First build questions - Overclock.net - An Overclocking Community
post #1 of 25 (permalink) Old 06-03-2020, 08:53 AM - Thread Starter
Rep: 3 (Unique: 3)
First build with water cooling, and I've reached somewhat of the final stage of assembly here but stuck with a few questions:
Due to the layout of the res/radiator the first tubing run is very short/tight 90 degree that soft tubing just can't support. To keep the tubing from kinking the only thing I could think of with the parts on hand is to extend out from the radiator using 2 90 degree rotaries. Is there a better way of doing this? This build has been so delayed due to parts availability etc. that if there is a better fitting to help here waiting for another part won't really matter.
Also regarding initial run/fill... I spent about 2 hours per radiator flushing and running distilled water through the individual blocks (except the GPU) so far. Is it recommends to run the system/drain a few times with distilled water before switching to a pre-mix fluid? My initial thought was to run the system with distilled water (pump only) for 24 hours, drain, run it again with distilled for 2-3 hours, drain and then switch to the fluid. I also have Mayhems Blitz Part 2 sitting here, but I am not really sure that is necessary for a brand new loop.
ryouiki is online now
post #2 of 25 (permalink) Old 06-03-2020, 09:16 AM
Rep: 2 (Unique: 2)
Hi, nice parts.
Will your front panel fit with that current bend? Seems close from my house.
You could make this connection with a combination of fittings, I think. But, this would introduce a hand two nineties right off the pump outlet which is worst case scenario for these. It's doable but will adversely affect flow.
I would propose rotating pump/res 90* clock wise so fittings are facing you. See mine below - same concept.
for radiators, I simply flush mine with hot tap water for ~5 minutes when new. Then assemble everything using an inline filter before my cpu block to catch any debris and flush with ~1 gallon of distilled water. I run the system and drain the water slowly and top off res as I go through the water.
I think this would allow you a good path for flow:
pump/res - GPU/chipset (parallel) - cpu - top rad - bottom rad - pump res in
I think the chipset really likes parallel flow setup for temperatures. Serial flow resulted in higher temperatures for me.
This also lets you keep the iconic heatkiller cap which makes filling/bleeding MUCH easier, and removes the flow tube from visual.
Mxj1 is offline
post #3 of 25 (permalink) Old 06-03-2020, 09:46 AM
whk0's Avatar
Rep: 3 (Unique: 3)
1. remove all connectors
2. mount B to the pump facing down, mount A to the B facing down.
3. mount C to radiator straight up, D not needed.
whk0 is offline
post #4 of 25 (permalink) Old 06-03-2020, 09:47 AM - Thread Starter
Rep: 3 (Unique: 3)
Thank you for the reply,
Front panel just barely clears as is with a few mm of space. I can rotate the res and try some test runs to get a better feel for what that looks like... right now I'm using some cheap tubing just to figure out lengths while I wait for different tubing to arrive.
So the initial thought (which is why things are oriented as is) was:
Res - > Bottom Rad Inlet (according to HWLabs, there is a preferred direction on this rad) -> Bottom Rad Outlet -> Chipset -> GPU -> CPU -> Top Rad -> HK Top.
I had planned to try to use the Res inlet as the drain (Ball Valve + Male to Male extender), since the bottom Rad is not multiport. I also have 1 rotary splitter I suppose I could use to put the drain closer to the rad, though I can't quite visualize how that would fit right now.
post #5 of 25 (permalink) Old 06-03-2020, 10:19 AM - Thread Starter
Rep: 3 (Unique: 3)
This seems to just barely work depending exactly on how long the tubing cut is... though this tubing I'm using for testing is really thin so it seems to want to kink very easily. I'm hoping the new tubing is a little more workable.
post #6 of 25 (permalink) Old 06-03-2020, 10:44 AM
Back at it again.
Avacado's Avatar
Rep: 103 (Unique: 78)
Add one of these before that 90 degree fitting coming off the pump. https://www.amazon.com/Touchaqua-Fem...NsaWNrPXRydWU=
Will give a cleaner tube run.
23652 Time Spy https://www.3dmark.com/3dm/47932151?
[email protected] Stats https://folding.extremeoverclocking....e.php?u=207393
i9 9900k @5.1GHz 1.34v
ASUS Prime Z390-A 1504 BIOS
Evga 2080 Ti Black Gamer +220 Core
Evga 2080 Ti Black Gamer +150 Core
4x8GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w G+
EK CPU/GPU/RES
2x aCool UT60 RADs
Lian Li O11 Dynamic XL (White)
Operating System
Windows 10
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #7 of 25 (permalink) Old 06-03-2020, 11:46 AM - Thread Starter
Rep: 3 (Unique: 3)
I placed an order for a couple of different extender lengths (measuring seems to be that I need about 15-20mm) will have to wait until they are delivered.
I also tried to change the orientation of the Res, but this introduces a new problem depending on the fitting of not being able to close the side door... I have the fan mount kits for this tube so I could move it back against the side fans, but I'd rather not have to make such a big change, the wire management is already a nightmare due to fan controllers.
post #8 of 25 (permalink) Old 06-03-2020, 11:47 AM
Rep: 2 (Unique: 2)
The above suggestions are good. I don't like the misaligned hose and fittings personally - its your pc though. Flow order will not matter so you don't HAVE to go to bottom radiator right after the pump.
Hi, I will be interested to see your tubing run from radiator outlet to chipset.
You can add one of these 3 way splitter to radiator outlet with a male to male radial radial fitting. this would allow you to rotate your drain valve out of the way when not needed and make it less unsightly.
Mxj1 is offline
post #9 of 25 (permalink) Old 06-03-2020, 08:20 PM - Thread Starter
Rep: 3 (Unique: 3)
This is mockup of tubing until I get new tubing + extenders.
post #10 of 25 (permalink) Old 06-03-2020, 10:02 PM
Bartdude's Avatar
Rep: 4 (Unique: 3)
You could just do away with the hard 90 and use a 45 which would give a better angle into the rad and also improve flow directly out of the pump.
"No s*** lady, does it sound like I'm ordering pizza!"
Corsair 900D
(29 items)
Intel E4790k Haswell
Asus ROG Maximus VII Watchdogs
EVGA 1080 SC Gaming
Corsair Dominator Platinum
Samsung SSD
Samsung SSD
Samsung SSD
Optical Drive
LG Blu Ray Rewriter
Corsiar AX1200i
EK XTOP Revo Duel D5
2X EK Radiator 360 PE
EK Supremacy EVO
EK 1080 Full Cover Waterblock
Aquero 6 XT
Aquero MPS 400 Flow Sensor
9X Gentle Typhoon Fans
Aquacomputer Hubby7
4x Aquacomputer Splitty9
Aquacomputer Poweradjust USB 3 Ultra Version
Corsiar 900D
Operating System
Win 10 Pro 64
Asus ROG Swift PG279Q 27" 2K WQHD 165Hz IPS G-Sync 2K Gaming Monitor
Keyboard
Razer Blackwidow Soft Touch
Keyboard
Razor Orbweaver
Mouse
Razer Deathadder 3500DPI
Mouse
Razer Mouse Mat
Audio
Sound Blaster X-Fi Titanium Fatal1ty Champion Series
Audio
Yamaha RX-V381 5.1 Channel Receiver Amplifier
Audio
Tannoy 5.1 Speakers
Bartdude is offline
