How do you manage summer temps? - Page 4 - Overclock.net - An Overclocking Community
post #31 of 35 (permalink) Old 05-20-2020, 03:44 AM - Thread Starter
Astral85's Avatar
Rep: 4 (Unique: 4)
Quote: Originally Posted by broodro0ster View Post
Voltage matters because power = voltage*amps.
Resistance is calculated by voltage/amps. So if the voltage goes up, the amperes go up and the total power consumption goes up.
A card sitting at 40% load will always be a few degrees cooler than a card sitting at 100% because the amp draw is lower which means a lower total power draw.
But if you compare a GPU loaded at 100% that runs are 900mV and then at 1093mV, the setting at 900mV will always be cooler under the same scenario.
To lower GPU usage, you could setup a frame limiter. This will also result in lower temps. That in combination with undervolting, can gain you at least 5°C temp wise (but at the cost of a lower frame rate)
I ran the GPU at stock power limit and voltage and there is definitely a 3-4 maybe 5C reduction in temps of the GPU. Power consumption in watts was obviously lower than usual. Funny thing is I can still play Division 2 locked at 85 FPS on my ultrawide monitor without the extra power. I will have to test with other games but this does go to show what a power house the 2080 Ti is even without overclocking it.
Asus Maximus XI Hero, 8700K 5.0Ghz, Custom loop: EKWB Velocity, X-RES D5, Rads: EK PE 360, Corsair XR5 280, EVGA RTX 2080 Ti FTW3 Ultra/EK Vector FTW3, Corsair Dominator Platinum RGB 32GB 3733Mhz, Samsung 850/860 Evo's, Seasonic Prime Ultra 1300W, Phanteks Eclipse P600S, Asus ROG Swift PG349Q 120hz 34"
Astral85's RIG
(0 items)
Astral85 is offline
post #32 of 35 (permalink) Old 05-20-2020, 07:06 PM
Skylinestar's Avatar
Rep: 3 (Unique: 3)
Nothing. I live it hot area. 95F with 70% humidity, day and night, everyday. Sometimes I switch on the AC, but I'll just bear with the heat most of the times.
Main Rig
(19 items)
Intel Core i5 6500 @ 4256MHz
ASRock Fatal1ty Z170 Gaming K6
Palit JetStream GTX1070
Corsair Vengeance LPX 2666 DDR4 2x4GB
Crucial M4 128GB SSD
Kingston UV400 480GB SSD
WD Blue 500GB HDD
Optical Drive
LiteOn DVD-RW
Corsair GS700
Noctua NH-U14S
Phanteks PH-F140SP case fan
Noctua NF-P14s Redux 1200 case fan
Fractal Define R5
Operating System
Win10 Education Edition 64-bit
Dell S2716DG
Keyboard
Microsoft Internet Keyboard
Mouse
SteelSeries Rival 100
Mouse
SteelSeries QcK mini
Audio
HiVi Swan M50W
Skylinestar is offline
post #33 of 35 (permalink) Old 05-24-2020, 07:42 AM
TiffTaffer's Avatar
Rep: 0
Afraid air conditioning is the only real answer.
I have central AC rather than a window unit. If I leave my room door closed, the heat just rises and rises. In the summer I've pretty much adapted to my room being 80-84F most of the time. The AC is set to 75F, but the heat isn't in the hallway to trigger the thermostat, it's in my room. When I get desperate, I put a box fan in my doorway to blow the cool hallway air into my room, it works. Otherwise leave the door open with a ceiling fan on to move that hot air out of the room and hopefully trigger the thermostat. Turning on the central fan without the ac can help with that too I guess, but I never really do that.
I don't believe in turning the thermostat down further.
Ideally, I'd just get a window ac for the room where it really matters, but I just haven't been bothered enough to do that. I would suggest a window ac for the hot room if you are really bothered, and leave the central ac off.
TiffTaffer is offline
post #34 of 35 (permalink) Old 05-24-2020, 08:29 AM
Goodbye
Penicilyn's Avatar
Rep: 981 (Unique: 763)
Just run Zen 2. It doesn't overclock anyways.
Penicilyn is offline
post #35 of 35 (permalink) Old 05-24-2020, 01:28 PM
bluechris's Avatar
Rep: 2 (Unique: 2)
I was in the same situation in my old room when i was younger with my parents.
What i did is that i bought a fun to take out the hot air (and my smoke also) out of the room to outside. That fun was in a wall that i drilled a hole if i remember right 20x20cm and took out everything outside.
It was an exhaust room fan, not a simple fan and inside the room had automatic grills that were open when you opened it.
It was something like that
https://www.amazon.com/SAILFLO-Direc...5&s=hi&sr=1-36
And i had put it high in the wall and that thing did tremendous work.
Ryzen 3600
Gigabyte Aorus Pro
Nvidia GT710 Pci X1
Trident Z DDR4-3200MHz CL14-14-14-34 1.35V 64GB (4x16GB)
HGST Ultrastar 7K4000 4TB 7200 RPM 512n SAS 6Gb/s 3.5-Inch 64MB HDD Enterprise Hard Drive HUS724040ALS640
Samsung 860 Evo 1TB
ADATA XPG SX8200 PRO 256GB M.2 2280
Corsair HX750i High-Performance ATX Power Supply — 750 Watt 80 Plus® PLATINUM Certified PSU
Noctua NH-D15 chromax black
Noctua NF-F12 PWM
NOCTUA NF-A8 FLX FAN 80MM
Corsair Carbide Air 740
Operating System
VMware ESXi 6.7 Update 3
Other
Asus HYPER M.2 X16 CARD V2
Other
HPE Smart Array P440/4GB FBWC 12Gb 1-port Int SAS Controller
bluechris is offline
