Hardware Labs SR-2 issue, is it fixable? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 20 (permalink) Old 04-11-2020, 01:24 PM
NewUser16's Avatar
Rep: 56 (Unique: 37)
Quote: Originally Posted by skupples View Post
you're overthinking it.
use an extension fitting.
Even with extensions you will still see shift to one side or the other. If hes going for glass tubing then obviously he goes for aesthetic and quality
NewUser16 is offline
post #12 of 20 (permalink) Old 04-11-2020, 01:37 PM - Thread Starter
Rep: 69 (Unique: 60)
use an extension fitting. standard, watercooling tier 2 inch extension, screw in, bend back. move on with life.
I have no idea what a "watercooling tier 2 inch extension" is, you are basically talking a different language to me. I put together a water cooling computer 8 years ago for the first time (adult legos) and that is the extent of my knowledge about PC water cooling. If you could produce a picture of the part or a part # of what you are talking about I might have a better idea of what you're talking about.
Thanks for your help thus far, much appreciated.
Systemlord is offline
post #13 of 20 (permalink) Old 04-11-2020, 01:47 PM - Thread Starter
Quote: Originally Posted by NewUser16 View Post
If they are new I would return and get replacement, ports should be straight. HL are the highest quality rads and this should be no exception, but defects happens.
Easier said than done, there are "no replacements", no Hardware Lab radiators to buy online, sold out "everywhere". It's either make this work or broke.
post #14 of 20 (permalink) Old 04-11-2020, 01:54 PM
NewUser16's Avatar
They might be gone now, but not forever, unless these particular rads has been discontinued and even then, HL has to have similar specs replacements if you within warranty period. I know If I was facing this I would rather wait until they are available and get the proper rads to make it right. Then again, If you on hurry and comes push to shove scupples making good suggestion
post #15 of 20 (permalink) Old 04-11-2020, 03:12 PM - Thread Starter
Ok I bought the 1/4 BSP and it doesn't thread in all the way, it seems tapered, I need some suggestions and really want to make this work because I want a drain port on the side and I can't have a drain port with any other Hardware Labs radiator.
post #16 of 20 (permalink) Old 04-11-2020, 04:33 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
they are? I just got 4 SR2s in the mail this week. Guess it happened after Monday.
OP -
https://www.performance-pcs.com/cata...nsion%20g1%204
NewUser - idk if you've looked out the window recently, but you kinda gotta work with whach'ya got right now.
Good luck getting them to respond to an RMA right now too, specially on something so frivolous.
Add me on Steam, same name
skupples is offline
post #17 of 20 (permalink) Old 04-11-2020, 04:54 PM
sultanofswing's Avatar
Rep: 5 (Unique: 5)
Yes it is tapered but if you notice the fittings that are used only use maybe 3 threads.
[email protected] GHz - 0 AVX @ 1.300v w/ Heatkiller Block + Delid | EVGA X299 Dark | Kingpin 2080ti with Bykski Block on water. | 3 XSPC 360's and 1 XSPC 480 | 32gb Corsair [email protected] | 1TB NVME/1TB Sata SSD | Seasonic Prime Platinum 1200 | Phanteks Enthoo Elite | Viewsonic XG-2703-GS | Windows 10-says pro but seems like an amateur
sultanofswing is offline
post #18 of 20 (permalink) Old 04-11-2020, 04:57 PM
Vermin Supreme 2020
skupples's Avatar
brooooo what're you doing.
no way that tapered thread is what you need.
where did you go? Home Depot? Would've been better off at a Boat Parts store (if you have one of those) or neighborhood Hardware (like ace)
https://shop.bitspower.com/index.php...roduct_id=1157
skupples is offline
post #19 of 20 (permalink) Old 04-11-2020, 05:11 PM
NewUser16's Avatar
Couldn't get more of a raw metal then this. I don't know if any anti corrosives will help to prevent from fast corrosion
post #20 of 20 (permalink) Old 04-18-2020, 04:20 PM - Thread Starter
I got everything straightened out, it was easier than I thought it was going to be.
Thanks for all the assistance guys.
