Budget CPU only loop, or AIO? - Overclock.net - An Overclocking Community
post #1 of 19 (permalink) Old 06-02-2020, 07:35 PM - Thread Starter
Gamer
Cysquatch's Avatar
Rep: 74 (Unique: 49)
Im ready to change up my cooling setup on my pc. I wan't to push my cpu overclocks, it seems I have a fairly decent CPU. My NH u12s isnt cutting it. I have a feeling everyone is going to say custom loop. I would really like to keep the costs down. Please give me some opinions, suggestions. Thanks
Gaming Rig
(12 items)
Ryzen 5 3600
MSI B450 Tomahawk Max
Sapphire Nitro+ RX 5700 XT 8G GDDR6
Crucial Ballistix 16GB (2 x 8GB) DDR4 3600
Silicon Power 1TB P34A80
Seasonic FOCUS Plus SSR-650FX
Noctua NH U12S
Fractal Design Meshify C
Operating System
Windows 10 Pro
Dell S2419HGF
Keyboard
Razer Blackwidow Elite
Mouse
UtechSmart Venus
Cysquatch is offline
post #2 of 19 (permalink) Old 06-02-2020, 08:10 PM
Why is it smoking?
Mr. Mojo's Avatar
Rep: 365 (Unique: 298)
A 3600 isn't hard to keep cool with any halfway decent air or AIO cooler, even when pushed to its limits (which won't be much higher than PBO anyway). You can go with a custom loop if you want it, but it's just going to be for looks, something to tinker with, or with an eye towards future upgrades. I'm not trying to turn you off the idea. I just want to make sure you know that it won't make a drastic difference in the CPU's performance.
Black Feathers
(22 items)
Even Better JuJu
(10 items)
AMD Ryzen 7 3700x
Gigabyte x570 Aorus Pro Wifi
Sapphire Radeon RX 5700 XT
Crucial Ballistix Elite DDR4 3600
Sabrent Rocket NVMe PCIe 4.0 M.2 2280
Sabrent Rocket NVMe PCIe M.2 2280
Seasonic FOCUS Plus 750
EK-KIT Classic RGB P360 with upgraded pump/res and tubing
EK-Vector Radeon RX 5700 +XT RGB - Nickel + Plexi
Arctic P12 PWM PST
DEEPCOOL RF120M
XSPC G1/4" Inline 10k Sensor, Chrome
Mayhems Pastel White Concentrate
Lian-Li PC O11 Dynamic (white)
Operating System
Windows 10 Pro
Viotek GFT27DB
BenQ GL2760H
Keyboard
Logitech G213
Mouse
Logitech G502 Hero
Mousepad
Enhance GX-MP6
Audio
Audio Technica ATH-M50x
Audio
Philips Fidelio X2HR
AMD Ryzen 5 2600
Gigabyte B450 I AORUS PRO WIFI
ZOTAC Gaming GeForce GTX 1660 Super amp
Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3200MHz C16
Silicon Power 512GB SSD 3D NAND A55
Optical Drive
External Blu Ray DVD Drive
Seasonic FOCUS Plus 550 Gold
AMD Wraith Prism
EVGA DG-77
Operating System
Windows 10 Pro
Mr. Mojo is offline
post #3 of 19 (permalink) Old 06-02-2020, 08:15 PM - Thread Starter
Gamer
Cysquatch's Avatar
I'm at 4.5 ghz @ 1.28 volts. I did get my system to boot to windows at 4.7, But voltages were maxing out my cooler. I'd really like to push the limits of this cpu. You think a decent AIO would be capable?
Gaming Rig
(12 items)
Ryzen 5 3600
Noctua NH U12S
Operating System
Windows 10 Pro
Dell S2419HGF
Keyboard
Mouse
UtechSmart Venus
post #4 of 19 (permalink) Old 06-02-2020, 10:13 PM
poah's Avatar
Rep: 8 (Unique: 7)
Arctic freezer II 280/360 will be good enough. ultimately you are going to be limited to 1.35v for an overclock.
poah is offline
post #5 of 19 (permalink) Old 06-02-2020, 10:39 PM
PC Enthusiast
Ashura's Avatar
Rep: 52 (Unique: 39)
Anything above your 4.5GHz is not guaranteed. So the question is how much is the potential 0-200mhz worth to you?
A - You're willing spend 100-200 bucks & will be okay even if you're stuck @ 4.5ghz. The experience of trying is good enough for the money.
