Tweaking the loop. - Overclock.net - An Overclocking Community
Tweaking the loop.
post #1 of 26 (permalink) Old 05-13-2020, 01:08 PM - Thread Starter
Rep: 1 (Unique: 1)
Tweaking the loop.
So I have currently a 360 GTS, 480 GTS, a 360 L series, Phanteks GPU block and Optimus CPU block. All a recipe of restriction. At 100% pump speed I'm moving 140 l/hr. I'm fairly certain it's my loop design and radiators. I have no intention of changing the front and top radiators because these were already difficult to get installed into my Phanteks 719. I have to replace a thermal sensor that's faulty so at the same time I'm thinking about tweaking the loop a bit. In the future I plan to change my bottom rad from the L series to an Alphacool 45 or 60mm thick rad.
Here's what I'm thinking of doing. First from the pump to the first rad. I currently have a dual radial 90 going into a 90 tube, into a T block. I think if i can do a setup a bit more gradual then the water flow wouldn't slam into the T block 90 before continuing on. So I did a mock up of what I'm thinking of doing. I can use the 2 dual rotary 90s I have to have a much more gradual curve, I then link it back to the T block which is rotated 90 degrees inward into the case. That should give a much straighter shot into the first radiator. Obviously the mock up isn't the correct length.
As for further tweaks I'm going to ditch the dual 90s and extension I have in place for the GPU inlet and just bend another pipe and hope I don't screw it up. My hope is I can free up some more flow and perhaps not have to get a different bottom radiator, although that may still happen.
Thoughts?
RoivonPC is offline
post #2 of 26 (permalink) Old 05-13-2020, 04:17 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 440 (Unique: 293)
Given the components, I would really consider a second pump. Something physically small like a Swiftech MCP50X would get the flow rate up considerably.
ciarlatano is offline
post #3 of 26 (permalink) Old 05-13-2020, 05:04 PM
Overclocker in training
ThrashZone's Avatar
Rep: 170 (Unique: 103)
Hi,
I'd get a multiport rad for the bottom so at least you can drain stsyem properly instead of the T fitting drain thing that will do nothing but kill flow.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
10900k batch # X016E724
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
Operating System
ThrashZone is offline
post #4 of 26 (permalink) Old 05-13-2020, 09:33 PM - Thread Starter
Rep: 1 (Unique: 1)
I'm looking into that now. I'm trying to find a radiator that has the multiports on one end and a a drain port on the opposite side. I have found this with an Alphacool 14174 NexXxoS UT60 but I keep hearing they're not that great. However I may not have a choice due to width restrictions, 125mm or less.
Quote: Originally Posted by ThrashZone View Post
Hi,
RoivonPC is offline
post #5 of 26 (permalink) Old 05-14-2020, 12:06 AM
broodro0ster's Avatar
Rep: 9 (Unique: 8)
The L series radiator and optimus block are you're most restricting parts. But 140lph is not that bad. I'm using 2x GTS rads and I achieve about 215lph. I tried adding a second pump and got 306lph, but it didn't help my temps. The component to water delta stayed the same, and the ambient to water delta went up by 1°C because of the extra heat of the second pump. So in the end, my CPU and GPU went also up by 1°C because of the second pump.
I don't think there is a lot to gain tempwise by adding a second pump or changing 1 radiator. You'll maybe get 0.1gpm extra flow, which will result in 0.3°C better temps. But there is nothing wrong with experimenting if you have some spare to money to get a different rad and extra pump :-)
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #6 of 26 (permalink) Old 05-14-2020, 04:50 PM - Thread Starter
Rep: 1 (Unique: 1)
My L series rad is coming out.
RoivonPC is offline
post #7 of 26 (permalink) Old 05-14-2020, 05:38 PM
Back at it again.
Avacado's Avatar
Rep: 100 (Unique: 75)
I'm in agreement with Thrash here. I have to believe that T off of the pump outlet is killing you. The 2 90 degree fittings beneath the GPU are hurting as well.
