Cooling a 3900x with a Corsair H110i GT (the CoolIt one) - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 05-14-2020, 02:47 AM - Thread Starter
SpecChum's Avatar
Rep: 61 (Unique: 31)
Considering getting a 3900x to replace my 3yo 1700, but whilst I can justify the CPU cost, having to buy a new cooler as well would probably be a deal breaker, for now.
My H110i is 3yo but still fine, my 3.8Ghz (1.275v) 1700 barely gets over 60 in IBT and Prime small FFT, so it's still working good, but is it enoguh for a 3900x, do you think?
Bit specific, I know, there's loads of different setups and use cases in here, so figured someone might be using one with a 3900x.
I do have my Vega 64 custom cooled with a G2 Slim 360mm rad, D5 and an EK block, so I do have that option to just get a CPU block, but I'd need another radiator too, as I'm not sure the 360mm G2 will be enough for both, so that'd end up being equal, if not more, than getting another AIO.
SpecChum is offline
post #2 of 5 (permalink) Old 05-14-2020, 06:17 AM
poah's Avatar
Rep: 7 (Unique: 6)
perfectly fine
poah is offline
post #3 of 5 (permalink) Old 05-14-2020, 06:37 AM
Goodbye
Penicilyn's Avatar
Rep: 981 (Unique: 763)
As I'm cooling a 3900X with a Dark Rock Slim and it only gets into the low 90s with IBT I'm sure you'll be perfectly fine.
Penicilyn is offline
post #4 of 5 (permalink) Old 05-16-2020, 03:23 AM - Thread Starter
SpecChum's Avatar
Forgot about this lol Thanks everyone
And woohoo! The 3900x arrives today.
Trying to decide if I should swap my ML140 RGB fans for the 2 x ML140 non-RGB I've got lying around - the none RGB go almost twice as fast (55.4CFM with 1.27mm-H20 vs 94CFM with 3.0mm-H20), but are also a lot louder.
I know it's subjective (noise vs cooling), but opinions? I know the Zen 2 chips like to be cooler to try to boost more, so I'm leaning toward the non-RGB.
Radiator is mounted in roof, so you can hardly see the RGB without being a contortionist anyway.
SpecChum is offline
post #5 of 5 (permalink) Old 05-16-2020, 02:55 PM - Thread Starter
SpecChum's Avatar
I'm pleased to report it's coping fine
Seems to top out about 74 to 77C, depending on what stress I'm running (tried Prime95, CB20 and Aida64 FPU), water temp goes up as expected so seems a decent mount.
Quite pleased with that, considering the stories I've seen of instant boosts to 95C on some coolers - that may have been a BIOS bug tho, apparently.
I kept the RGB fans, still undecided on that, but temps seem fine so far.
SpecChum is offline
