Arctic Liquid Freezer II Fans - Page 2 - Overclock.net - An Overclocking Community
post #11 of 20 (permalink) Old 05-14-2020, 11:57 AM
Facepalm
Falkentyne's Avatar
Rep: 442 (Unique: 307)
Quote: Originally Posted by eliwankenobi View Post
Yes the fans are good. I did change the orientation so as to set the fans as intake from the front. Pulling fresh air into the radiator.
Is it better to have the radiator connected hose at the top or the bottom when vertically mounted? I've heard top prolongs longevity, and then I've heard it doesn't matter one bit or top helps against air bubbles. Anyone know?
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Quote: Originally Posted by sakete View Post
Well, I want you to know I have an academic degree in speculation.
Falkentyne is offline
post #12 of 20 (permalink) Old 05-14-2020, 12:04 PM
AMD fan
Tobiman's Avatar
Rep: 65 (Unique: 50)
I have my fans set to intake from the top of the case. The fans are really good temp and noise wise. Maybe, not the best but decent performers, if noise and price are your main criteria.
LIAN LI PC-05SX/SILVERSTONE SX800 LTI
R5 3600
AUROS 1080TI EXTREME WATERFORCE
AUROS B450I
ACER XV340CK
ASUS MG279Q
32GB GSKILL RIPJAWS 3600MHZ C16
Tobiman is offline
post #13 of 20 (permalink) Old 05-14-2020, 12:09 PM
The last VRM burner
Rep: 45 (Unique: 27)
The only reasonable reason to do so is to protect against noise due to eventual liquid vapourisation.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Iris Pro 6200
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #14 of 20 (permalink) Old 05-14-2020, 12:10 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1394 (Unique: 721)
shouldn't matter if the hoses leave the top or bottom of the rad so long as the pump/block isn't the highest point of the loop.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Gigabyte GA-H55N ITX
EVGA GTX 950 2GB
G.Skill DDR3-2133 8GB
Dierya 120GB SSD
Seagate Momentus 2.5" 500GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
CoolerMaster MasterKeys Pro S (Browns)
Mouse
Logitech M512
The Pook is online now
post #15 of 20 (permalink) Old 05-14-2020, 12:12 PM
eliwankenobi's Avatar
Rep: 9 (Unique: 2)
I set it like that following recommendation from Gamer’s Nexus video. Helps prevents air bubbles to go into the CPU block. They stay on top of radiator. Not pretty but functional
eliwankenobi is offline
post #16 of 20 (permalink) Old 05-18-2020, 06:44 PM - Thread Starter
gderreck's Avatar
Rep: 0
Thanks guys,
I am set up with the rad up top, exhaust. There is not a lot of additional room above the motherboard (mounted horizontally, in a v21 cube case). I hadn't thought about front intake. I have an mATX case and an ITX motherboard, so there's lots of room at the front. If I were to buy 2 more fans (it seems I'm determined to do so eh ), would a push pull setup be worth it for a front intake installation? I realize I will be taking air warmed by the rad in front, but I also have 2 x 120mm intake fans on the bottom. I will have plenty of room to set up enough exhaust fans to roughly equalize the air pressure.
One final question. I used non-conductive thermal paste for the install. Given that I understand the need to be very careful, what are the benefits of using liquid metal? The cooler has a copper cold plate. If it's worth it, how far from the edge of the heat spreader should I stop spreading the liquid metal? Or can it be spread to the edges? Finally, does protecting the immediate area around the heat spreader with nail polish help, and does it lead to any long term issues?
You guys are probably wondering why I am going on about this. I live on the 4th floor of an apartment building and I don't have AC. I am concerned about ambient temperature, come summer. Why don't I have AC? That's a question for another day.
I have learned a lot. Thanks again,
Graham
gderreck is offline
post #17 of 20 (permalink) Old 05-18-2020, 07:35 PM
Facepalm
Falkentyne's Avatar
Quote: Originally Posted by gderreck View Post
Thanks guys,
Graham
Use a cutout foam dam to protect the area around the heat spreader. Put the foam dam on a layer of trimmed Super 33+ tape that you made to help cover the outside of the socket retention area.
This is what I did with my 9900K and NH-D15 when I used LM between the IHS and heatsink.
https://www.amazon.com/Duck-Replacem...dp/B002GKC2US/
post #18 of 20 (permalink) Old 05-18-2020, 08:43 PM - Thread Starter
gderreck's Avatar
Rep: 0
Thanks Falk,
Maybe an obvious question, but the cold plate is considerably larger than the heat spreader. Do the tape and dam remain? Or remove dam after tightening the cold plate and leave the tape? If I had to guess, I'd avoid moving anything as any metal on the dam could be transferred to the motherboard. That's a guess based on ignorance.
I'm not quite as dumb as I seem , but this is the first time I have built a machine myself, and I have never had liquid metal as the conductive material before. Given the potential damage LM can do to the motherboard, I want to make sure I'm doing it right.
Graham
gderreck is offline
post #19 of 20 (permalink) Old 05-18-2020, 09:04 PM
Facepalm
Falkentyne's Avatar
Thanks Falk,
Graham
The tape you just apply around the gaps in the socket so LM doesn't ever fall into the socket around the CPU. Just apply it where it's barely touching the IHS and then rub it in a bit. Super 33+ tape is easy to work with. Don't use crappy tape.
The foam just goes on the edges of the socket bracket, right above the tape. That way any LM on the heatsink will get trapped and won't go anywhere else. Just cut out a shape of foam slightly larger in inside cutout than the IHS. It's easy to do. You don't want thick foam. The foam I linked is perfect for the job. The tape and foam serve two different purposes. The tape stops LM runoff from the IHS from escaping off the sides of the IHS and into the socket--if you applied the tape to barely touch the IHS edges. The foam stops LM from getting away off the block and if any LM happens to get on the tape somehow (it shouldn't though), it will stay there.
You can also use kneaded eraser and push it into the gaps around the socket, instead of foam or tape, if you so choose.
post #20 of 20 (permalink) Old 05-20-2020, 07:57 AM - Thread Starter
gderreck's Avatar
Rep: 0
Thanks everyone,
Graham
gderreck is offline
