Best case for triple 360mm rad or bigger? 2020 - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 05-16-2020, 08:42 PM - Thread Starter
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
TK421's Avatar
Rep: 164 (Unique: 128)
Any thoughts on what case would be the easiest to build a 3x360mm rad in, possibly bigger rads in?
So far the candidates are the O11XL and Phanteks 719
So far here are the problems I've seen
O11XL
- max is 3x360, not bigger
- hdd cage is not ventilated, possibly bad temp issues?
- 2 pieces of glass: hard to keep clean and shatter possibility
Phanteks 719
- Using 3 rads on [top,side,front] is a challenge in terms of space
- If bottom rad is used, it blocks the use of 3.5" hdd cages
Radiator: HWL 360 GTX (54mm), XSPC 360 EX (35mm) + TX (21mm)
Fans: Gentle Typhoon 2150 (25mm)
nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴ
PC 1
(6 items)
Ryzen 9 3950X 1900FCLK
Crosshair VIII Hero Wi-Fi
B-die 2x16 3800MHz F4-3600C16D-32GTZN
Samsung 960 Pro 512GB
EVGA 750G2
Swiftech H360X3
TK421 is online now
post #2 of 15 (permalink) Old 05-16-2020, 08:51 PM
Section31's Avatar
Rep: 18 (Unique: 14)
O11XL
Phanteks 719
Not consider going external radiator route?
Section31 is offline
post #3 of 15 (permalink) Old 05-16-2020, 10:22 PM
Village Idiot
pewpewlazer's Avatar
Rep: 112 (Unique: 101)
Phanteks 719 is incredibly restrictive in what you can fit in it. Hard pass as far as I'm concerned.
If you want to run 120mm rads, the O11D XL is pretty much a no brainer.
Beyond that, I have no idea. The Define 7 XL can fit 2x 420s, but I'm not quite satisfied with it. Starting to come to the realization that the MO-RA3 is my only option... if it were ever to be in stock...
Derptron 9000
(11 items)
Intel i7 5820k @ 4.5ghz
ASRock X99 Extreme4/3.1
RTX 2080 Ti @ 2100/7950
16GB DDR2400 12-12-12-36
Samsung 970 EVO 1TB
EVGA Supernova 1600 T2
Walmart Great Value Distilled Water
Fractal R6 Blackout TG
LG 32GK850G + LG 32UD59
Audio
Schiit Yggy & Ragnarok -> HD800S
Other
Intel X520-DA1
pewpewlazer is offline
post #4 of 15 (permalink) Old 05-16-2020, 10:45 PM
ASUSfreak's Avatar
Rep: 135 (Unique: 106)
Mine case is big, can hold 420 they say.
Might wanna check it out...
https://www.bequiet.com/en/case/1473
ASUS Hero XI + Intel i9 9900K + ASUS Ryujin 360 + Corsair 32GB 3200MHz + ASUS 2080Ti + Samsung 970 nvme 500GB + 3x Crucial MX500 2TB (For Games Only ) + ASUS Thor 1200W + Be Quiet! Dark Base Pro 900 v2 + ASUS XG35VQ + ISP 1Gb down/40Mb up
ASUSfreak is offline
post #5 of 15 (permalink) Old 05-16-2020, 10:53 PM
Rep: 961 (Unique: 706)
x71 can hold a 420 in front and maybe a 480 if you dont need your bays for dvdroms etc, Without any mods you can get a 360 in top 420 in front and a 240 on bottom side. If you don't mind doing a little modding you can get a 420 in front 360 in top and a 360 in bottom.
Midnight Madness
(17 items)
AMD RYZEN 9 3900X
ASUS AMD AM4 ROG Strix X570-E
EVGA GTX 1080 FTW Hydro Copper
G.SKILL TridentZ Series
Samsung EVO 850 500
SeaSonic M12D SS-850 850W
EK-SBAY Dual DDC 3.2 PWM Serial
Alphacool NexXxoS ST30 Full Copper Radiator 360
Hardware Labs Black Ice SR2 Multiport Black Carbon Radiator - 360mm
EKWB EK-Velocity Strike CPU
EK-CoolStream RAD XTC 420
Thermaltake core x71
Operating System
Windows 10 Pro
ASUS VW246H Black 24" 2ms
Keyboard
Rosewill NEON K75 V2 BR
Mouse
CM Storm Sentinel Advance II
Audio
Corsair Void
Bal3Wolf is offline
post #6 of 15 (permalink) Old 05-16-2020, 10:55 PM
Section31's Avatar
Have you looked at dazmode. He has stock. I ended up getting one from heatkiller germany store. It was significant cheaper than dazmode.
post #7 of 15 (permalink) Old 05-16-2020, 11:11 PM
sultanofswing's Avatar
Rep: 5 (Unique: 5)
0-11XL is extremely popular for a reason. Can fit 3 360 without any issues.
It can also fit 2 420's as well.
I ran 3 360's plus 3 D5 pumps in series in my 0-11XL without any issue and still had room to spare as I removed all the rear HDD cages/sleds.
[email protected] GHz - 0 AVX @ 1.300v w/ Heatkiller Block + Delid | EVGA X299 Dark | Kingpin 2080ti with Bykski Block 2280mhz on water. | 3 XSPC 360's and 1 XSPC 480 | 32gb Corsair [email protected] | 1TB NVME/1TB Sata SSD | Seasonic Prime Platinum 1200 | Phanteks Enthoo Elite | Viewsonic XG-2703-GS | Windows 10-says pro but seems like an amateur
sultanofswing is offline
post #8 of 15 (permalink) Old 05-16-2020, 11:21 PM - Thread Starter
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
TK421's Avatar
How would I even do that?
Airflow doesn't seem to be too great with this case
I'll have to look into how people are configuring it for watercool.
I already have the mentioned rads, except the HWL 360GTX.
Also I'm not interested in modding the case :|
PC 1
(6 items)
EVGA 750G2
Swiftech H360X3
TK421 is online now
post #9 of 15 (permalink) Old 05-16-2020, 11:32 PM
TeslaHUN's Avatar
Rep: 23 (Unique: 21)
Thermaltake Core X9
Thermaltake W100 / W200
Thermaltake Core X71 (TG)
Corsair 1000D
TeslaHUN is offline
post #10 of 15 (permalink) Old 05-16-2020, 11:37 PM
Pepillo's Avatar
Rep: 4 (Unique: 4)
+1
One thing I liked about this case is that it doesn't look so big to support three triple radiators, but it does so with ease. As for the temperature of the hard drives, if you are going to put mechanics you can interspers between the two cage some small fan, I have done it. If they're SSDs, you don't need it.
Lian Li O11 Dynamic XL + EK O11D Distro-Plate G1 DDC 3.2 + 2 x 360 EK PE Rads - Aorus RTX 2080 TI Fullcover [email protected]/15000 - EVGA Supernova 1600 - Corsair K95 + Dark Core SE/MM1000 - X27P 4K HDR1000 Gsync 144 Hz - Lenovo Explorer
Asus Prime X299 Deluxe - i9 [email protected]/3.2 Delid - 4x8 G.SKILL RipjawsV [email protected] C17 1T - Intel Optane 900P NVME - Crucial MX300 2TB - Samsung EVO 860 4TB + Optane 32GB - 2X2TB WD Raid - DAC Teac UD H01 + AKG K612 Pro + 2.1 Studio
Pepillo is offline
