algae? - Overclock.net - An Overclocking Community
algae?
post #1 of 55 (permalink) Old 05-24-2020, 03:19 PM - Thread Starter
lololol
qsxcv's Avatar
Rep: 373 (Unique: 154)
algae?
new build, only about a month old.
coolant is distilled water, about 1L, and 4 drops pt nuke phn (benzalkonium chloride).
i'm seeing some green stuff in my blocks, quite a bit actually near the bottom of the cpu block. how can this be after only 1 month?
well i'll need to drain the loop and scrub everything? maybe i'll dump in a lot more pt nuke phn first.
too busy to check forums as regularly
pm me if i forget to respond
7980xe
4770k
(16 items)
7980xe direct die @ 4.4/4.2/4.2 GHz, 1.135V
x299 aorus master
strix 5700 xt oc
4x32gb crucial ballistix 3200cl16
wd black sn750 1tb
seasonic snowsilent 1050
3x nemesis gts 360mm, fans: gt 1850rpm
lian li o11 dynamic
Operating System
win10
viewsonic xg2703-gs
Keyboard
logitech g410
Mouse
logitech g pro wireless
Mousepad
supermat
4770k @ 4.6GHz
maximus vii impact
nvidia gtx 970
crucial ballistix tactical 16gb
crucial mx100
silverstone sx500-lg, fan removed
nxzt x53
ncase m1 v3
Operating System
gentoo
Operating System
win 7 ultimate
sony gdm-fw900
Keyboard
kbp v80 matias quiet
Mouse
logitech g pro (3366)
Mousepad
allsop raindrop xl
Audio
chord mojo
Audio
sennheiser hd800
qsxcv is offline
post #2 of 55 (permalink) Old 05-24-2020, 03:21 PM
Back at it again.
Avacado's Avatar
Rep: 105 (Unique: 79)
Yea, that looks like algae. Consider Mayhems biocide and inhibitor. Definitely scrub the **** out of that loop and use high temperature water.
23652 Time Spy https://www.3dmark.com/3dm/47932151?
[email protected] Stats https://folding.extremeoverclocking....e.php?u=207393
i9 9900k @5.1GHz 1.34v
ASUS Prime Z390-A 1504 BIOS
Evga 2080 Ti Black Gamer +220 Core
Evga 2080 Ti Black Gamer +150 Core
4x8GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w G+
EK CPU/GPU/RES
2x aCool UT60 RADs
Lian Li O11 Dynamic XL (White)
Operating System
Windows 10
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #3 of 55 (permalink) Old 05-24-2020, 03:35 PM - Thread Starter
lololol
qsxcv's Avatar
argh... yea i'll try mayhem's next.
minimizing additional growth might be good enough for me as a temporary measure. i just added 12 more drops of phn. maybe if i let the loop get really hot (60-70C) that can sterilize things.
7980xe
4770k
(16 items)
x299 aorus master
strix 5700 xt oc
wd black sn750 1tb
lian li o11 dynamic
Operating System
win10
viewsonic xg2703-gs
Keyboard
logitech g410
Mouse
Mousepad
supermat
4770k @ 4.6GHz
maximus vii impact
nvidia gtx 970
crucial mx100
nxzt x53
ncase m1 v3
Operating System
gentoo
Operating System
win 7 ultimate
sony gdm-fw900
Keyboard
Mouse
Mousepad
allsop raindrop xl
Audio
chord mojo
Audio
sennheiser hd800
qsxcv is offline
post #4 of 55 (permalink) Old 05-24-2020, 03:46 PM
Watercooler
Socks keep you warm's Avatar
Rep: 145 (Unique: 124)
Pretty weird to have growth that quick.
What are you using coolant wise? Have you got biocide or a killcoil?
I have been using distilled water and kill coil for last 8 years and no corrosion.
I like to have fun.
https://stats.foldingathome.org/donor/110855
https://www.trueachievements.com/gamer/II+TH3PRO+II
16 Threads is Good
(10 items)
Intel Core I9 9900K 4.8Ghz
Gigabyte Aorus Elite
Aorus 2080Ti Xtreme Waterforce WB 11GB
Trident Z
Samsung 250 SSD
Cooler Master Silent Pro Hybrid
Watercooling Custom
900D
Operating System
Windows 10 x64
28" ACER 4K Monitor
Socks keep you warm is offline
post #5 of 55 (permalink) Old 05-24-2020, 04:11 PM
Robotic Chemist
Asmodian's Avatar
Rep: 202 (Unique: 134)
I had a bad experiance with algae once a long time ago, due to over diluting the coolant.
It can VERY quickly clog the loop for very bad consequences. I suggest dealing with it right away.
"Soldering resistors onto your video card to bypass the manufacturers over current protection kind-of sort-of absolute-definitely voids your warranty"
Desktop
(17 items)
AMD Ryzen 3950X
Asus Crosshair VIII Hero
Nvidia 2080 Ti
32GB DDR4 3600
Intel 900P
Samsung 960 Pro
Optical Drive
Asus BW-16D1HT
Seasonic 1200W
EK Velocity + EK GPU Block
Old Marble Slab
Operating System
Windows 10 Pro
LG C9 55"
Keyboard
Wooting two
Mouse
Logitech G903 Lightspeed
Mousepad
Logitech G PowerPlay
Audio
Arctis Pro Wireless
Other
Mellanox 40GbE
Asmodian is offline
post #6 of 55 (permalink) Old 05-25-2020, 10:30 AM - Thread Starter
lololol
qsxcv's Avatar
i know i should but i'm feeling hesitant to take apart the loop because some of the fittings are quite tight and difficult to reach.