The Arctic freezer II, Kraken X62/63, 280mm or 360mm, whichever fits your budget. These AIOs can handle your CPU at max clocks.
B - You want to upgrade your cooling but do not want to waste any money. In that case, a dual tower cooler such as the D15, Dark Rock pro 4 , Assassin III would be good choices. Or if you'd like an AIO, then the Arctic Freezer II 240mm is great value for money.
These will be a major upgrade from your current cooler whilst not hurting your wallet.
PolaRyz
(15 items)
AMD Ryzen R7 1700x
Asus Crosshair VI Hero
Asus GTX 1060 6Gb
Hyper X Predator 32gb 3000Mhz
Crucial MX100 256 GB
Seagate ST1000DM003
Toshiba DC01ACA300
SeaSonic S12G 750w 80+ Gold
Phanteks TC14PE
Phanteks Enthoo Pro
Operating System
Windows 10 Pro x64
LG 23MP68VQ
LG 23MP68VQ
Mouse
Logitech G402 Hyperion Fury
Mousepad
Steelseries Qck Mass
Ashura is offline
post #6 of 19 (permalink) Old 06-03-2020, 12:22 AM
prznar1's Avatar
Rep: 45 (Unique: 37)
Some time ago i have made a decision about making budget loop and it was worth it. Go for CPU only loop and later you can always expand to GPU also. Just get proper size radiator. When you will get the watercooling components they will stay with you. Pump, radiator, fans, fittings etc are parts that you don't have to change every time you swap pc parts. Olny GPU block is tricky because its hard to get core only GPU block now (i've used mine for 3 cards, GTX 580, 660 ti and 970). Or you can get fullcover and sell it later, and get some money back. What you get on return is the silence and cooling capacity. All that is out of the reach of any air cooler and aio is not expandable and also not as good as custom loop. Hope that helps.
Ryzen 5 3600 | ASUS TUF B450 PRO | 2x16 GOODRAM IRDM PRO 3600Mhz DDR4 | MSI VENTUS GTX 1660 Ti | PNY 1TB NVMe SSD | IN WIN 303 | be quiet! STRAIGHT POWER 10 500W
prznar1 is online now
post #7 of 19 (permalink) Old 06-03-2020, 04:36 AM - Thread Starter
Gamer
Cysquatch's Avatar
Why am I limited to 1.35v? Previous to me messing with the overclock my cpu was defaulting to 1.4v
Gaming Rig
(12 items)
Ryzen 5 3600
Noctua NH U12S
Operating System
Windows 10 Pro
Dell S2419HGF
Keyboard
Mouse
UtechSmart Venus
post #8 of 19 (permalink) Old 06-03-2020, 05:47 AM
Arni90's Avatar
Rep: 87 (Unique: 80)
While a custom loop can dissipate a lot of heat, the main bottleneck lies in the heat transfer from the die to the heatsink. This applies to both water cooling and air cooling on more recent processor architectures produced on 22nm, 14nm, 12nm, 10nm, and 7nm.
You might gain 10C by going from an NH-U12S to a custom loop, but that extra thermal headroom won't give you more than 50 mV before you're at the same temperature again. And Zen 2 voltage/frequency scaling is already poor past 1.15V (at least on the ones I have tested). Those 50 mV extra might gain you 50 MHz, possibly 75 MHz if you're lucky.
If you want a project for fun, going custom loop might be what you're looking for.
If you want silence, be prepared to spend a bit more money.
If you want more performance, save the money for an actual processor upgrade.
Main rig
(16 items)
9900k
Z390 AORUS MASTER
RTX 2080 Ti
4x 8GB B-die @4000 MHz 16-16-16-37-2T
960 EVO
860 EVO
ADATA SX8200 PRO 1TB
Optical Drive
No
Fractal Design ION+ 860W
MCP655
Alphacool RTX 2080 Ti full cover block
EKWB Supremacy EVO
3x 180mm radiator
SST-FT02
Operating System
Windows 10
EX3501R
Arni90 is offline
post #9 of 19 (permalink) Old 06-03-2020, 05:47 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 451 (Unique: 298)
You can go into the middle with a Swiftech X3 as an option. Preassembled, but made up of copper components and configured for easy expansion. It also has a pump strong enough to effectively expand if you want to add the GPU and another rad.
ciarlatano is offline
post #10 of 19 (permalink) Old 06-03-2020, 11:05 AM
poah's Avatar
Rep: 8 (Unique: 7)
safe level for the 7nm ryzen is 1.35v
poah is offline
