How do you manage summer temps? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 35 (permalink) Old 05-16-2020, 06:19 AM - Thread Starter
Astral85's Avatar
Rep: 4 (Unique: 4)
Quote: Originally Posted by Avacado View Post
I don't really see a way to make any substantial modifications to a setup to reduce loop temp. Ambient is king, you don't control that no matter what season, you control nothing. You could add a chiller, which would add more heat to your room anyway, you could increase fan speed, but that wouldn't matter in the end if the ambient is warm. AC is your only option. You could remove filters and panels to ease air flow restriction which would help, but ultimately a summer without AC is just hot.
OK I might of got this thread title a little wrong. I do have AC and use it in the summer but on the really hot days even the AC can struggle... I think what I am wanting to know is how can I reduce my loop temps further, summer or winter.
I think Thrash has already answered this with his Mora 360. He says a 4C loop and component reduction with the Mora 360. That's pretty substantial...
I think the thread was supposed to be more aimed at peoples setups and what sort of temps your getting... Whether rads as intake/exhaust or more rads matter/make a difference. I've recently had my 2080 Ti FTW3 replaced and have learnt chip quality does not just affect the what clock speeds you get. My old GPU ran at a constant 50C sometimes creeping 53-55C last summer. My new GPU runs at 40-46C and occasionally peaks at 48C. This is under the same loop temps...
As mentioned I could reduce the GPU power limit or cap the FPS to possibly reduce the temps. That's quite relevant because I notice GPU temps respond directly to power consumption and not voltage or clock speed... Ultimately I'm wondering how possible it is to reduce the GPU and coolant temps another 2-4C with further cooling capacity/configuration....
Asus Maximus XI Hero, 8700K 5.0Ghz, Custom loop: EKWB Velocity, X-RES D5, Rads: EK PE 360, Corsair XR5 280, EVGA RTX 2080 Ti FTW3 Ultra/EK Vector FTW3, Corsair Dominator Platinum RGB 32GB 3733Mhz, Samsung 850/860 Evo's, Seasonic Prime Ultra 1300W, Phanteks Eclipse P600S, Asus ROG Swift PG349Q 120hz 34"
Astral85's RIG
(0 items)
Astral85 is offline
post #12 of 35 (permalink) Old 05-16-2020, 06:37 AM
Overclocker in training
ThrashZone's Avatar
Rep: 170 (Unique: 103)
Hi,
Think my water idle temps were unusual too at 32c when room ambient was always 25.5c or 78f degrees.
Now water is only 1-3c over and has not gone to 29c yet
So I would really think existing rads before the mora aren't all that efficient matter of fact pisspoor would be a better description of 2-280gtx and 2-240gtx or older 2-280CE all are the same crappy performance
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
10900k
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
Operating System
ThrashZone is offline
post #13 of 35 (permalink) Old 05-16-2020, 07:51 AM
Rep: 1 (Unique: 1)
My office is south facing in the Denver elevation so even in winter it gets warm with the sun baking down on it, I have to crack the window to keep it cool, during summer the ac doesn't work the best in here so I just got a fan duct cover with fans, turns out they are just 2 pc fans, and not even high flow and very ******* noisy so I will be modding that with some high flow fans I have if I'm going to suffer with noise for more air, maybe add some rgb fans for more air flow
Ryzen Thredripper 3970x
Asus ROG Zenith ii Extreme Alpha
EVGA Geforece RTX 2080 Super Black Gaming Edition
Corsair Vengence
Samsung 970 Evo m2
Inland sata 3 ssd
Corsair HX850i Platinum
White Corsair 680x
Operating System
Windows 10 Enterprise Edition
Samsung 32" 4k
AOC 32" 1440p
farpetrad is offline
post #14 of 35 (permalink) Old 05-16-2020, 03:04 PM
bluechris's Avatar
Rep: 2 (Unique: 2)
In Greece it's the 3nd day that we reach 39c (102f i think) and its only may. This time of year we suppose to have max 30c but a heat came from Africa.
I have build the Homelab server in my sig and i haven't opened ac yet because it holds.
