Lian Li PC-O11DW XL DynamicWater-cooling Part List first try - Overclock.net - An Overclocking Community
post #1 of 1 (permalink) Old 04-07-2020, 12:28 AM - Thread Starter
Rep: 0
Hi,
so after some digging, reading and getting help here my idea of a water-cooling setup and questions:
If you have ANY good suggestions to alternative or think that the option I have chosen is total BS please tell :-)
Pump and Reservoir:
D5 Pump, are Bitspower ok? Or the EK ones? Or perhaps the D5 next.
Any specific suggestion?
Reason for Bitspower is that there are white covers available for it which would allow for a white Pump build.
Otherwise I would probably go for a HeatKiller tank with Red / White bars and a D5 next(?) or any other good combo with reservoir.
Tube:
Size 16/10
Mayhems Ultra Clear (except somebody tells me that PrimoChill PrimoFlex Advanced LRT in red is as good, in which case I could keep the coolant clear)
Coolant:
DP Ultra in Red (clear not opaque)
Radiators:
XPSC 360 36mm or Hardware Labs (perhaps white versions but I think black will do)
Fittings:
Barrow white, incl a Fillport and Drainport
CPU Block:
EK-Momentum Aorus Z390 Master D-RGB - Plexi or Aqua Computer cuplex kryos NEXT CPU Vision or Heatkiller
The Aqua Computer Vision would only be interesting together with the Aquacomputer Monitoring and Control
GPU:
EK Liquid Devil RX 5700 XT
Fans:
LL120 RGB, white 10 x
Control:
Motherboard or
Aquacomputer Aquaero 6 lt + 2 x Farbwerk 360 + 3 x Splitty4 + Hubby7 + RGBpt to DRGB Adapter(?) + Aquabus Splitter
I know that the Aquacomputer Setup would be quite powerful, but does somebody has experience with the Motherboard Bios?
Sensors:
Depends on Pump (as D5 Next has some stuff build in) and if using the motherboard or not but in general:
1 Temperatur Sensor for Loop for the Mainboard (as I have no idea if I can otherwise get any temps in OSX)
1 Flow Meter Sensor
1 Temperatur Sensor for AirTemp
Did I forget anything?
Routing of tubing would than come next.
Thanks in advance
Don
DonRedhorse is offline
