Looking for an additive that won't gunk up my loop over time - Overclock.net - An Overclocking Community
post #1 of 32 (permalink) Old 07-01-2020, 09:06 AM - Thread Starter
Rep: 1 (Unique: 1)
I've been using Mayhem's XT-1 Nuke, no coloring or anything else other than 10% of that and distilled water.
See attached pics for what it led to - a completely clogged loop, since water could not get past the waterblock, at least not with flow rate of significance, despite two large pump motors pushing it through the loop.
The water reservoir had similar foamy gunk all over the top of its inside which was very difficult to clean. I don't even want to image what's inside my radiators! It took several hours of hot vinegar to flush all this crud out. I did the waterblock by hand with baking soda (30 mins of scrubbing with a toothbrush, to get all the gunk out from between the ridges!) since nickel and vinegar don't mix.
There has to be an additive out there that won't gunk up your loop, but is still effective at killing algae and bacteria, so if anyone is using one that doesn't foam or leave a horrible residue behind, please reply with the brand/product details and how long you've been running it in your loop without issue.
mikegold10 is offline
post #2 of 32 (permalink) Old 07-01-2020, 09:13 AM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
was this with soft tube?
how long had the XT1nuke been run?
how did you clean your components before assembling and filling?
kinda looks like plasticizer.
i've been using X1 Clear/Mayhems Biocide/inhibitor droppers for years, n I can't say i've ever seen build up like since moving to X1 Clear.
(standard x1, not nuke cuz i'm not cooling nuclear powered lasers)
Add me on Steam, same name
skupples is offline
post #3 of 32 (permalink) Old 07-01-2020, 09:16 AM - Thread Starter
Rep: 1 (Unique: 1)
Soft tube was used, plasticizer-free (PrimoFlex Advanced LRT). I did the research and made sure before purchasing it. Also, plasticizer resembles fine powder not this paste, in any case.
The gunk is definitely from the Mayhem, since I see it forming in the foam if the water is run fast through the loop (even on day 1!). The precipitate in the image formed over about 2 years time.
post #4 of 32 (permalink) Old 07-01-2020, 01:08 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 452 (Unique: 299)
There are plenty of additives that won't gunk up your loop....it's the plasticizer that is gunking up your loop in this case.
Can you find me anywhere, just one single place that Primochill (and not a random poster in a forum) claims that Advanced LRT is plasticizer free? It's not. Never has been. And you are probably the fifth person I have seen post that it is in the last week (and, of course, showing a clear plasticizer issue and saying that it must be something else.....). What is up with that?
This is straight from Primochill, not a single mention of it being plasticizer free:
Description
PRIMOFLEX™ ADVANCED LRT™
PrimoFlex™ Advanced LRT™ Tubing has been designed, formulated, and manufactured for today’s evolving standards in the PC water cooling industry. Advanced LRT™ has been carefully formulated to perform in a wide range of closed loop cooling systems, creating the most compatible water cooling tubing ever created.
LOW RADIUS TECHNOLOGY
PrimoChill’s proprietary blend of notably low durometer PVC and more rigid polymer resin provides PrimoFlex™ Advanced LRT™ with an unbeatable bend ratio and durability. PrimoFlex™ has been tested in exacting laboratory set-ups. This included tests with abrupt small radius bends and multiple directional changes. Advanced LRT™ tubing resisted both twisting and collapse in test results. This allows for tighter bends eliminating kinking that can cause cooling failures and reduction in system performance.
CLARITY IN SIGHT AND MIND
Smooth inner walls improve closed loop sanitation. Advanced LRT™ smooth surface inhibits particulate gathering or entrapment onto the tubing wall. This reduces the potential of bacterial growth and contamination. With this technology, Advanced LRT™ will keep your system looking and feeling as clean as the day it was installed..
SysPrep & Liquid Utopia™ INCLUDED
COMPLETE RETAIL BUNDLE
Included in the package at no additional cost is a 15mL bottle of SysPrep – Cooling Loop Pre-Treatment as well as a 15mL bottle of Liquid Utopia. Any successful venture into water-cooling starts with a true cooling loop preparation which can only be achieved by using Sys Prep™. It will “flush” your loop and its components of any debris left by the manufacturing processes of your reservoir, block, pump, or radiator, leaving your water cooling loop clean, clear, pristine and ready for any type of coolant. Once your LRT tubing is crystal clear the Liquid Utopia offers a full line of protection against algae and corrosion.
START TO FINISH
PrimoChill has you covered from the beginning of your build to the end. For the first time a bundle is available that harmoniously matches a perfect tubing solution with a cleaning solution as well as a distilled water additive that ensures a clear, clean, and protected cooling loop!
