Tweaking the loop. - Page 3 - Overclock.net - An Overclocking Community
Tweaking the loop.
post #21 of 26 (permalink) Old 05-15-2020, 05:26 PM
munternet's Avatar
Rep: 31 (Unique: 13)
Quote: Originally Posted by RoivonPC View Post
Update. I've eliminated the t block configuration and have gone with my mock up. I've also done a much simpler single bend tube from the bottom rad to the GPU. I've gone up to 160 l/h. I still plan on changing out the bottom radiator at some point so I can take advantage of the space I have down there. I may condsider the X Flow radiator for up top but only if I can fine one that's similar length. These rads were already a pain in the ass to get installed.
Either way you look at it that's still around about 3/4 of a 44 gallon drum of water passing through in an hour, so if the radiators are doing their job you would expect reasonable results wouldn't you?
Github Memory Overclocking Tutorial
GSAT in Windows 10 https://www.overclock.net/forum/1805...l#post28448038
Maximus XI Gene Overclocking Results Thread https://www.overclock.net/forum/5-in...k-results.html
9900ks
Asus Maximus XI Gene
EVGA 1080 Ti Superclock 2 Black
F4-4400C19D-16GTZSW
Samsung M.2 1TB 970 EVO Plus
Corsair HX1200i
EK 140D5 Pump, waterblocked CPU, Ram, GPU with 1 x 360mm and 1 x 420mm Radiators and Vardar Furious Fans
ThermalTake V51
Operating System
Windows 10 Pro
Asus PG349Q 34.1 inches 3440 x 1440 pixels @ 120 Hz
Keyboard
Corsair K95 RGB Platinum
Mouse
Logitech Gaming Pro Wireless
Mousepad
1000x500x3
Audio
Steelseries Siberia800 wireless Headset
8700k @ 5.2ghZ
Maximus X Hero
32GB 1xF4-4400C19D-16GTZSW & 1xF4-4400C19D-16GTZKK
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Lite
Keyboard
Mouse
Asus Spatha Wireless Gaming
Mouse
Ligitech G602 wireless
Mousepad
1000mm x 500mm
Audio
i7-4770k
Asus Maximus VII Ranger
Gigabyte NVIDIA GeForce GTX980
G.SKILL Trident X 16GB 2 x 8GB 2400 Memory F3-2400C10D-16GTX
Seagate Barracuda 2TB
Optical Drive
LG DVD Rom
PSU Coolermaster V1000W
Custom Loop
Case Thermaltake V51 Full Window
Operating System
Windows 7
Shimian 2650x1440
Keyboard
Thermaltake Poseidon Z
Mouse
Logitech G602
munternet is offline
post #22 of 26 (permalink) Old 05-15-2020, 06:05 PM
Rep: 1 (Unique: 1)
Quote: Originally Posted by sultanofswing View Post
Are you 100% sure the pump is running at full speed? Should be 4800ish RPM.
I have 3 rads in my loop with 2 blocks and a single pump will net me 247lph at full speed so for you to only be getting 160ish that seems pretty low.
Also make sure none of your blocks are clogged.
This is a good point.
OP,
The Optimus block will catch everything in your system (and obstruct flow) if its not completely cleaned.
As for draining from a radiator, I'm using a bitspower Leviathan - which happens to be a hardware labs rebrand - 360 in the bottom of my O11 XL. It has four ports on one end, and sitting on top of 25mm fans, it leaves me with enough space for a drain fitting... and it also happens to be the lowest point in the system.
Thoughts?
Can you change the orientation of your bottom radiator, and get these runs behind your resevoir? Put your flow meter and t valve in line with the rear most run.
Mxj1 is online now
post #23 of 26 (permalink) Old 05-21-2020, 08:58 PM - Thread Starter
Rep: 1 (Unique: 1)
Not easily, not without doing the entire bottom half of my loop again.
The optimus block was brand new, didn't see any obstructions.
Do you have a better picture of the bottom of your res and all the connections?
OP,
RoivonPC is offline
post #24 of 26 (permalink) Old 05-21-2020, 09:02 PM - Thread Starter
Rep: 1 (Unique: 1)
Updated loop.
I'll try and work out changing the orientation of the eventual bottom rad replacement.
RoivonPC is offline
post #25 of 26 (permalink) Old 05-22-2020, 05:55 AM
Rep: 1 (Unique: 1)
Sorry if this is too late. Your new loop looks cleaner. How did it affect your flow? I keep looking at mine trying to figure out what I can do to use two straight fittings into the cpu block and rotate the fittings vertically....
Here's what's going on down there. The loop is setup like this:
Heatkiller Pump/Res > top rad > side rad > bulk head (to rear of case) > flow meter > extra pumps > bulk head > bottom radiator > GPU/PCH parallel > CPU
I've got a handful of odd fittings to make the connections. I've got correct sized fittings on the way to replace those.
Mxj1 is online now
post #26 of 26 (permalink) Old 05-22-2020, 10:32 AM - Thread Starter
Rep: 1 (Unique: 1)
I gained about 20 l/h. During gaming my temps are usually in the low to mid 50s but that's without an overclock (not counting ram to 3600) so I'm curious how my temps will be after. I still plan to change my bottom rad.
RoivonPC is offline
