)
Hi,
Yeah I might be doing something similar to a mora 3 360 pro supposed to show up today
I have no idea what comes with it or even if it comes with feet.
Don't think I'll need the pump on it seeing I already have dual pumps.
Where to put it is the main issue
Ghetto will be trying a box fan in front of it instead of 18 fans
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
10900k batch # X016E724
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
Operating System
ThrashZone is offline
post #4 of 6 (permalink) Old 04-04-2020, 07:42 AM
Food Editor
skupples's Avatar
Rep: 721 (Unique: 379)
that's not ghetto. it's a classic replica at that point.
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #5 of 6 (permalink) Old 04-04-2020, 07:51 AM
ThrashZone's Avatar
Hi,
Bad thing is mora/ quick disconnects will be here 3-4 weeks before the soft tubing will be
Someone bought all 10-16mm clear from modmymods I knew I shouldn't of said anything about them selling at 0.59 a foot
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
EVGA 1000P2
Corsair 450D
Operating System
post #6 of 6 (permalink) Old 04-04-2020, 03:29 PM - Thread Starter
Fluxmaven's Avatar
Thanks, I just know enough to be dangerous and or fix things around the house. My day job is in IT.
There have been modular cases before. The problem is that adding functionality like that increases costs and people are cheap. Running external rads is pretty cool™ since they always have fresh air.
Quote: Originally Posted by ThrashZone View Post
Hi,
Mora doesn't come with anything. The feet, grills, and pump mounts are all optional accessories. I have a grill and a wall mount kit on mine and have it mounted under the desk. On that build, the pump is in the PC and I just have a long molex extension that runs to it to power the fans.
Thanks fam, I have the genuine article as well and they are a nice piece of kit compared to this setup.
Didn't make much progress on it today. Came up with this setup to add in a drain valve and the temp plug. Used a bitspower d-plug set as a spacer and rotary fitting lol. Seems pretty secure. I added some foam under the end of the 5 way to support it.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
GTX 1080 FE
WD Black SN750
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Keyboard
Mouse
Glorious Model O
Mousepad
Audio
Audio
Focusrite 2i4 Gen2
Audio
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
WD Blue 3D m.2
Corsair AX760
InWin D-Frame Mini
i7 6700
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
