New Loop Build - Looking for Parts Review - Overclock.net - An Overclocking Community
post #1 of 41 (permalink) Old 07-03-2020, 05:15 PM - Thread Starter
ObscureEmpyre's Avatar
Rep: 0
Hello. I'm thinking of breaking into custom water cooling but I'm not exactly sure I've got all bases covered. Below are the parts I'm looking to cool and below that are the parts I've pieced together from EKWB using their configurator with some modifications. This is for a gaming rig. Open to tips/suggestions/opinions. Please let me know what you think.
CPU: Intel Core i9 9900K overclocked to 5GHz all cores, currently cooled with a Corsair H150i Pro RGB AIO
GPU: EVGA RTX 2080 Ti FTW3 Ultra Hybrid Gaming with an overclock of +110/+1100
Case: Fractal Design R6
Note: CPU and GPU temps tend to hang around the mid-60s C depending on the game/application, sometimes cooler, and low 30s when idle. Wanting to bring them down a bit when under load. Ambient room temp tends to hang around 24-26° C for reference.
EKWB Parts:
CPU Block: EK-Quantum Velocity D-RGB - Nickel + Plexi
Pump/Res: EK-Quantum Kinetic TBE 200 D5 PWM D-RGB - Plexi
GPU Block: EK-Quantum Vector FTW3 RTX 2080 Ti D-RGB - Nickel + Plexi
GPU Backplate: EK-Quantum Vector FTW3 RTX 2080 Ti Backplate - Black
Top Rad: EK-CoolStream PE 360 (Triple)
Front Rad: EK-CoolStream SE 240 (Slim Dual)
Fittings: EK-Torque STC-10/13 - Black
Drain Valve: EK-AF Ball Valve (10mm) G1/4 - Black
For Drain Valve: EK-AF Extender 12mm M-M G1/4 - Black
For Drain Valve: EK-CSQ Plug G1/4 - Black
Tubing: EK-DuraClear 9,5/12,7mm 3M RETAIL
Coolant: EK-CryoFuel Navy Blue (Premix 1000mL)
Note: Wondering if a fill port would be worthwhile. Also, no fans listed as I have plenty of Corsair ML-120s
ObscureEmpyre is offline
post #2 of 41 (permalink) Old 07-03-2020, 05:44 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 733 (Unique: 385)
I'd avoid using nickel if you're hell bent on EK, go no nickel.
if you're hell bent on it, get Optimus or HeatKiller nickel blocks, so the finish will last a little while. (they're also better performing products, they're both top tier for the industry on all CPU series)
i'd also NOT use EK coolant. They stopped Rebranding Mayhems coolant, and have had a ton of issues ever since(we see it ALL the time here). Best bet Mayhems X1(V2/Eco) or Mayhems Biocide+ inhibitor+
I appreciate your attempt for a full EK system, but it'll come at the cost of total possible performance.
Better radiators = Hardware Labs SR2
I'd also recommend going with EK's dual D5 pump based on the size of your loop.
another recommendation for all your pumps/LEDs, fans etc. Aquacompunter OCTO = full RGB control, pump control, fan control, curve control, monitoring, etc in one piece of software with vastly superior programming & functionality to iCue, Commander, motherboard level solutions, MSI Sync, and all the other Big Box Gamer Gear brand companies. aquacomputer also makes REALLY good blocks, like optimus & Heatkiller.
OCTO = for fans pumps & LEDs via Aquasuite
High Flow Sensor & temp sensor in one.
https://www.performance-pcs.com/aqua...r-pwm-fan.html
https://shop.aquacomputer.de/product_info.php?language=en&products_id=3832https ://www.performance-pcs.com/aquacomputer-flow-rate-sensor-high-flow-usb-g1-4-aq-53129.html
Add me on Steam, same name
skupples is offline
post #3 of 41 (permalink) Old 07-03-2020, 05:54 PM - Thread Starter
Rep: 0
Thanks for the input. I only went with EK because it's a brand I've heard of and they have a configurator. Not ashamed to admit to being a total noob when it comes to custom loops. I'll definitely check out the other manufacturers you mentioned and their products.
post #4 of 41 (permalink) Old 07-03-2020, 05:55 PM
Why is it smoking?
Mr. Mojo's Avatar
Rep: 365 (Unique: 298)
You will probably get a lot of "EK sux" replies. IMO, they aren't the best but they aren't the worst either. I went with EK in my build because it was easier than tracking 5 different vendors and waiting forever for the components I wanted to be in stock. I seriously waited for almost 2 months for a Heatkiller block to be restocked before I gave up and went with EK.
A fill port can make things easier depending on layout, but it may not be necessary if you have easy access to the res. I would be more concerned about adding a temp sensor and maybe a flow meter, as these should be included in every loop.
The only components I would really consider changing are the tubing and coolant. Primochill and Mayhems both offer much better tubing for about the same price. I started with EK tubing, and it clouded up within about a month. I switched to Primochill almost a year ago and the tubing still looks as good as it did the day I installed it. I have a couple of short pieces of Mayhems tubing in my loop as well, and it is also still in good shape.
Mayhems coolant is the most popular for a reason. It's good, it lasts, and it doesn't stain or clump.
You will also probably want to get a prep/cleaning kit for the new components. This is another item where Mayhems is probably the best on the market (Blitz Kit).
