First custom loop advice on 280mm rad! - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 05-28-2020, 09:08 PM - Thread Starter
Dash8Q4's Avatar
Rep: 4 (Unique: 4)
So I've finally ordered some parts to start my first custom loop.
The ultimate plan is to have dual 280mm rads for this build. My case supports a 280mm or 360mm in the front and 240/360 on the top. Now it supports 140mm fans on the top and I have one going right now. So today I tested the 280mm rad from the Corsair H115i in the top and it fit just fine so I don't know why the manufacturer didn't put a 280mm there.
Anyway, I am looking for advice for a good performing 280mm rad under 40mm thick with sub 1700RPM speed used in the fans. I have done some research and so far I have narrowed it down to the listed rads, keep in mind I will be using Arctic P14 (nonpwm) for this. The fans are the 3pin since I couldn't get the PWM version but the motherboard regulates the voltage and I see no issues slowing them down so far.
Here are the contenders
1.Hardware Labs Nemesis 280 GTS(or XFLOW) - this is a maybe because of the distance from edge of rad to screw holes since my case has a pull out tray which has the holes at a certain distance from the edge meaning I have to make sure it fits.
2. EK Coolstream SE - 22 FPI
3. Koolance HX-CU1402V - 30 FPI
4. Primochill 280 EximoSX Slim - 20 FPI
Initially I'm going to cool the GPU and later the CPU, but the goal is for both in the next few months. I'm doing soft tubing for now 13mm OD, black Barrow fittings, Evga waterblock for my RTX, and this pump reservoir combo(https://www.formulamod.com/barrowch-...-p2034903.html).
Let me know what you think. My second 280 will be the front one and that's going to be a thicker rad for the same fans. Maybe I'll do a 360mm but like I said, already have the fans and I cannot fit 3x140mm in the front.
Thanks for chiming in.
-8
Intel Devil's Canyon Owners Club
Daily Driver
(14 items)
Ryzen 7 3700X
Asus X570 TUF wifi
EVGA 2080 Super
T-Force Dark Pro 16GB 3200C14
Plextor PCIE SSD
1TB HP EX920 m.2
2TB Samsung 860 QVO
6TB 3.5"
4TB 3.5"
1TB WD Blue 2.5"
Fractal Design Ion+ 760p
Cryorig R1 Ultimate (lapped)
BeQuiet Dark Base 700 (inverted motherboard config)
ASUS PG279Q
Dash8Q4 is offline
post #2 of 10 (permalink) Old 05-29-2020, 12:40 AM
KingT's Avatar
Rep: 478 (Unique: 306)
Well I have had SE 240 with 2x EK Vardar fans @ ~ 1300 rpm and it had cooled my ocd GTX 1080 @ 50C max.
Now I added 140 CE rad and EK Velocity CPU block and cooling system handles my 4930K @ 4.25GHz 1.26V at 61C in Intel Burn Test (2x push/pull at 1000rpm) and GPU @ max 49C with fans on 240 rad @ 1200 rpm max.
It can run Crysis..
i7 4930K @ 4.37GHz / 125 BCLK (1.31V LOAD)
Asus Rampage IV Formula
EVGA GTX 1080 Founders Edition
G Skill Ripjaws Z 4x4GB @ 2333MHz, CL10
Kingston HyperX 3K 120GB SSD
Crucial MX100 256GB SSD
2x Seagate Barracuda 500GB [7200.12] @ RAID 0
Optical Drive
Samsung DVD
Cooler Master V1200 Platinum
Noctua NH-D14
Cooler Master HAF 932
Operating System
Windows 10 Pro 64bit
DELL UltraSharp U2412M 24"
Keyboard
Logitech G110
Mouse
Roccat Kone MAX (rev.2)
Mouse
N/A
Audio
Logitech G430 headset
E6750 G0 @ 3.3GHz (1.25V LOAD)
Asus P5KPL-VM G31
GeForce 8500GT @ 700/1600/445
Apacer 2x1GB 800MHz
Hitachi Deskstar 160GB (7200,8MB)
Optical Drive
LG DVD
Cheap stuff
Linkworld crappy/modded
Operating System
Win 7 Ultimate 64bit build 7601
LG 19"
Keyboard
5$ keyboard
Mouse
SmartBox cheap
Mouse
N/A
KingT is offline
post #3 of 10 (permalink) Old 05-29-2020, 06:20 AM
Overclocker in training
ThrashZone's Avatar
Rep: 176 (Unique: 106)
Hi,
Seeing you already got the 140mm fans
GTS series period.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
10900k batch # X016E724
z490 ASUS Maximus XII Apex
EVGA 1080ti FTW3
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
ThrashZone is offline
post #4 of 10 (permalink) Old 05-29-2020, 06:55 AM - Thread Starter
Dash8Q4's Avatar
Rep: 4 (Unique: 4)
Quote: Originally Posted by ThrashZone View Post
Hi,
GTS series period.