yesterday i ran p95 and furmark simultaneously, turned down the fans, and got the water temp up to 60C for about an hour. maybe that sterilizes things . also added a lot more PHN. i'll monitor it for maybe another week and see what happens. if it doesn't get worse, i might just leave it as is and clean it in the future when i change or upgrade parts
7980xe
4770k
(16 items)
x299 aorus master
strix 5700 xt oc
wd black sn750 1tb
lian li o11 dynamic
Operating System
win10
viewsonic xg2703-gs
Keyboard
logitech g410
Mouse
Mousepad
supermat
4770k @ 4.6GHz
maximus vii impact
nvidia gtx 970
crucial mx100
nxzt x53
ncase m1 v3
Operating System
gentoo
Operating System
win 7 ultimate
sony gdm-fw900
Keyboard
Mouse
Mousepad
allsop raindrop xl
Audio
chord mojo
Audio
sennheiser hd800
qsxcv is offline
post #7 of 55 (permalink) Old 05-25-2020, 12:34 PM
Working as Intended
Filters83's Avatar
Rep: 1 (Unique: 1)
It can VERY quickly clog the loop for very bad consequences. I suggest dealing with it right away. [IMG class=inlineimg]/forum/images/smilies/frown.gif[/IMG]
yesterday i ran p95 and furmark simultaneously, turned down the fans, and got the water temp up to 60C for about an hour. maybe that sterilizes things [IMG class=inlineimg]/forum/images/smilies/tongue.gif[/IMG]. also added a lot more PHN. i'll monitor it for maybe another week and see what happens. if it doesn't get worse, i might just leave it as is and clean it in the future when i change or upgrade parts
You know most watercool component start degrading around 60c water temperature ? Apparently not
Demount all clean and use a premix liquid before doing more damage
My 2 cent
Filters83 is offline
post #8 of 55 (permalink) Old 05-25-2020, 12:38 PM
Rep: 963 (Unique: 708)
My 2 cent
yea 50-60c is top end side of almost all res and water blocks can cause cracks doing that and have a dead computer from leaks all over everything.
Midnight Madness
(17 items)
AMD RYZEN 9 3900X
ASUS AMD AM4 ROG Strix X570-E
EVGA GTX 1080 FTW Hydro Copper
G.SKILL TridentZ Series
Samsung EVO 850 500
SeaSonic M12D SS-850 850W
EK-SBAY Dual DDC 3.2 PWM Serial
Alphacool NexXxoS ST30 Full Copper Radiator 360
Hardware Labs Black Ice SR2 Multiport Black Carbon Radiator - 360mm
EKWB EK-Velocity Strike CPU
EK-CoolStream RAD XTC 420
Thermaltake core x71
Operating System
Windows 10 Pro
ASUS VW246H Black 24" 2ms
Keyboard
Rosewill NEON K75 V2 BR
Mouse
CM Storm Sentinel Advance II
Audio
Corsair Void
Bal3Wolf is offline
post #9 of 55 (permalink) Old 05-25-2020, 01:04 PM
H₂O Aficionado
Slaughtahouse's Avatar
Rep: 119 (Unique: 96)
I agree. Just because it is small and green isn't conclusive that it is algae. Distilled water user here too.
Possibly, it could be junk from your radiator. They are quite difficult to clean 100% due to the nature of the construction. That being said, I've only had "black" junk from my radiators. Never green.
-=]░▒▓███ [Official] NVIDIA GTX 780 Owner's Club ███▓▒░[=-
Stridsfordon 90
(20 items)
M1 Abrams
(18 items)
Asus G53
(0 items)
Intel 3930K
Asus Sabertooth X79
GTX 780 SC
Patriot Black Viper
Samsung 840 SSD
WD Black 7200 RPM
Corsair AX 850
XSPC EX 360 Radiator
XSPC Raystorm CPU Block
XSPC Titan/780 GPU Block
EK-XRES 100 Revo D5 - Acetal
XSPC D5 Pump
Fractal Design Meshify C
Operating System
Windows 10
QNIX 27"
Keyboard
Logitech G710+
Mouse
Razer Death Adder 2013
Mousepad
Mouse Rug
Audio
Sennheiser HD 6XX
Audio
Bose Companion III's
i7 3930K
Asus Sabertooth X79
Geforce GTX 780 EVGA SC 3GB + XSPC Waterblock
Patriot Viper 3 16GB (4 x 4GB) DDR3 2133
SAMSUNG 840 Series 250GB
Corsair AX850
XIGMATEK Dark Knight II Night Hawk Edition
XSPC 360mm radiator, Raystorm CPU block, D5 pump
Corsair Vengeance Series C70 Military Green (Custom paint)
Operating System
Windows 10
QNIX QX2710 27" 100hz
Samsung 2233RZ 22" 120hz
Keyboard
Logitech g710+
Mouse
Razer DeathAdder 3.5G
Mouse
Mouse Rug
Audio
Bose Companion III's Speakers
Audio
Sennheiser HD 558 Headphones
Audio
Sennheiser HD 6XX Headphones
Slaughtahouse is offline
post #10 of 55 (permalink) Old 05-25-2020, 01:16 PM
i wonder if his ptnuke could be reacting to something in his loop instead of it being alge
Midnight Madness
(17 items)
AMD RYZEN 9 3900X
Samsung EVO 850 500
Operating System
Windows 10 Pro
Keyboard
Mouse
Audio
Corsair Void
Bal3Wolf is offline
