D5 vs DDC vs EK VTX? - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 05-26-2020, 01:35 AM - Thread Starter
Astral85's Avatar
Rep: 4 (Unique: 4)
So this past weekend as I redid my tubes for the fourth time I discovered the OUT port on my EK XRES pump has stripped threads. The barb fitting just spins and doesn't tighten properly. There is shavings of acetal everywhere... I decided to fill anyway and it appears to have a good enough seal that it is not leaking, however I rushed to find a new pump and ordered an EK Kinetic D5. But now after looking more at EK's other pumps and a thread I came across someone mentions the DDC pumps are better for hard line, especially for lot's 90 deg angles because of increased head pressure. If I am considering going hard line have I made the wrong decision getting another D5? EK have a new VTX pump that they mention as suitable for small factor builds. Is this another type of DDC pump?
Asus Maximus XI Hero, 8700K 5.0Ghz, Custom loop: EKWB Velocity, X-RES D5, Rads: EK PE 360, Corsair XR5 280, EVGA RTX 2080 Ti FTW3 Ultra/EK Vector FTW3, Corsair Dominator Platinum RGB 32GB 3733Mhz, Samsung 850/860 Evo's, Seasonic Prime Ultra 1300W, Phanteks Eclipse P600S, Asus ROG Swift PG349Q 120hz 34"
Astral85's RIG
(0 items)
Astral85 is offline
post #2 of 4 (permalink) Old 06-29-2020, 09:06 PM
Costas's Avatar
Rep: 143 (Unique: 105)
In theory - Yes, DDC pumps will provide for a higher pressure value at a given flow point. However D5's will provide higher flow rates at a given pressure value for its PQ curve relationship..
In practice, it really is not worth worrying about for 99.9% of our builds as either of these pumps will provide ample flow rates for the majority of complex builds you ever see on this forum. If you really have a more complex build, - just use a dual pump top like I did.
Check out my single loop Deja Vu build which has a myriad of 90 deg fittings yet still achieves excellent flow rates (using 2 D5's).
No....
Costas is offline
post #3 of 4 (permalink) Old 06-29-2020, 10:43 PM
Moose-Tech's Avatar
Rep: 9 (Unique: 9)
I went with dual DD5 pumps and have not looked back. I have a failsafe on my Aquareot LT6 to shut down the PC if my flow rate drops below 55 L/ph.
Build: Z390 ACE
Core i9-9900K OC 5 GHz, MSI Z390 ACE Mobo, AMD Radeon VII GPU OC 2K MHz
Corsair Vengeance RGB 32GB 3200 RAM, Phanteks Enthoo Pro M SE.
EKWB Z390 ACE Monoblock, Bykski Radeon VII GPU w/b, 2x EKWB 140 Revo D5 Pump & Res.
Aquacomputer Aquaero 6 LT USB Fan-Controller, Quadro, Vision Touch and 'High Flow' Sensor.
(2x) HWL Black Ice Nemesis 280 GTS XFLOW and (1x) Alphacool XT45 X-Flow 280 radiators.
Moose-Tech is offline
post #4 of 4 (permalink) Old 06-30-2020, 05:41 AM
Rep: 1 (Unique: 1)
Doesnt the bios have does protections?
Mordorr is offline
