Least Expensive watercooled GPU? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 15 (permalink) Old 05-20-2020, 03:30 PM
Steven Stacy's Avatar
Rep: 1 (Unique: 1)
Quote: Originally Posted by Kevin Costello View Post
I'm like that with my reef tank...
I had 90 gallon saltwater tank. I just couldn't keep reefs. I just couldn't get the right lighting and nitrate down. I tried coil denitrator and denitrate reactors. I cant remember the plant name, but I bought a vine that feed on nitrates. Maybe I had to much water flow or whatever. My wife finally had enough and I had to dismantle it. Totally get that.
Steven Stacy is offline
post #12 of 15 (permalink) Old 05-20-2020, 04:45 PM
Cobra26's Avatar
Rep: 8 (Unique: 6)
If you planning to use a beefy GPU then water cooling will prolong its lifespan since the temps stay at around 35 to 45c while gaming and you dont like getting a gpu every 2 years or so, plus if you want a little bit extra juice with overclock (not sure if many OC a gpu but the option is there). And of course for the silence.
Cobra26 is offline
post #13 of 15 (permalink) Old 05-27-2020, 11:22 AM
outofmyheadyo's Avatar
Rep: 55 (Unique: 51)
Quote: Originally Posted by pewpewlazer View Post
This. Call me crazy but if I had to pick between going to a 2080 Super (on water) or going back to my stock 2080 Ti air cooler... I'd probably be downgrading my GPU. All higher end (like 2060 and up performance) GPUs sound like miniature vacuum cleaners inside your computer.
You obviously havent tried slapping 2x 10$ 120mm fans on ur random aftermarket GPU with zipties, RTX 2080 is inaudible under full load 50cm away in an open case, temps suck if u run ur fans very slow but perf is as good as with the screaming fans.
outofmyheadyo is offline
post #14 of 15 (permalink) Old 05-27-2020, 11:33 AM
Overclocker
JackCY's Avatar
Rep: 358 (Unique: 255)
Radiators usually need fans too so the fans are loud on air coolers applies the same way to water cooling.
Decent air cooler GPUs don't even run high speed fans, 100mm fans at max 1500rpm are not loud. But yes there are aftermarket models that run screamer fans to compensate for bad die contact and heatpipe design, or too small fin stack. It's cheaper to run fans faster than to design a good air cooler. Almost all series have at least a couple models with a decent cooler, these aren't necessarily the most expensive models either.
JackCY is offline
post #15 of 15 (permalink) Old 05-27-2020, 01:22 PM
I can count to potato
Fluxmaven's Avatar
Rep: 52 (Unique: 21)
If you want to add a water cooled GPU, I would pick up a used GPU with a block already on it. Waterblocks are expensive to buy new, but don't really add much value on second hand cards.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
64GB TridentZ 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is online now