FEATURES
Trusted/Experienced Brand. PrimoFlex
Inner Wall Resilience
FDA Approved ingredients
ROHS Compliant PVC
Glass Like Transparency. Crystal Clear
DEHP Free and Phthalate Free
Environmentally Responsible, Safe, and Non Toxic Product
Superior UV Transmission
SPECIFICATIONS
Dimensions
Inner Diameter (ID): 1/2in. ±.005
Outer Diameter (OD): 3/4in. ±.015
Wall Thickness: 1/8in
Compatibility
This tubing is designed to work with 1/2in. x 3/4in. compression fittings or 1/2in. Barb w/ 3/4in. Clamp.
Note: Due to a lack of tolerances in fitting design, we have seen some minor issues when using LRT tubing along with strict size brands such as Bitspower.
PARTS INCLUDED
PRIMOFLEX™ – 10ft (For a Cleaner Cooling Loop)
SYSPREP™ – 15ml (Cooling Loop Pre-Treatment)
UTOPIA™ – 15ml (Algae/Corrosion Protectant)
WARNINGS
With the use of different components, materials, fluids, and flow rates, results may vary with the appearance of your tubing. Although Advanced LRT™ is designed to work with a large variety of cooling components the use of alcohols, Ethylene Glycol and as well as any other harmful chemicals is strictly prohibited and will void your warranty. Tubing will stain if “dyed” coolants are used. PrimoChill is not responsible for any damage caused by or when using this product.
If your fittings seem extremely tight when using our tubing there are some methods to navigate around this issue. One method is to dip the end of our tubing into very hot (not quite boiling) water prior to installation. This will make the tubing more pliable allowing tight compression rings to be mounted easier. Using this method will also create a seal between the tubing and fitting once the tube cools creating an added layer of security.
PrimoChill is not responsible for any hardware damage. Use at your own risk.
View less
If you don't want plasticizer issues, get yourself some Tygon A-60-G or Tygon 2375, both of which are actually plasticizer free.
ciarlatano is offline
post #5 of 32 (permalink) Old 07-01-2020, 03:49 PM - Thread Starter
Rep: 1 (Unique: 1)
I just did more research and decided to follow your advice! I bought a huge 50-foot length roll of 3/8" ID / 1/2" OD Tygon 2375 clear soft tubing. It's pretty expensive and 50 feet is more than I will ever need, but I am going to retube my whole watercooling loop with it. I'll use less than 10-feet of it, so I'll have plenty left over to re-sell or keep.
Michael
post #6 of 32 (permalink) Old 07-02-2020, 01:38 PM
WaterCooler
Sir Beregond's Avatar
Rep: 75 (Unique: 68)
Have used Primochill Advanced LRT for years. Definitely has plasticizer.
Deus Ex (2015-)
(21 items)
[Intel] Core i7-4790k
[ASUS] Z97-DELUXE
[ASUS] GTX 980 Strix
[Corsair] Vengance Pro Series 16GB DDR3-2400
[Crucial] M550 512GB
[WD] Black 3TB x 2
[Corsair] AX750
[EK] Supremacy EVO - Gold
[EK] GTX 980 Strix - Fullcover w/ Backplate
[EK] D5 X-RES Top 100 w/ D5 Vario
[Monsoon] 3/8" ID 5/8" OD Compressions - Gold
[XSPC] EX240 x 2
[Corsair] SP120 x 5 / AF120 x 1
[Corsair] Carbide Air 540
Operating System
[Windows] 8.1 Pro 64-bit
[LG] 32GK650F-B
Keyboard
[Corsair] K70 - Red switches
Mouse
[Razer] Naga Epic
Audio
[Audio Technica] ATH-A700
Audio
[Antlion] ModMic
Other
[Lamptron] FC5-V2
[Intel] Core i7-960
[ASUS] Rampage III Formula
[EVGA] GTX 670 FTW 2GB
[Corsair] Dominator-GT 6GB DDR3-1866
[Crucial] M4 128GB
[Samsung] Spinpoint F3 1TB x2
[WD] Caviar Black 750GB
[Corsair] AX850
[XSPC] Raystorm
[XSPC] EX360 and EX240
[Scythe] Gentle Typhoon AP-15 x 5
[EVGA] GTX 680 Hydro Copper w/ Backplate
[XSPC] Dual-bay Res w/ [Swiftech] MCP655
[Bitfenix] Spectre Pro Red LED - 140mm x 4
[NZXT] Switch 810 Matte Black
Operating System
[Windows] 7 Ultimate 64-Bit
[BenQ] XL2420TX
Keyboard
[Saitek] Cyborg V.5 Red LED
Mouse
[Razer] Naga Epic Red LED
Audio
Audio
[ASUS] Xonar Essence STX
Other
[Lamptron] FC5-V2
[Intel] Core M-5Y10
[Intel] HD Graphics 5300
[Generic?] 8 GB DDR3
[Generic?] 256GB SSD
Operating System
[Microsoft] Windows 10
1920 x 1080
Sir Beregond is offline
post #7 of 32 (permalink) Old 07-03-2020, 05:42 AM
New to Ryzen
chas1723's Avatar
Rep: 2 (Unique: 2)
I use this tubing as I thought it was plasticizer free as well. It definitely is not plasticizer free. You have a plasticizer problem. Also, you should not have foam in your coolant.
