Arctic Liquid Freezer II Fans - Overclock.net - An Overclocking Community
post #1 of 20 (permalink) Old 05-14-2020, 02:10 AM - Thread Starter
gderreck's Avatar
Rep: 0
Greetings,
I hope this finds you all well.
I have a Liquid Freezer II 240mm cooling my CPU. I have seen a number of user reviewers stating that they took the cooler and swapped out the rad fans. No mention of how. I am wondering if anyone reading this post has changed the rad fans on this cooler. If so, could I get a quick idea of what is involved? The reason I ask is, the fans are routed through the tube's sleeving and terminate at the same plug as the pump and VRM fan. Maybe not your average fan swap.
Now perhaps the difficulty changing the fans requires someone with experience cutting rewiring, crimping, etc. If so, it isn't me. And of course, that would also be an answer. On the other hand, perhaps there is a very simple way of accomplishing the task that I am missing.
Any tips would be appreciated.
Graham
gderreck is offline
post #2 of 20 (permalink) Old 05-14-2020, 02:13 AM
Intel in 2020 LOL
Rep: 37 (Unique: 19)
Why do you want to swap the fans? They are pretty good and very silent. Sure, you can get better fans but they will be much louder. Not worth it.
AMD Bliss
(16 items)
AMD Ryzen 7 3700X
MSI X470 Gaming Pro - 1.0.0.4B
Sapphire RX 5700 XT Pulse
2x8GB G.Skill Trident Z 3600C15 @3800 14-15-12-28-40 1T 1.52V
Samsung 970 Evo Plus 250GB
2x Samsung 860 Evo 500GB
2x Crucial MX500 1TB
Super Flower Leadex II Gold 650W
be quiet! Dark Rock 4
Phanteks P350X
Asus VG245HE
Keyboard
Logitech G710+
Mouse
Logitech G502 Hero
Mouse
Logitech G502 Proteus Core
Mousepad
Logitech G440 hardmat
Audio
Asus Cerberus
Intel Core i5 4460
Gigabyte B85M-D3H-A
Sapphire RX 580 Nitro+ 8GB
2x8GB Kingston HyperX Fury @1600 CL10
Samsung 860 EVO 500GB
WD Blue 1TB
Super Flower Golden King Pro SF-500P14PE 500W 80+ Platinum
Intel Stock Cooler
Zalman Z11+
Operating System
Windows 10 x64
Asus VG245HE TN 1080p 75hz
Keyboard
Logitech G710+
Mouse
Mousepad
Logitech G440
Audio
Logitech X-540 5.1
Intel Core 2 Quad Q6600
Gigabyte P43-ES3G
Asus R9 270X Top 2GB
2x2048MB Kingston DDR2 800mhz
Samsung 840 EVO 120GB
WD Blue 1TB
Sirtec High-Power 80+ 400W
Some 92mm cooler
Zalman Z11+
Operating System
Win 7 Ultimate x64
Several LG/BenQ 17" 1280x1024 75hz
Keyboard
Logitech G710+ MX Brown
Mouse
Mouse
Razer DeathAdder 2013
Mousepad
Mousepad
Razer Goliathus Speed WoT Edition
rares495 is offline
post #3 of 20 (permalink) Old 05-14-2020, 02:23 AM - Thread Starter
gderreck's Avatar
Rep: 0
Thanks for the reply rare,
I was looking at the industrial Noctua 120mm. Their static pressure is nearly double that of the Arctic fans. What I don't know, how a near doubling of the static fan pressure translates into cooler CPU temperatures. I do take your point that I will be adding noise to the equation. Perhaps not worth it as you suggest.
gderreck is offline
post #4 of 20 (permalink) Old 05-14-2020, 02:40 AM
Molitro's Avatar
Rep: 1 (Unique: 1)
There's no difficulty on changing the fans, they're pluggued to an extender, that's what goes through the sleeve to the CPU block.
But as they said, at least the 140mm fans from the 280 version, the on I have, are perfectly good fans, I run this thing at 50% at full load, running it at 100% gives me like 2º better cooling, absolute overkill.
Molitro is offline
post #5 of 20 (permalink) Old 05-14-2020, 02:51 AM - Thread Starter
gderreck's Avatar
Rep: 0
Thanks Molitro,
That's 2 votes against. Maybe better to take a pass. Molitro, in case I get a fit of stupidity, what's the process? Pull down the sleeve, disconnect the old fans and connect the new? I suppose if I have to ask, I had better leave well enough alone.
gderreck is offline
post #6 of 20 (permalink) Old 05-14-2020, 03:19 AM
Molitro's Avatar
Rep: 1 (Unique: 1)
The extender is outside, as I said, no difficulty involved at all.
Fans are screwed normally and have short cables, then the extender is routed along the fans with 2 plugs, one for each.
Molitro is offline
post #7 of 20 (permalink) Old 05-14-2020, 03:26 AM - Thread Starter
gderreck's Avatar
Rep: 0
Thanks Molitro
gderreck is offline
post #8 of 20 (permalink) Old 05-14-2020, 05:25 AM
GoldCartGamer's Avatar
Rep: 0
I believe Steve shows it in this video. I would leave them alone though.
https://youtu.be/ZQRwn-lecnk
3950x, Gigabyte X570 Xtreme, Team Dark Pro 16GB (2x8GB), MSI RTX 2080 Ti Gaming X Trio, Arctic Liquid Freezer II 360.
Build list
GoldCartGamer is offline
post #9 of 20 (permalink) Old 05-14-2020, 06:08 AM
poah's Avatar
Rep: 7 (Unique: 6)
Quote: Originally Posted by gderreck View Post
Greetings,
Graham
why would you want to change them? They are really good fans.
poah is offline
post #10 of 20 (permalink) Old 05-14-2020, 11:15 AM
eliwankenobi's Avatar
Rep: 9 (Unique: 2)
Yes the fans are good. I did change the orientation so as to set the fans as intake from the front. Pulling fresh air into the radiator.
eliwankenobi is offline
