Best way to clean, preserve and store water blocks? - Overclock.net - An Overclocking Community
post #1 of 31 (permalink) Old 07-04-2020, 02:16 PM - Thread Starter
Been around...
garyd9's Avatar
Rep: 20 (Unique: 17)
As the title says...
Specifically, I have an EK EVO Supremacy that I can't bring myself to throw in the garbage. I've disassembled it to clean as well as I can, but there are limits what I can do with the "EK Nickel Plating", and I'm not sure how to go about drying it for preservation and storage.
(Or shipment to someone else who might want it.)
Ryzen 9 3900X
Asus Crosshair VIII Hero
NVidia RTX 2070 Super Founders Edition
G.Skill Ripjaws 32GB 3600 CL16 (Hynix DJR @ 16-16-19-21)
Samsung 970 EVO Plus
Seasonic Prime TX-750
EKWB Velocity CPU Water Block
HWLabs 360GTS Radiator
EK-XTOP with D5 Pump
Monsoon MMRS tube Res
Thermaltake Core X5
Operating System
Windows 10 Pro x64
Asus PB328Q 32" WQHD
Asus 25" 16:10 (forgot the model number)
Keyboard
Ducky Shine 5
Mouse
Logitech G900
Mousepad
Corsair MM300
garyd9 is offline
post #2 of 31 (permalink) Old 07-04-2020, 02:20 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 452 (Unique: 299)
Wipe it dry as best you can, then let natural drying take care of the rest. Just leave it unassembled for a couple of days to completely dry, put it back together and put it back in the box. Nothing you need to do that isn't obvious.
ciarlatano is offline
post #3 of 31 (permalink) Old 07-05-2020, 04:32 AM
Overclocker in training
ThrashZone's Avatar
Rep: 186 (Unique: 111)
Hi,
Tooth brush and tooth paste to clean everything
Dry and reassemble
I usually use some blue tape to cover in/ outlets put back in the box.
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is offline
post #4 of 31 (permalink) Old 07-06-2020, 02:09 PM
MakubeX's Avatar
Rep: 121 (Unique: 114)
Funny, I'm in the exact same boat. I'm about to replace my old Supremacy and I had the same questions.
MakubeX is offline
post #5 of 31 (permalink) Old 07-08-2020, 06:06 AM
EJays gaming mods
LosHog's Avatar
Rep: 0
Really ciarlatano ?? You were saying in some other post how no one should never reuse any water cooling part !! That they would leak our have clogs
LosHog is offline
post #6 of 31 (permalink) Old 07-08-2020, 08:48 AM
ciarlatano's Avatar
Uh....no. Never said that. The posts you referred to in that thread in that thread wasn't even mine....nor did that post even say it. You have some issues.
post #7 of 31 (permalink) Old 07-08-2020, 09:00 AM
EJays gaming mods
LosHog's Avatar
Rep: 0
Your right sir I deeply apologize to you
LosHog is offline
post #8 of 31 (permalink) Old 07-08-2020, 08:55 PM
Moderately Ancient
Andrew LB's Avatar
Rep: 27 (Unique: 22)
My old Aquacomputer Kryographics GPU block that was on my 780ti kept tarnishing (being copper and all that) so after i cleaned it real good using dish soap and a little "barkeepers friend" which brightens copper, brass, etc, rinsed with distilled water, and dried using my air compressor in the garage, i put it into one of those vacuum sealer bags for food, sealed it up and it looks the same as when i sealed it up probably 2 years ago. As others have said, toothpaste also works well.
Intel i7-10700K @ 5.2 - Asus Prime z490-A - EVGA GTX 1080 - 32gb Corsair DDR4 3600mhz - Creative X-Fi Titanium HD - Adata 1tb M.2 - Samsung 512gb 860 Evo + 512gb 850 Evo - Phanteks Enthoo Pro M - Watercool DualDDC Top - 2x DDC1-T PWM 10w Pumps - XSPC Raystorm V3 CPU block - AquaComputer Pascal block - Barrow Tube Res - XSPC ex360 Rad w/3x Fractal Venturi 120mm fans - XSPC ex280 Rad w/2x 140mm Phanteks 140mm fans - Aquaero 5LT + Flow Meter - 14mm Barrow Fittings - Crystal-Link Acrylic Tubing
Andrew LB is offline
post #9 of 31 (permalink) Old 07-08-2020, 09:01 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
foodsavers are an awesome around the house tool for more than food & weed, it's true.
Add me on Steam, same name
skupples is offline
post #10 of 31 (permalink) Old 07-08-2020, 09:11 PM
Moderately Ancient
Andrew LB's Avatar
^^^ one of the best comments ive seen in a while.