The problem in it is that there are 4 x sas 4tb Seagate disks that with normal weather were reaching 45 degrees. When i saw that i didn't know what to do at first and i was thinking the Greek summer, so i did this. I bought 2 x 120mm noctuas 3000rpm that i put them in push/pull in the disks.
The fans at high rpms make noise but i manage to set their max speed at 2300rpm so the noise is acceptable and have them at 44c with 38-39c ambient.
I watch it closely but i find it stupid to open the ac for it.
Ryzen 3600
Gigabyte Aorus Pro
Nvidia GT710 Pci X1
Trident Z DDR4-3200MHz CL14-14-14-34 1.35V 64GB (4x16GB)
HGST Ultrastar 7K4000 4TB 7200 RPM 512n SAS 6Gb/s 3.5-Inch 64MB HDD Enterprise Hard Drive HUS724040ALS640
Samsung 860 Evo 1TB
ADATA XPG SX8200 PRO 256GB M.2 2280
Corsair HX750i High-Performance ATX Power Supply — 750 Watt 80 Plus® PLATINUM Certified PSU
Noctua NH-D15 chromax black
Noctua NF-F12 PWM
NOCTUA NF-A8 FLX FAN 80MM
Corsair Carbide Air 740
Operating System
VMware ESXi 6.7 Update 3
Other
Asus HYPER M.2 X16 CARD V2
Other
HPE Smart Array P440/4GB FBWC 12Gb 1-port Int SAS Controller
bluechris is offline
post #15 of 35 (permalink) Old 05-17-2020, 04:42 AM
Back at it again.
Avacado's Avatar
Rep: 100 (Unique: 75)
Sure, you can add an external radiator, but again it can't cool past ambient, so if your "AC struggles" in the summer, it wont matter how many rads you have. Also the Mora is a 300$ part not including fan costs. If money is not an issue and you don't mind having external cooling components, then you should go for it. 300$ might be better spent adding Freon/servicing your AC rather than adding more radiators. To reduce your temps in winter, just open your windows, lol
22643 Time Spy https://www.3dmark.com/3dm/46344026?
https://folding.extremeoverclocking....e.php?u=207393
White Lightning
(12 items)
i7 9700k @ 5.1GHz 1.385v
ASUS Prime Z390-A
Evga 2080 Ti Black Gamer
32GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w
Corsair H150i Pro
CORSAIR Crystal 570X White Mid Tower
Operating System
Windows 10 Home
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #16 of 35 (permalink) Old 05-17-2020, 06:11 AM
Food Editor
skupples's Avatar
Rep: 720 (Unique: 378)
by being hot as balls all summer. (remember, water cooling = better heat transfer = now your room is hotter instead of your computer!)
this summer, i'm upgrading the fuse box to handle me installing a window AC in my office.
Not playing the sticking to the chair game this year boys. Too damn old.
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #17 of 35 (permalink) Old 05-17-2020, 06:13 AM
ThrashZone's Avatar
Hi,
I suppose if you get all the mora 360 assessors it might get a little expensive but a 360LT is 160.us 420LT 280.us without them and is all I bought
Made my own stand system and had just enough fans for one side one the first mora I got just put the second mora 360's in front of each other and still the second mora with no fans is sitting there with water temp as 26.1c
Don't have kids/ cat or dog so no grills needed intake filtered with a box fan behind it for the go time
So you can do it on the cheap
Think 10 pairs of QDC's= quick disconnects were the biggest expense
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
10900k
EVGA 1000P2
Corsair 450D
Operating System
post #18 of 35 (permalink) Old 05-17-2020, 07:01 AM
elucid087's Avatar
Rep: 9 (Unique: 7)
Ditch the leather chair for mesh. Get an Aeron when they go on sale and you'll be set for life.
"Atheism never killed anyone" - Bill Maher
elucid087 is offline
post #19 of 35 (permalink) Old 05-17-2020, 07:29 AM
Imprezzion's Avatar
Rep: 106 (Unique: 93)
We got those in the office.. man they are so good..
I also played the stick to the AK Racing chair game until I bought myself a powerful A/C unit last year.
