Custom Loop Question - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 04-05-2020, 06:22 PM - Thread Starter
Dream Chaser
jfizz84's Avatar
Rep: 217 (Unique: 196)
Hey OCN! So I am looking to get back into watercooling and will be purchasing my parts starting in the next couple of weeks. I plan on mounting my components in a desk, with a sheet of glass over it. So I have included a picture of my loop idea, but I am just worried about the routing and order. Can someone let me know if this loop order looks sufficient and spot any issues I am not seeing. Keep in mind, the res and pump will be mounted flat inside this desktop. i have included a picture of a similar setup so you see what I am planning. Thanks!
Coal Factory
(15 items)
8700K
AsRock Fata1ity Gaming K6
Gigabyte 1080 Auros
Corsair Dominator Platinum
Mushkin 240GB SSD
WD Blue 1TB
Seagate Firecuda
Optical Drive
Hitachi DVD-RW
EVGA G2
Stock
Corsair 750D
Operating System
Windows 10
28" Asus
Keyboard
Roccat ISKU
Mouse
Roccat Kone Naval Storm
jfizz84 is offline
post #2 of 16 (permalink) Old 04-05-2020, 06:36 PM
Invalid Media
J7SC's Avatar
Rep: 73 (Unique: 31)
...probably might not make that much difference (and I hope I'm not misreading your diagram), but I typically mount radiator(s) right after the heat-generating components (ie CPU, GPU), then into the reservoir and then on to the pump which then feeds back into the water-blocks for CPU and GPU.
[also 'optional' comment' ...with a desk affording you plenty of space, have you considered dual rads (depending on the size & thickness you settled on, ie 360x60 ?). I know it would mean more 'plumbing and fan wiring' but with a desk-computer-build, might as well use all that space you gained ?]
J7SC is offline
post #3 of 16 (permalink) Old 04-05-2020, 06:43 PM - Thread Starter
Dream Chaser
jfizz84's Avatar
I see what you mean. I was thinking in my head I wanted the cool water to go directly into heat generating components and not give time for the water to warm up before going back through the loop. I did think about dual rads, but the radiator I was looking at was an EK Coolstream 480. Do you suspect that maybe I'd be better of with 2 smaller rads, 1 for CPU and 1 for GPU, or will the bigger one for both suffice?
Also unrelated question...can you install more than one temp plug in your loop to monitor temps lets say before and after the radiator?
Thanks guys and gals!
Coal Factory
(15 items)
8700K
Gigabyte 1080 Auros
Mushkin 240GB SSD
WD Blue 1TB
Seagate Firecuda
Optical Drive
Hitachi DVD-RW
EVGA G2
Stock
Corsair 750D
Operating System
Windows 10
28" Asus
Keyboard
Roccat ISKU
Mouse
jfizz84 is offline
post #4 of 16 (permalink) Old 04-05-2020, 07:05 PM
Invalid Media
J7SC's Avatar
Quote: Originally Posted by jfizz84 View Post
I see what you mean. I was thinking in my head I wanted the cool water to go directly into heat generating components and not give time for the water to cool before going back through the loop. I did think about dual rads, but the radiator I was looking at was an EK Coolstream 480. Do you suspect that maybe I'd be better of with 2 smaller rads, 1 for CPU and 1 for GPU, or will the bigger one for both suffice?
Re. radiator count and size, it really comes down to a.) your components and b.) planned 'oc'. I would think that the EK 480 should be able to handle quite a lot of heat, but once you get into a 380w-400w GPU (ie some 2080 Ti) and an oc'ed multi-core HEDT CPU at >1.33v, things might get toastier.
I typically run mutli-GPUs (ie sig rig) and thus always run separate loops for CPU and GPU...not an absolute necessity, but it works for me. Just the two GPUs in my system put out a combined 780w. That said, you do not need separate loops to run two (or more) rads, but the more components you add per loop, the more you want to consider the pump's head pressure rating.
Along the same line, having more than one temp plug in your system shouldn't be an issue unless the the temp plugs are restrictive. Usually, GPU blocks are the most restrictive in a loop, then CPU blocks
J7SC is offline
post #5 of 16 (permalink) Old 04-05-2020, 07:16 PM - Thread Starter
Dream Chaser
jfizz84's Avatar
I am planning on a 5700XT GPU with OC, and I have an 8700K with OC. Like you said, given the space I will have I am not opposed to getting dual radiators...maybe 2 240 radiators in a single loop? I am concerned about pump pressure though, but the ek-xtop revo dual pump is sooooo expensive. Do-able but expensive.
So I guess those are the main questions right now...2 smaller rads or 1 big rad? And single pump or dual pump?
Coal Factory
(15 items)
8700K
Gigabyte 1080 Auros
Mushkin 240GB SSD
WD Blue 1TB
Seagate Firecuda
Optical Drive
Hitachi DVD-RW
EVGA G2
Stock
Corsair 750D
Operating System
Windows 10
28" Asus
Keyboard
Roccat ISKU
Mouse
jfizz84 is offline
post #6 of 16 (permalink) Old 04-05-2020, 07:24 PM
Food Editor
skupples's Avatar
Rep: 720 (Unique: 378)
you know LianLi makes a desk like that, AND its motorized adjustable?
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #7 of 16 (permalink) Old 04-05-2020, 07:30 PM
Invalid Media
J7SC's Avatar
I think a single EK 480 and D5 type pump should be able to handle an oc'ed 5700XT and oc'ed 8700K well, especially with a well-ventilated desk design you had drawn out above.
If you do decide to go for two rads, then why not go for some 'thick' 2x 360s instead of 2x 240s; that also gives you some headroom for future upgrades. Now, I only use D5 type pumps and while they have a deserved, superb reputation, they do not react well to any air in the system (given their larger internal diameter) - having two D5 in series helps with that, and I also like the fail-over with two D5s, and the solid pressure. But it is not an absolute necessity to go for dual pumps if you get all the air out.
J7SC is offline
post #8 of 16 (permalink) Old 04-05-2020, 07:37 PM
Food Editor
skupples's Avatar
SideWinder is having a massive sale. Koolance's 450S is on sale for $65(normally ~$80)
also lots of other good stuff half off. all sorts of random BP fittings left.
skupples is offline
post #9 of 16 (permalink) Old 04-06-2020, 02:24 AM - Thread Starter
Dream Chaser
jfizz84's Avatar
I've seen that, however I think half the fun is building it
Definitely worth considering!
I am not opposed to the Koolance pump. But it has less head pressure than the D5. But I did notice both pumps use some form of aluminum. Can I even use either of those with Copper EK waterblocks?
Coal Factory
(15 items)
8700K
Gigabyte 1080 Auros
Mushkin 240GB SSD
WD Blue 1TB
Seagate Firecuda
Optical Drive
Hitachi DVD-RW
EVGA G2
Stock
Corsair 750D
Operating System
Windows 10
28" Asus
Keyboard
Roccat ISKU
Mouse
jfizz84 is offline
post #10 of 16 (permalink) Old 04-06-2020, 03:50 AM
Shawnb99's Avatar
Rep: 59 (Unique: 40)
The water temperature will even out so there is no single component that will dump enough heat to increase the temps that you need to add a radiator after it.
I have temp sensors on every inlet/outlet in my loop and at no stage is any more then a degree of each other.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