22643 Time Spy https://www.3dmark.com/3dm/46344026?
https://folding.extremeoverclocking....e.php?u=207393
White Lightning
(12 items)
i7 9700k @ 5.1GHz 1.385v
ASUS Prime Z390-A
Evga 2080 Ti Black Gamer
32GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w
Corsair H150i Pro
CORSAIR Crystal 570X White Mid Tower
Operating System
Windows 10 Home
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #8 of 26 (permalink) Old 05-14-2020, 05:39 PM
Back at it again.
Avacado's Avatar
If you are going to buy a new rad, consider an X-Flow to replace the top, would eliminate a tube run with a 90 degree fitting.
White Lightning
(12 items)
ASUS Prime Z390-A
EVGA 1000w
Corsair H150i Pro
Operating System
Windows 10 Home
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #9 of 26 (permalink) Old 05-14-2020, 05:53 PM
munternet's Avatar
Rep: 31 (Unique: 13)
Are you having a cooling problem?
Github Memory Overclocking Tutorial
GSAT in Windows 10 https://www.overclock.net/forum/1805...l#post28448038
Maximus XI Gene Overclocking Results Thread https://www.overclock.net/forum/5-in...k-results.html
9900ks
Asus Maximus XI Gene
EVGA 1080 Ti Superclock 2 Black
F4-4400C19D-16GTZSW
Samsung M.2 1TB 970 EVO Plus
Corsair HX1200i
EK 140D5 Pump, waterblocked CPU, Ram, GPU with 1 x 360mm and 1 x 420mm Radiators and Vardar Furious Fans
ThermalTake V51
Operating System
Windows 10 Pro
Asus PG349Q 34.1 inches 3440 x 1440 pixels @ 120 Hz
Keyboard
Corsair K95 RGB Platinum
Mouse
Logitech Gaming Pro Wireless
Mousepad
1000x500x3
Audio
Steelseries Siberia800 wireless Headset
8700k @ 5.2ghZ
Maximus X Hero
32GB 1xF4-4400C19D-16GTZSW & 1xF4-4400C19D-16GTZKK
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Lite
Keyboard
Mouse
Asus Spatha Wireless Gaming
Mouse
Ligitech G602 wireless
Mousepad
1000mm x 500mm
Audio
i7-4770k
Asus Maximus VII Ranger
Gigabyte NVIDIA GeForce GTX980
G.SKILL Trident X 16GB 2 x 8GB 2400 Memory F3-2400C10D-16GTX
Seagate Barracuda 2TB
Optical Drive
LG DVD Rom
PSU Coolermaster V1000W
Custom Loop
Case Thermaltake V51 Full Window
Operating System
Windows 7
Shimian 2650x1440
Keyboard
Thermaltake Poseidon Z
Mouse
Logitech G602
munternet is offline
post #10 of 26 (permalink) Old 05-14-2020, 05:57 PM
Booo
sakete's Avatar
Rep: 13 (Unique: 12)
Concur, all those 90s and and T joints will kill your flow. I have one 90 in my loop (no other choice), and one T (but used correctly, where the drain is off to the side, and the main flow goes straight), with 2 pumps, one running at 4000rpm, the other at 3000rpm, and I get about 160LPH. Granted, I'm using filter in my loop that's apparently highly restrictive, I might get a couple of Y joints in my loop and a couple more valves so I can bypass it during normal use, and turn it on whenever I'm running Blitz 2 through my loop when cleaning. Don't really need a filter in your loop all the time.
Main
(23 items)
AMD Ryzen 9 3900X
Asus X570 ROG Crosshair VIII Formula
EVGA GTX 980Ti SC+
2x 16GB G.Skill Ripjaws DDR4-3600 C16
1TB Samsung 970 EVO+ NVMe
1TB Samsung 850 EVO SSD
480GB SanDisk Extreme Pro
3x 4TB HGST Deskstar NAS (2 in RAID 1)
Seasonic Prime PX-1000
Optimus Foundation AM4
HWLabs GTS 360 XFLOW
Alphacool Nexxos 480
Watercool Heatkiller 980ti Waterblock
2x D5 Pump
Phanteks Enthoo 719/Luxe 2
Acer XB270HU
Keyboard
Corsair K70
Mouse
Logitech G502
Audio
Motu M4
Audio
JBL LSR305
Other
Aquacomputer Aqualis 450ml reservoir
Other
Aquacomputer Aquaero 6 LT
Other
Aquacomputer OCTO
sakete is offline
