Hard Line tube OD standard changed? - Overclock.net - An Overclocking Community
post #1 of 1 (permalink) Old 05-15-2020, 11:14 PM - Thread Starter
Sykrui's Avatar
Rep: 1 (Unique: 1)
So I have not done a new systems / upgrade in more then a few years and I have come back to find that the fitting makers no longer follow standard tube OD's from what i can find. E.g they look to no longer make fittings for 1/2" 12.7mm(use to be sold as 13mm in some places) but instead 7/16" 12mm, 9/16" 14mm.
Now the issue i have here is that 7/16" 12mm and 9/16" 14mm step away from standard tube OD's used and there for i can not used standard 1/2" tube or other standard tube OD's. If I am wrong here and in fact i can use 12.7mm 1/2" OD copper tube with these 12mm 7/16" OD fittings then i will leave it at that but if this is not the case, then i feel what they have done is kind of dum and them trying to be special snowflakes for no reason imo.
Thank you in advance for any information regarding this.
Sykrui is offline