I'm in Holland so no 40c's here but still, summer can see long stretches of 30c+ days and my house is angled completely wrong so the sun burns down on my side of the roof from 9 AM to 3 PM so it heats up super fast in the morning. Plus, 120 year old house, terribad isolation on the roof.. literally styrofoam blocks glued to the roof with a drywall sheet over them. Really have to improve that as the wall literally feels warm in the summer lol. Ambients before AC in my gaming room would easily go over 40c with the PC running. Hell, i've seen 44c ambients just playing minecraft on a 36c sunny day.
But, I got myself a office size rolling A/C (like, 3360w / 10k BTU) with it's own 16A 240VAC group and power socket and it keeps my upstairs around 21-24c with 33-36c ambients outside. And that is with my PC running full blast at like, 500-700w of heat output from 2 seperate watercoolers. I do have to keep the A/C running ocnstantly on a thermostat because of the bad isolation of the upstairs floor. It keeps leaking in SO much heat I have to keep it running so my power bill is through the roof but yeah.. i don't care lol.
It's not like my garage equipment doesn't consume massive amounts of power lol. (Quickjacks, drill press, grinding wheels, belt sander, chopsaw, 3000w air compressor, several 240VAC/400VAC welders and so on).
Cars:
-Crashed: (not my fault ) '94 Nissan 100NX GA16DE (a.k.a. NX1600). Renault Laguna Phase I facelift '99 1.6 K4M. (Broke a strut and smacked a tree).
-Sold: '00 Nissan Primera P11-144 QG18DE, '97 Honda Prelude F20A4, 03 Ignis Sport.
-Current daily: '07 Ford Focus 1.6 Futura.
-Current funcars: '03 Peugeot 206CC 2.0 RFN fully riced and tuned (Turbo coming soon)
Looking for: Gen 4 or 5 Honda Prelude, >92 Toyota Celica or >90 MR2.
Full-On Rainbowbarf
(16 items)
P45 power!
(9 items)
i9 9900K @ 5.1Ghz 1.248v (VR VOut)
MSI MEG Z390 ACE
RTX 2080 Ti Phoenix GS + G12 & Kraken X52 @ 2130/8100 1.093v (EVGA FTW3 BIOS)
Corsair Vengeance RGB B-Die @ 4200 16-17-17-34-320-2T 1.54v
Samsung 850 EVO 500GB x2
Samsung 970 Evo 1TB
Seasonic Prime Ultra Gold 1000w
EK MLC-Phoenix 280 Kit
Phanteks Enthoo Evolv X
Operating System
Windows 10 Pro X64
Samsung S27B350H @ 1080p 75Hz OC
Iiyama GB2788HS @ 144Hz
Keyboard
Logitech G710+
Mouse
Trust GXT31
Mousepad
Corsair MM300 Large
Audio
Steelseries Siberia V2
Intel Core 2 Quad Q6600 G0 @ 3Ghz (333x9)
MSI P45 Neo2-FR
MSI GTX760 Gaming X
6GB completely random 1 and 2GB sticks. All 4 different ones.
A-Data 120GB SSD
AOpen 350w
Some huge aluminum Xeon heatsink
Cartboard box.
Operating System
W10 Pro x64
Intel Xeon E3-1270v1 @ 3.8Ghz
ASUS P8H61-i R2.0
Sapphire R9 280X Vapor-X @ 1230Mhz core.
16GB Kingston HyperX Savage 2400CL11 @ 1333CL6
Kingston 240GB SSD
Corsair CX600
Corsair H110i GTX
Custom open test bench made from a cut-up CM690 v1
Operating System
W10 Pro X64
Samsung 23" cheap thing
Keyboard
Cheapest one Aldi had
Mouse
Mousepad
The desk...
Imprezzion is offline
post #20 of 35 (permalink) Old 05-17-2020, 03:19 PM
broodro0ster's Avatar
Rep: 9 (Unique: 8)
Nothing. If my GPU works fine at 38°C during the winter, it also works fine at 43°C in summer. Same for my CPU.
That 5-8°C increase in temps shouldn't matter. If that throws of your stability, then you have other problems.
During winter, my ambient around my computer is always 2-3°C higher than roomtemp, because hot exhaust air stays around the case. If I open a window in summer or put a fan on, that hot air can't circulate around the case anymore and my intake temps drop by 2-3°C. So that might helps if you don't have an AC that regulates air circulation in your room.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