I measured the width and unfortunately it's not gonna work out on the top or front. The GTS is too wide.
-8
Daily Driver
(14 items)
Ryzen 7 3700X
Asus X570 TUF wifi
EVGA 2080 Super
Plextor PCIE SSD
1TB HP EX920 m.2
2TB Samsung 860 QVO
6TB 3.5"
4TB 3.5"
1TB WD Blue 2.5"
ASUS PG279Q
Dash8Q4 is offline
post #5 of 10 (permalink) Old 05-29-2020, 06:58 AM
ThrashZone's Avatar
Hi,
280 rads are all pretty much the same width and length
Only differences are how thick.
GTS is a fairly thin rad and optimized for low rpm fans.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
EVGA 1080ti FTW3
EVGA 1000P2
Corsair 450D
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
post #6 of 10 (permalink) Old 05-29-2020, 10:14 AM
D-EJ915's Avatar
Rep: 15 (Unique: 14)
Hi,
The issue is hardware labs radiators are like 1cm wider than every other brand so they don't fit in his case.
How wide can you fit?
Kanna
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
post #7 of 10 (permalink) Old 05-29-2020, 01:27 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 451 (Unique: 298)
I'm not sure how you did research and still included the EK SE as a possibility. It is quite literally the worst performing rad from any name manufacturer. And it's not even "the worst by just a little bit".....it's the worst by a healthy amount - https://www.xtremerigs.net/2015/02/1...-round-2015/5/
If you are looking for a slim rad and can't fit the GTS (which is a shame, as it blows every other slim rad out of the water), The Koolance is a good choice, as is the Alphacool ST30 V2 - https://www.performance-pcs.com/wate...-ac-14280.html
ciarlatano is offline
post #8 of 10 (permalink) Old 05-29-2020, 01:46 PM
asuindasun's Avatar
Rep: 63 (Unique: 59)
I'm pretty happy with my primochill 280SX, but it was one of a few 280 rads that would fit my case (SFF pain in the rear). Haven't found a good 280 roundup that it's included in, but it's 360 brother does.
http://thermalbench.com/2017/07/06/p...mm-radiator/5/
Not as good as the 360 GTX i was running on my old full tower build, but with an XSPC slim 120 it's sufficient for a [email protected] + 1080ti under water (~75C and 50C under sustained heavy gaming).
rad was VERY clean when I got it too, very minimal crud flushed out when i did the vinegar/water shake n dump I do with new rads.
asuindasun is offline
post #9 of 10 (permalink) Old 05-29-2020, 02:18 PM - Thread Starter
Dash8Q4's Avatar
Rep: 4 (Unique: 4)
Maybe 145mm tops. But I'm thinking more and more to get GTS 240 if I can sell my 140mm fans.
I don't know how either, must've slipped thru the cracks while my eyes were half open late night. It doesn't help my left upper eyelid is swollen from allergy rubbing either.
Gents I'm still on the fence with the selection. Seeing that all the parts except GPU block are coming to Canada from China will take a little while, I have some time to try selling my fans since I can't return them due covid which means I could go the GTS route and do a 240 in the top and a 360 in the front. We'll see. If not, it looks like the Alphacool is the second place for my choosing. ST30 for the top and an XT45 for the front.
Cheers
-8
Daily Driver
(14 items)
Ryzen 7 3700X
Asus X570 TUF wifi
EVGA 2080 Super
Plextor PCIE SSD
1TB HP EX920 m.2
2TB Samsung 860 QVO
6TB 3.5"
4TB 3.5"
1TB WD Blue 2.5"
ASUS PG279Q
Dash8Q4 is offline
post #10 of 10 (permalink) Old 06-07-2020, 09:58 PM - Thread Starter
Dash8Q4's Avatar
Rep: 4 (Unique: 4)
I went with Alphacool’s St30 v2 and xt45 v2 as well. Hoping they perform well.
-8
Daily Driver
(14 items)
Ryzen 7 3700X
Asus X570 TUF wifi
EVGA 2080 Super
Plextor PCIE SSD
1TB HP EX920 m.2
2TB Samsung 860 QVO
6TB 3.5"
4TB 3.5"
1TB WD Blue 2.5"
ASUS PG279Q
Dash8Q4 is offline
