Restricted flow question - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 05-15-2020, 10:35 PM - Thread Starter
Rep: 16 (Unique: 13)
I'm thinking about doing this because I really like the idea and how it looks. However, will the way the water comes out of the reservoir into the T-Block restrict the flow alot or not?
MIGhunter is offline
post #2 of 8 (permalink) Old 05-17-2020, 09:55 AM
PM2843's Avatar
Rep: 1 (Unique: 1)
Typical Tee-branch fittings has about twice as much restriction as a sharp 90° elbow.
There are several equivelent length tables online like this one or this one.
and several calculators to get rough estimates on entire systems like this one.
Specific components like blocks and radiators have their own unique pressure drop profile. Manufacturers SHOULD provide them, but some don't.
PM2843 is offline
post #3 of 8 (permalink) Old 05-17-2020, 03:12 PM
broodro0ster's Avatar
Rep: 9 (Unique: 8)
I hear this a lot, but I've never seen test results. Do you have an article with measurements that proves this? I'd really like to know this.
If not I'll see if can test it with my spare loop.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #4 of 8 (permalink) Old 05-17-2020, 06:32 PM
PM2843's Avatar
Rep: 1 (Unique: 1)
From Sodiki and Adigio it looks like Roberson and Crowe in 1975 and Giles in 1977 did the original research or were the first to compile other sources of head loss through fittings. Good luck tracking down those papers though. All of it has been revised and refined in the last 45 years anyways and the tables today are taken as gospel. In practice, equivalent lengths are usually calculated at worst possible loss with an added safety factor unless other factors such as volume taken up or fitting mass are needed to be considered.
Testing fitting head loss should be doable if pressure drop or flow rate can be precisely measured using a pump with a known curve. But there are a ton of variables that could complicate matters.
PM2843 is offline
post #5 of 8 (permalink) Old 05-17-2020, 06:39 PM
Back at it again.
Avacado's Avatar
Rep: 100 (Unique: 75)
I applaud you for asking the question in lieu of hard evidence, I would love to see what you come up with.
22643 Time Spy https://www.3dmark.com/3dm/46344026?
https://folding.extremeoverclocking....e.php?u=207393
White Lightning
(12 items)
i7 9700k @ 5.1GHz 1.385v
ASUS Prime Z390-A
Evga 2080 Ti Black Gamer
32GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w
Corsair H150i Pro
CORSAIR Crystal 570X White Mid Tower
Operating System
Windows 10 Home
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #6 of 8 (permalink) Old 05-17-2020, 06:56 PM
PM2843's Avatar
Rep: 1 (Unique: 1)
Found a physical experiment that tested pressure loss in fittings. Check page 25 and 31 for elbow and tee data. Results consistent with previous data of a branch-tee having twice the loss of an elbow. Interestingly, it looks like it is the some of the first research into losses of reducing or expanding elbows and concentric reducers for 6 to 10 inch steel pipe.
PM2843 is offline
post #7 of 8 (permalink) Old 05-18-2020, 10:07 AM
treetops422's Avatar
Rep: 24 (Unique: 18)
http://martinsliquidlab.petrastech.c...Estimator.html
Martins lab has a tee in the estimator. Picture going down on a slide with a sudden 90 degree face plant turn. ^^
Sapphire Radeon RX 5700 Non XT Boost Core 2035 Gaming Ram 950 with a 20$ Chinese waterblock on the, Ryzen 3700x 4.25 ghz, 15$ Chinese waterblock, 3200 ddr3 cl16 Team T-FORCE VULCAN TUF B450m Asrock Pro 4 Mobo, 700 Watt OCZ PSU. 6 gallon res + back of a toilet tank with 240 mm radiator.
treetops422 is offline
post #8 of 8 (permalink) Old 05-18-2020, 10:20 AM
Shawnb99's Avatar
Rep: 58 (Unique: 39)
Buy some Aquacomputer pressure sensors and you can test it yourself.
Without a flow meter you’ll never know what part affects the flow either
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
