The SPC pump in the EK-Classic DP Front PC-O11D sucks. - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 06-02-2020, 11:26 AM - Thread Starter
ObviousCough's Avatar
Rep: 0
Should I bypass it completely or just run another pump in series/parallel?
If I were to bypass: The red dots are what gets plugged. The green dot with the blue outline is where the new pump would go in/out (with a Y fitting so i can still drain the loop). The blue dot with the red outline is where my GPU will go, eventually. Orange dot with the purple outline is for CPU. Orange dot with yellow outline is radiator in/out.
ObviousCough is offline
post #2 of 12 (permalink) Old 06-02-2020, 11:46 AM
Xinoxide's Avatar
Rep: 282 (Unique: 251)
Plug it. Time to experience an eheim.
Firestrike vs. Similar Systems
FIRESTRIKE EXTREME ULTRA
LittleBitties
(15 items)
PC of the Son.
(9 items)
ryzen 7 3800x
ASRock X470 Gaming-ITX
ASRock Phantom Gaming RX 5700 XT Challenger D
G.Skill RGB Z 3600 C14
Intel EX920 M.2 1TB
EVGA SUPERNOVA G2 1000
Corsair H100i v2
Metallic Gear MGNE210 BLACK
Viotek GN34C
Keyboard
Corsair K75 LUX
Mouse
Logi G502 Hero
Mousepad
Corsair "speedmat?"
Audio
AKG K240 ( 1987 )
Audio
Alienware by Ultrasone
Audio
Roland RH-200
Ryzen 5 1600
ASRock AB350M
Zotac GTX 1050Ti OC
GeIL EVO SPEAR 2x4GB DDR4-2400
HP EX900 500GB M.2
Corsair CX450M
AMD Wraith SPIRE RGB
CM Q300L
QNIX 2710
Xinoxide is offline
post #3 of 12 (permalink) Old 06-02-2020, 12:21 PM
jonkrmr's Avatar
Rep: 4 (Unique: 4)
It is a DDC style pump. Replace the pump with a proper DDC pump like a Swiftech MCP35x or similar.
jonkrmr is offline
post #4 of 12 (permalink) Old 06-02-2020, 12:34 PM - Thread Starter
Rep: 0
It's not. They're incompatible.
post #5 of 12 (permalink) Old 06-02-2020, 01:13 PM
Arni90's Avatar
Rep: 87 (Unique: 80)
Just set the new pump in series with the old one, that way you have a backup in case your pump dies
Main rig
(16 items)
9900k
Z390 AORUS MASTER
RTX 2080 Ti
4x 8GB B-die @4000 MHz 16-16-16-37-2T
960 EVO
860 EVO
ADATA SX8200 PRO 1TB
Optical Drive
No
Fractal Design ION+ 860W
MCP655
Alphacool RTX 2080 Ti full cover block
EKWB Supremacy EVO
3x 180mm radiator
SST-FT02
Operating System
Windows 10
EX3501R
Arni90 is offline
post #6 of 12 (permalink) Old 06-02-2020, 01:18 PM - Thread Starter
Rep: 0
It won't be a problem that the SPC flow rate is only 250 L/h?
post #7 of 12 (permalink) Old 06-03-2020, 04:50 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 451 (Unique: 298)
No, it will not hinder the other pump.
ciarlatano is online now
post #8 of 12 (permalink) Old 06-04-2020, 10:18 PM
Lerkah's Avatar
Rep: 12 (Unique: 10)
The fact it's the lesser DDC pump is so **** on EK's part. It's a relatively expensive premium piece with a less than acceptable pump.
Poop
(17 items)
Pensixteen
(15 items)
Pen Fifteen
(15 items)
9600KF
ASUS ROG Strix z390F
EVGA 1080ti Founders Edition
GSkill Trident
Samsung EVO 970 Nvme
WD Black HDD
Corsair HX1050
EK Supremacy CPU
2x360mm radiator
EK 1080ti
d5 pump
XSPC hardline fittings
Lian Li 0-11 Dynamic
Operating System
win10
AOC 27inch 144hz
Keyboard
corsair k75
Mouse
logitech g502
i5 6600k
Asus Sabertooth MK1
EVGA Nvidia 1080ti FE
Corsair CMK16GX4 8GBx2 DDR4
Crucial 250gb SSD x2
2tb WD Black x4
Corsair HX1050
Custom W/C
Corsair 800D
Operating System
Win 10 Pro
AOC Agon 24inch 144hz
Keyboard
Corsair K70 RGB w/ Cherry Speeds
Mouse
Logitech G402
Mouse
Some big ass honking razor mat
Audio
Astro A50 Gen3
i7930 @ 4.0ghz @ 1.22v 24/7
Asus P6T Deluxe V2
Sapphire Radeon HD5870
OCZ
OCZ Vertex2 120gb SSD / 2x1tb Samsung SP F3
Optical Drive
Pioneer DVR 218L
Corsair HX1050
Custom Loop
Corsair 800D
Operating System
Windows 7 Ultimate 64bit
Samsung 23inch LED x3 Eyefinity
Keyboard
Logitech G15 Refresh
Mouse
Razor Goliathus
Mouse
Logitech G700
Audio
Edifier S550
Lerkah is offline
post #9 of 12 (permalink) Old 06-05-2020, 10:18 AM - Thread Starter
Rep: 0
I'm surprised there isn't an adapter for it yet.
I'm going to mount a Koolance PMP-420 at the back of the case to suck water through 2x360 rads. For fans I am going Noctua all around. Three A12x25 pulling air in from the top so it blows on my ram too, two more in the bottom of the case pulling air in so it blows on my gpu. Three A12x15 on the side rad pulling air out of the case.
The SPC will push water directly through an EK XE 240 in the bottom. I don't know what GPU block i am going to get as I don't know what GPU i am getting. I ordered an Optimus Foundation block for my cpu. My side chamber 360 is a Nemesis GTS. I haven't decided what 360 I am going to put in the top. Probably an EK XE, though i haven't ruled out a hardwarelabs SR-2.
Bitspower fittings, haven't settled on whether or not I am going hardline or matte black EPDM tubing.
post #10 of 12 (permalink) Old 06-05-2020, 10:30 AM
Vermin Supreme 2020
skupples's Avatar
Rep: 732 (Unique: 385)
yes. low tier DDCs are trash.
Add me on Steam, same name
skupples is offline
