Custom loop - Overclock.net - An Overclocking Community
Custom loop
post #1 of 165 (permalink) Old 04-15-2020, 10:10 AM - Thread Starter
lstmysock11's Avatar
Rep: 3 (Unique: 3)
Custom loop
Hi all
Had been planing to do a custom loop on my new computer in the middle of building, Thought of using Primochill mostly but had a bad experience on their discord. Anyway would like to find ideas and what I would need as far as parts and fittings from other companies.
Also looking for as many as these parts that I can get in White, Since the case is black I want to do a Black and White theme
Using a Phantecks Entho 719(Aka the Lux)
Amd Ryzen 7 3700x
MSI 570 gaming plus
XFX RX5700 XT Thic III
Accelero extreme III For the GPU
Had run through Corsairs Hydro config online tool but honestly their prices seem a little high if you ask me.
lstmysock11 is offline
post #2 of 165 (permalink) Old 04-15-2020, 10:18 AM
Back at it again.
Avacado's Avatar
Rep: 100 (Unique: 75)
All custom loops require a serious investment. You did not not say what exactly you were looking for. CPU only, CPU+GPU? Budget?
22643 Time Spy https://www.3dmark.com/3dm/46344026?
https://folding.extremeoverclocking....e.php?u=207393
White Lightning
(12 items)
i7 9700k @ 5.1GHz 1.385v
ASUS Prime Z390-A
Evga 2080 Ti Black Gamer
32GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w
Corsair H150i Pro
CORSAIR Crystal 570X White Mid Tower
Operating System
Windows 10 Home
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #3 of 165 (permalink) Old 04-15-2020, 10:26 AM
I can count to potato
Fluxmaven's Avatar
Rep: 52 (Unique: 21)
Are you wanting to do hardline or soft tube? do you want to use clear tubing with pastel white fluid, or white tubing? For cheaper fittings, Barrow are pretty good and come in white.
A good white 420mm Rad
A 480mm option
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
64GB TridentZ 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is offline
post #4 of 165 (permalink) Old 04-15-2020, 10:31 AM
Back at it again.
Avacado's Avatar
These fittings are tits. Best Iv'e used so far. https://www.amazon.com/Bykski-Enhanc...%2C141&sr=8-18
White Lightning
(12 items)
ASUS Prime Z390-A
EVGA 1000w
Corsair H150i Pro
Operating System
Windows 10 Home
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #5 of 165 (permalink) Old 04-15-2020, 10:49 AM - Thread Starter
Rep: 3 (Unique: 3)
Just the CPU water cooled and hoping to keep it around 500 us for all the cooling parts and would like to use hard tube and have in a drain/fill port off the res.
post #6 of 165 (permalink) Old 04-15-2020, 10:55 AM
Back at it again.
Avacado's Avatar
That should be possible. You want Res/Pump combo? Or separate.
White Lightning
(12 items)
ASUS Prime Z390-A
EVGA 1000w
Corsair H150i Pro
Operating System
Windows 10 Home
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #7 of 165 (permalink) Old 04-15-2020, 10:59 AM
Back at it again.
Avacado's Avatar
I would advise to use these guys https://www.performance-pcs.com/ you can get free shipping on orders over 75$ and using code OCN55 gives you 5% off your order.
White Lightning
(12 items)
ASUS Prime Z390-A
EVGA 1000w
Corsair H150i Pro
Operating System
Windows 10 Home
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #8 of 165 (permalink) Old 04-15-2020, 11:00 AM - Thread Starter
Rep: 3 (Unique: 3)
Either separate or a combo but might be less clutter if they are a combo unit. Then again the Phanteks case has plenty of room. Also not sure what fans of course want to keep the price down on fans since this Phanteks case comes with no fans.
post #9 of 165 (permalink) Old 04-15-2020, 11:08 AM
( ━☞´◔‿ゝ◔`)━ ☞
Kokin's Avatar
Rep: 427 (Unique: 365)
You'll need to provide more context of what you want to use. Depending on rigid tubing or soft tubing, it will change what type of fittings you'll purchase.
I actually swapped to white fittings when I re-vamped my loop last year. I previously used XSPC black chrome compression fittings and went with Barrow white compression fittings for soft tubing. The Barrow fittings are similar to Bitspower fittings but are much cheaper and are unbranded for a cleaner look. I also use Mayhem's Pastel white coolant with Primochill Advanced LRT clear tubing to show off the white opaque coolant. For radiators, I used Hardware Labs GTS radiators, which are sold in white from PPCs directly or PPCs via Amazon.
Black Heart
(22 items)
AMD Ryzen 9 3900X 12c/24t
Asus ROG Crosshair VIII Impact X570
EVGA GTX 1080Ti FTW3 11GB
G.Skill TridentZ DDR4 2x16GB 3200MHz 14-14-14-34 1.35V
Inland Premium 2x2TB PCIe 3.0 NVMe SSD in Raid0
Crucial MX500 2TB Sata SSD
Seasonic Prime 600W Titanium Fanless SSR-600TL
EK-Supremacy EVO RGB - Acetal+Nickel
EK-FC1080 GTX Ti FTW3 - Nickel
Phanteks Glacier R160 Reservoir
Swiftech MCP35X
Hardware Labs Black Ice Nemesis 280GTS White
Hardware Labs Black Ice Nemesis 240GTS White
Noctua NF-A12x25 PWM (4x rad intakes, 1x case exhaust)
Case Labs Mercury S3
Operating System
Windows 10 Pro
Alienware AW3418DW 34" Ultrawide IPS 3440x1440 120Hz G-Sync
Qnix QX2710 PLS 2560x1440 120Hz
Keyboard
WASD CODE V2 87-Key [MX Green + /dev/tty Keycaps]
Mouse
Logitech G Pro Wireless
Audio
Sennheiser HD 6XX
Audio
Micca OriGen G2 USB DAC/Amp
Kokin is offline
post #10 of 165 (permalink) Old 04-15-2020, 11:10 AM
Fluxmaven's Avatar
Having a separate pump and reservoir adds an additional tubing run and fittings. Combo unit is typically the way to go. Arctic makes probably the best budget fans. They do have white models that are available individually, but the 5 packs of black fans are unbeatable for the price.
https://www.arctic.ac/us_en/p12-pwm.html
Another option would be the grey Noctua Redux line.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
GTX 1080 FE
WD Black SN750
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Keyboard
Mouse
Glorious Model O
Mousepad
Audio
Audio
Focusrite 2i4 Gen2
Audio
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
WD Blue 3D m.2
Corsair AX760
InWin D-Frame Mini
i7 6700
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
