Custom loop for 9900KS and 2080Ti - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 04-06-2020, 12:24 PM - Thread Starter
Rep: 0
i currently have my 9900KS on a H150i and have a hybrid EVGA 2080Ti. Things work fine, but I am unable to hit that 5.2Ghz OC on the 9900KS so looking into doing my first custom loop. Case is a Lian Li Dynamic XL. Looking at a 2 rad system.
Questions:
Should i build 2 loops or keep everything in on?
Do you run the loop to the CPU/GPU and then both radiators in series?
Will a custom loop with 2 360rads help me hit 5.2Ghz on the 9900KS? I had to stop on stability testings at about 1.38v due to heat getting into the mid 90s on P95 Small FFT noAVX
What brand radiators, cpu block, pump/res should I be looking at? The corsair stuff looks pretty easy but not sure of quality
What coolant? I understand some colored stuff separates or corrodes and creates a maintenance nightmare
Thanks for helping the cooling newb
HllCntryHrrcane is offline
post #2 of 8 (permalink) Old 04-06-2020, 12:34 PM
Overclocker in training
ThrashZone's Avatar
Rep: 170 (Unique: 103)
Hi,
You don't show a region.
Performance pc should have some easter discount codes coming soon
Best blocks... are optimus if in the USA.
https://optimuspc.com/
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
10900k
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
Operating System
ThrashZone is offline
post #3 of 8 (permalink) Old 04-06-2020, 12:35 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1394 (Unique: 721)
loop order doesn't matter, the old rule of thumb used to be pump -> radiators -> rest of loop -> pump so that the "heat" from the pump would be taken care of by the radiators before it goes to your blocks but it's such a little amount of heat that it's irrelevant.
one large loop or two separate ones are kind of up to you but you're going to have to grab a second pump ($$) so unless you have a reason to (or just want two separate loops for aesthetics) I'd just do one.
your radiator choice should match your fans, figure out the noise level you want and then figure out the fans you want and then base your radiator off that.
Name:	360 Radiator Performance at 1GPM + 750RPM.png
Name:	360 Radiator Performance at 1GPM + 1300RPM.png
Name:	360 Radiator Performance at 1GPM + 1850RPM.png
Name:	360 Radiator Relative Average Performance.png
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Gigabyte GA-H55N ITX
EVGA GTX 950 2GB
G.Skill DDR3-2133 8GB
Dierya 120GB SSD
Seagate Momentus 2.5" 500GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
CoolerMaster MasterKeys Pro S (Browns)
Mouse
Logitech M512
The Pook is online now
post #4 of 8 (permalink) Old 04-06-2020, 12:48 PM - Thread Starter
Rep: 0
Yes, I am in the USA. I would reuse my existing fans which are Corsair ML120s.
The 9900KS is doing around 220-230watts at 5.2 1.380v. The 2080Ti is probably another 250watts so 500-600watts dissipation total.
post #5 of 8 (permalink) Old 04-06-2020, 02:48 PM
ThrashZone's Avatar
Hi,
Most water cooling is budget
But actually if you start out with good stuff you skip a lot of waste
Optimus foundation blocks are freaking awesome bottom line
They also have good D5 pump sata powered at 75.00 have you ever rma'ed to Germany ? it bites
If still to pricey heatkiller 4 pro is also an awesome block plus they have some nice reservoir combos/ gpu water blocks.... but not local as optimus is
https://www.performance-pcs.com/wate...-wc-18009.html
https://www.performance-pcs.com/wate...c-30199-d.html
Name:	heatkiller pro 4 blocks.JPG
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
10900k
EVGA 1000P2
Corsair 450D
Operating System
post #6 of 8 (permalink) Old 04-06-2020, 03:13 PM
Watercooler
Socks keep you warm's Avatar
Rep: 144 (Unique: 123)
Quote: Originally Posted by ThrashZone View Post
Hi,
Yeah they are nice blocks, they also make about a 1c difference lol.
OP just go with whatever one you think looks nice.
I like to have fun.
https://stats.foldingathome.org/donor/110855
https://www.trueachievements.com/gamer/II+TH3PRO+II
16 Threads is Good
(10 items)
Intel Core I9 9900K 4.8Ghz
Gigabyte Aorus Elite
Aorus 2080Ti Xtreme Waterforce WB 11GB
Trident Z
Samsung 250 SSD
Cooler Master Silent Pro Hybrid
Watercooling Custom
900D
Operating System
Windows 10 x64
28" ACER 4K Monitor
Socks keep you warm is offline
post #7 of 8 (permalink) Old 04-06-2020, 03:20 PM
ThrashZone's Avatar
Hi,
Depends on who you ask
1c I've seen a lot more than that on 2066 socket
I showed 3 different manufactures prices you offer nothing besides the obvious it's the op choice well no kidding
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
10900k
EVGA 1000P2
Corsair 450D
Operating System
post #8 of 8 (permalink) Old 04-06-2020, 04:44 PM
Watercooler
Hi,
I don't need to show anything as if you go onto a parts website and look at say a standard EK block it will perform well.
I'm not going to link to common items.
I like to have fun.
16 Threads is Good
(10 items)
Trident Z
Samsung 250 SSD
Watercooling Custom
900D
Operating System
Windows 10 x64
28" ACER 4K Monitor
