When you're fed up with bad case selection - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 06-02-2020, 06:43 AM - Thread Starter
tcclaviger's Avatar
Rep: 25 (Unique: 22)
You design your own case I'm fed up with the constraints that case builders have, needing to facilitate space for 3.5" drives, 2.5" drives, 5.25" bays, multi-system cases etc.
100% Aluminum
Removable MB tray (slides out the back)
7x140mm intake fans
1x120 intake fan
480 SR2 Push Pull Exhausting
240 SR2 Push Pull Exhausting
Dedicated cutout for Aquaero 6 above 240
Radiators mount behind motherboard tray in rear chamber, cut outs for radiator port access
Outside Dimensions 23.1 x 22 x 10
Can take an 11 inch wide EATX board
Left side panel is tempered glass (not shown)
Still working out the front I/O and Button location and whether or not i want to add another 480 in the roof.
Working on a good water jet facility to do the cutting, very open to suggestions if you have any!
tcclaviger is offline
post #2 of 12 (permalink) Old 06-02-2020, 11:05 AM
Nineball_Seraph's Avatar
Rep: 4 (Unique: 4)
you know im getting some caselabs vibes here. And honestly considering CL is no longer around and 3d printing/CNC is a big thing now im suprised that a CL duplicate hasnt come out of the woodwork.
Heatware: Nineball |
Main Rig: Lian Li Dynamic XL | [email protected] (1.26v) | EVGA XC Ultra Gaming 2080Ti 2160Mhz on stock BIOS | 16 G.Skill Trident RGB @ 4000MHZ | Asus Hero Max X | Heatkiller V CPU block, EKWB Full cover block, Aquacomputer D5 Next, 2x Alphacool nexos rads | Corsair AX1200i
Nineball_Seraph is offline
post #3 of 12 (permalink) Old 06-02-2020, 11:14 AM
Shawnb99's Avatar
Rep: 62 (Unique: 43)
100% Aluminum
7x140mm intake fans
1x120 intake fan
So a Caselabs case? Great idea!
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #4 of 12 (permalink) Old 06-02-2020, 11:33 AM
Xinoxide's Avatar
Rep: 282 (Unique: 251)
I think the caselabs idealogy in their cases is a fantastic framework.
I would like to see more done with the imagination like this feller here on a regular basis though.
Caselabs design is still caselabs design. I myself would let it be, Tt can remain in crosshairs themselves.
Firestrike vs. Similar Systems
FIRESTRIKE EXTREME ULTRA
LittleBitties
(15 items)
PC of the Son.
(9 items)
ryzen 7 3800x
ASRock X470 Gaming-ITX
ASRock Phantom Gaming RX 5700 XT Challenger D
G.Skill RGB Z 3600 C14
Intel EX920 M.2 1TB
EVGA SUPERNOVA G2 1000
Corsair H100i v2
Metallic Gear MGNE210 BLACK
Viotek GN34C
Keyboard
Corsair K75 LUX
Mouse
Logi G502 Hero
Mousepad
Corsair "speedmat?"
Audio
AKG K240 ( 1987 )
Audio
Alienware by Ultrasone
Audio
Roland RH-200
Ryzen 5 1600
ASRock AB350M
Zotac GTX 1050Ti OC
GeIL EVO SPEAR 2x4GB DDR4-2400
HP EX900 500GB M.2
Corsair CX450M
AMD Wraith SPIRE RGB
CM Q300L
QNIX 2710
Xinoxide is offline
post #5 of 12 (permalink) Old 06-02-2020, 11:37 AM
Section31's Avatar
Rep: 20 (Unique: 16)
Lot of us are in your boat. I would love to get an caselabs case quality and design commissioned but it just costs too much.
The Ever Ongoing Build. 3950X. X570 Hero VIII, 32GB GSkill Trident Z 4000mhz, Seasonic Prime Titanium 1000Watt, 1TB 960 Pro, 1TB WD SN750.
Section31 is offline
post #6 of 12 (permalink) Old 06-02-2020, 11:58 AM
Vermin Supreme 2020
skupples's Avatar
Rep: 736 (Unique: 388)
i'm about to toss 3x 480SR2 into my stuff as well
I was fed up with cases when 900D launched, so I went CaseLabs.
looking back, i should've gotten a second, and a third.
Add me on Steam, same name
skupples is offline
post #7 of 12 (permalink) Old 06-03-2020, 02:46 PM
PhillyB's Avatar
Rep: 30 (Unique: 28)
PhillyB is offline
post #8 of 12 (permalink) Old 06-04-2020, 04:59 AM
Triffid's Avatar
Rep: 0
Im planning on building one out of wood to accommodate 2x 560s.
Mass loaded vinyl and foam for sound proofing. Both intake & exhaust muffled to an absurd degree. The PSU will exhaust inside, decoupled from rear via an arcade power switch.
A big dumb silent(as i can make it) box under the desk.
Will use carcass (motherboard tray and rear panel - i/o & pci slots) from regular case. Front i/o from a Fractal R6.
Triffid is offline
post #9 of 12 (permalink) Old 06-04-2020, 10:52 AM
PhillyB's Avatar
sounds like the exact opposite of my spare computer that mounts everything on either side of a plywood board.
PhillyB is offline
post #10 of 12 (permalink) Old 06-05-2020, 02:55 PM - Thread Starter
tcclaviger's Avatar
/rant
Fashion open loop pisses me off.
Sad that it comes down to designing your own case because the industry is so tied around the finger of 1x120 is enough for each major component or 2x120 if overclocking. That is such crap guidance I can't even fathom where or why that stupid guideline is a thing. It blows my mind that people would go to all the work, planning, time to build a custom loop to settle for 10c or worse Air-Water deltas. At that point... just buy a Noctua cooler and be done with it lol. If you have to turn your open loop fans over 1200 to beat the NH-D14 it's a complete waste imho.
Then, on top of that, you get cases like the 011d. While pretty and somewhat functional, they completely waste space and take what could be amazing and leave it mediocre by leaving it slightly too narrow and too shallow. Even worse, the 011XL... w t f, like, make it 2 inches taller and deeper for 480s please.
I just cannot understand investing the cash/time to build an open loop to settle for aircooling level of performance, blows my mind.
/end rant
Currently holding 4c at 800 rpm with 3900x and 2080ti in loop, 2 D5s, and MB VRMs also in loop, but I want to build the above to try and get it to 2c at 800 RPM as I despise audible fans, the loudest thing in my setup is my Aquacomputer flow meter gently clicking 1 or 2 times a second. By my math it'll take at least the push\pull and 10x120 of a GTX/SR2 or 11x120 of UT60/XT-45 to pull it off.