Sent from my SM-N950U using Tapatalk
3800x
(18 items)
3800x
Asrock x570 Taichi
EVGA 980ti
G.Skill Trident Z Neo
Western Digital BLACK SERIES
Samsung 830 Series
Samsung 850 Pro Series
Silicon Power M.2-2280 NVME Solid State Drive
Optical Drive
LG UH12NS29 Blu-Ray Reader, DVD/CD Writer
SeaSonic PRIME Ultra Titanium 750 W 80+ Titanium Certified Fully Modular ATX Power Supply
EK EVO Copper CPU block
EK Titan X Copper GPU block
Alphacool NexXxos XT45 360 Radiator
Alphacool NexXxos XT45 420 X-Flow Radiator
Aquacomputer Aqualis 150mm
Phanteks Enthoo Series Primo Aluminum ATX Full Tower Case
Operating System
Windows 10 Home
BenQ SW271 27.0" 3840x2160
chas1723 is offline
post #8 of 32 (permalink) Old 07-03-2020, 07:00 AM
Watercooled since 2003
computertechy's Avatar
Rep: 3 (Unique: 2)
Noticed this chart on Overclockers UK.
Been using Mayhems Ultra Clear tube since beginning with a mix of Mayhems Ultra Pure H20, EC6 addictive, Mayhems biocide and EK Cryofuel for years & years.
Most i have ran a system without maintenance is 3 years and was practically perfect when i stripped it down. (Ultra pure, biocide & Mayhems Dye)
My rig.
(20 items)
9900K Direct-Die @ 5GHZ 1.33v
Gigabyte Aorus Master F11J
MSI RTX 2080Ti SEAHAWK EK X @ Stock
32GB Corsair Vengeance RGB Pro 3200
Samsung 960 Pro M.2 512GB
Sabrent Rocket 1TB
Samsung 860 Evo 2TB
Seagate BUP 4TB USB-C
Corsair HX1000i
EK Quantum Velocity Block, EK-2080Ti Block, 3 x 360 Rad's, 19 x 120mm Fans, 2 x EK-DBAY MX Res's & 2 x EK-D5 PWM G2 Pumps
Mountain Mods U2-UFO Extended
Operating System
Win 10 64Bit Pro
Asus MG278Q
Acer Predator XB270HA
Keyboard
Corsair K70 MK.2 Silent
Mouse
Corsair M65 RGB Elite
Mousepad
RGB
Audio
Fiio K3 DAC, SZ2000. Steelseries Arctis Pro + GAMEDAC, Yamaha Y-S501 & Mission x3i's, Turtle beach Elite 800X
Other
RT-AC68U & RT-AC86U Aimesh System
Other
1 x TP-Link TL-SG1016D 16 Port Switch, 2 x TP-Link TL-SG108S 8 Port Switch
computertechy is offline
post #9 of 32 (permalink) Old 07-03-2020, 09:00 AM
Overclocker in training
ThrashZone's Avatar
Rep: 186 (Unique: 111)
Michael
Hi,
2375 is good it does have typing all down it though
Problem is 3/8-1/2" is very soft so it can't do turns very well
3/8-5/8" is best
If in the USA modmymods.com has some good PVC soft tubing worth considering i switched to it but again I used 3/8-5/8" but this stuff is pretty stiff so 3/8-1/2" would probably be fine.
https://modmymods.com/modmymods-3-8-...-mod-0002.html
Mods also has some good mods clear coolant 9.us and one free with coolant as discount code I also switched it but they also sell mayhems stuff too.
https://modmymods.com/modmymods-modw...-mod-0275.html
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is offline
post #10 of 32 (permalink) Old 07-03-2020, 10:56 AM
Rep: 1 (Unique: 1)
Damm...
Shouldn`t buy Tygon S3 E-3603.....
Mordorr is offline
Tags
additive , water block , Water Cooling
