Questions about arctic liquid freezer ii 360 - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 06-16-2020, 10:36 PM - Thread Starter
Elric2a's Avatar
Rep: 0
Hi
I've ordered this arctic liquid freezer ii 360
I have some questions about it
I saw all is plugged with one fan but will it be possible to plig the 3x120 on my corsair commander to control it while having the pump speed controlled in bios?
I have some ll120 fans in my case right now. If I use those instead of the arctic one (p12), would the performances be really worse?
Thanks
Envoyé de mon SM-G973F en utilisant Tapatalk
Motherboard: Aorus Master Z390
Processor: i9 9900k - 5Ghz / 1.25vcore
GPU : RTX 2080 TI EVGA FTW3 ULTRA
Ram : 32GB G.SKILL Trident Z RGB / 3466Mhz
PSU: Corsair RMI 850 GOLD
Watercooling : Corsair H150i Pro RGB / LL 120 RGB
Case : Cooler Master H500M
Elric2a is offline
post #2 of 16 (permalink) Old 06-16-2020, 11:34 PM
poah's Avatar
Rep: 8 (Unique: 7)
Id run the arctic fans and you can plug them into any unit to control them.
poah is offline
post #3 of 16 (permalink) Old 06-17-2020, 06:25 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 452 (Unique: 299)
I haven't tested them firsthand, but the few results that are published, as well as user experiences here, certainly point to the P12 being a much better fan than the Corsair LL.
ciarlatano is offline
post #4 of 16 (permalink) Old 07-07-2020, 02:17 PM - Thread Starter
Elric2a's Avatar
Rep: 0
Hi i have realized that when i use asus ai suite I can control the pump speed of my liquid freezer ii 360. Is it safe to do so?
Elric2a is offline
post #5 of 16 (permalink) Old 07-07-2020, 03:03 PM
The last VRM burner
Rep: 47 (Unique: 27)
LLs are mediocre pc case fans and bad radiator fans. Fans coming with LF II can be linked and controlled anywhere, pump is controllable and is designed to operate in variable RPM. It is safe to change its speed but only when plugging it to a 12V variable PWM source. I also despitse any ASUS software for being a pile of heavy junk. Leave it in motherboards hands.
PC for all
(23 items)
i7 5775c @4.2GHz/3.8GHz
MSI Z97 MPower
Iris Pro 6200 1300MHz
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Front Arctic P14 PWM PST x2
Top Arctic P14 x2
Back Arctic P12
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mouse
Tiger Gaming Arc teflon mouse feet
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is online now
post #6 of 16 (permalink) Old 07-07-2020, 05:46 PM
gasolin's Avatar
Rep: 8 (Unique: 8)
No you can't really not just change the pump speed in the stock configuration
Theres one cable that goes in the cpu fan header, that's alle you need, pump,vrm fan and the 120mm fans you all adjust with the samme setting an only one setting, as fare as i know cable goes from the fans down to the pump and the only cable you plug in to the cpu fan header
gasolin is offline
post #7 of 16 (permalink) Old 07-07-2020, 06:43 PM - Thread Starter
Elric2a's Avatar
Rep: 0
I plugged the fans to another header because i wanted to control them independently
The pump is plugged to a pump header now and I realized it was very loud because this header is 100% by default. When i changed the fan curve It was more silent. That's why I asked
If I plug everything all together will I still be able to control the fan speed?
Elric2a is offline
post #8 of 16 (permalink) Old 07-07-2020, 09:40 PM - Thread Starter
Elric2a's Avatar
Rep: 0
I suppose it's the vrm fan actually that is variating and not the pump speed but I wanted to know if its OK to leave it as it is.
If I plug it all on one header would I still be able to control the fan speed? Also will the vrm fan varies it speed as well?
Elric2a is offline
post #9 of 16 (permalink) Old 07-08-2020, 02:33 AM
The last VRM burner
If you plug everything into one header everything will be ran by the same PWM % given by motherboard, which you can adjust freely (to a degree). If you plug pump and fans separately you will be able to control separately fans and pump + vrm fan.
PC for all
(23 items)
MSI Z97 MPower
Corsair MP510
Samsung Evo 860
Top Arctic P14 x2
Back Arctic P12
LianLi 330X
Operating System
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Mouse
Mouse
Mousepad
Artisan FX Raiden
Audio
Audio
AKG M220
Other
NZXT Hue+
Other
post #10 of 16 (permalink) Old 07-08-2020, 02:37 AM - Thread Starter
Elric2a's Avatar
Rep: 0
I finally put tje pump abd vrm on aio pump which runs 100% and fans on cpu fan header. The level of noise is fine i guess its all ok
Elric2a is offline