Black Feathers
(22 items)
Even Better JuJu
(10 items)
AMD Ryzen 7 3700x
Gigabyte x570 Aorus Pro Wifi
Sapphire Radeon RX 5700 XT
Crucial Ballistix Elite DDR4 3600
Sabrent Rocket NVMe PCIe 4.0 M.2 2280
Sabrent Rocket NVMe PCIe M.2 2280
Seasonic FOCUS Plus 750
EK-KIT Classic RGB P360 with upgraded pump/res and tubing
EK-Vector Radeon RX 5700 +XT RGB - Nickel + Plexi
Arctic P12 PWM PST
DEEPCOOL RF120M
XSPC G1/4" Inline 10k Sensor, Chrome
Mayhems Pastel White Concentrate
Lian-Li PC O11 Dynamic (white)
Operating System
Windows 10 Pro
Viotek GFT27DB
BenQ GL2760H
Keyboard
Logitech G213
Mouse
Logitech G502 Hero
Mousepad
Enhance GX-MP6
Audio
Audio Technica ATH-M50x
Audio
Philips Fidelio X2HR
AMD Ryzen 5 2600
Gigabyte B450 I AORUS PRO WIFI
ZOTAC Gaming GeForce GTX 1660 Super amp
Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3200MHz C16
Silicon Power 512GB SSD 3D NAND A55
Optical Drive
External Blu Ray DVD Drive
Seasonic FOCUS Plus 550 Gold
AMD Wraith Prism
EVGA DG-77
Operating System
Windows 10 Pro
Mr. Mojo is offline
post #5 of 41 (permalink) Old 07-03-2020, 06:07 PM
Vermin Supreme 2020
skupples's Avatar
no worries, the configurator is a great place to a get a list of all the possible pieces you want, which you can then build on from there. You could always fire the trigger on all of that, & be off to the races with a functional system. or you could further tune things..
personally at the least I'd do the following
upgrade to EK's dual PWM D5 pump combo
add the aquacomputer parts linked below
go with mayhems coolant (https://www.performance-pcs.com/mayh...mx1c250ml.html)
You're gonna catch a lot of EK flak because we've seen their products degrade in quality slowly over the years, so the performance extremists cast extreme views on the matter. They aren't wrong that the nickel finish is trash though, and they aren't wrong that their coolant is trash as well.
Performance-Pcs.com & Frozencpu are the best places to get parts in the US, with Amazon coming in second.
For real though, these three things are next level for system control.
https://www.performance-pcs.com/fans...r-pwm-fan.html
https://www.performance-pcs.com/wate...-aq-53129.html
https://www.performance-pcs.com/wate...-aq-53234.html
You can technically control your pump from the OCTO as well, just not sure if it would be stuck at the same speed as the other fans (not sure if the octo gives individual control as I use Aquaero instead of OCTO)
skupples is offline
post #6 of 41 (permalink) Old 07-03-2020, 06:09 PM - Thread Starter
Rep: 0
I have no doubt EK isn't the best. Just looking to make things easy with purchasing. My goal as this point is to get it right the first time. Will be looking into Mayhems and Primochill. Thank you for the suggestions.
post #7 of 41 (permalink) Old 07-03-2020, 06:11 PM
Vermin Supreme 2020
skupples's Avatar
you can also clone blitz kit in the future with watered down pool acid & dawn dish soap
skupples is offline
post #8 of 41 (permalink) Old 07-03-2020, 06:16 PM
Why is it smoking?
Mr. Mojo's Avatar
Yeah, vinegar or citric acid also work (diluted of course). It also wouldn't hurt to throw a filter in somewhere. You can buy a cheap inline fuel filter at any auto parts store with the correct barbs.
Black Feathers
(22 items)
Even Better JuJu
(10 items)
AMD Ryzen 7 3700x
Arctic P12 PWM PST
DEEPCOOL RF120M
Operating System
Windows 10 Pro
Viotek GFT27DB
BenQ GL2760H
Keyboard
Logitech G213
Mouse
Logitech G502 Hero
Mousepad
Enhance GX-MP6
Audio
Audio
AMD Ryzen 5 2600
Optical Drive
AMD Wraith Prism
EVGA DG-77
Operating System
Windows 10 Pro
Mr. Mojo is offline
post #9 of 41 (permalink) Old 07-03-2020, 06:20 PM - Thread Starter
Rep: 0
If I go with EK stuff, I'll probably get the D5 dual you mentioned. Again, all that was put together with their configurator, and then I made some changes/additions to it. I'm not even sure going with a single loop for the CPU and GPU is the best route to go. A single loop is all I think my case can accommodate, though. I think I'd even prefer a 360 rad in the front, but that too I don't think my case can handle. That's why I chose a 240. I've only had the Fractal R6 for about a year and a half, but maybe it's already time for a new one. Otherwise, what's wrong with nickel out of curiosity?
post #10 of 41 (permalink) Old 07-03-2020, 06:27 PM
Why is it smoking?
Mr. Mojo's Avatar
It's not a problem with nickel in general, it's just that EK has some well documented QC issues with their plating/process. EK's nickel plated components have a fairly common flaking and/or corrosion problem. I haven't seen it in my components but there are lots of reports of it.
Black Feathers
(22 items)
Even Better JuJu
(10 items)
AMD Ryzen 7 3700x
Arctic P12 PWM PST
DEEPCOOL RF120M
Operating System
Windows 10 Pro
Viotek GFT27DB
BenQ GL2760H
Keyboard
Logitech G213
Mouse
Logitech G502 Hero
Mousepad
Enhance GX-MP6
Audio
Audio
AMD Ryzen 5 2600
Optical Drive
AMD Wraith Prism
EVGA DG-77
Operating System
Windows 10 Pro
Mr. Mojo is offline
Tags
2080 ti , 9900k , Ekwb
