Mo-ra3 user - Overclock.net - An Overclocking Community
Mo-ra3 user
post #1 of 15 (permalink) Old 07-10-2020, 08:44 PM - Thread Starter
Rep: 1 (Unique: 1)
Mo-ra3 user
I have a mo-ra3 420 with 4x200 fan on and 3x360 rad inside my case. Pump is mcp35x2 directly from reservoir to mo-ra3 then back in the case. My water temp at idle is 27c, at load 700w, water temp is a 31c-33c. Ambient is 24c-25c. I tried to disconect the mo-ra3 and just use 3 internal rad and I see the temp stays the same. Is something wrong? I tried to run the fan on mo-ra3 at 100% and see 0.4c drop from outlet and inlet. At regular speed, temp stays the same.
Thanh Nguyen is offline
post #2 of 15 (permalink) Old 07-10-2020, 11:35 PM
I can count to potato
Fluxmaven's Avatar
Rep: 56 (Unique: 24)
Just diminishing returns... There's a point where adding more radiator doesn't help. What are you trying to achieve? sub 10c delta T is already great temps.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
64GB TridentZ 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is offline
post #3 of 15 (permalink) Old 07-10-2020, 11:41 PM - Thread Starter
Rep: 1 (Unique: 1)
I just want to get load temp closer to ambient.
post #4 of 15 (permalink) Old 07-11-2020, 12:48 AM
Fluxmaven's Avatar
Why? At 31-33c liquid you are going to see pretty low GPU and CPU temps. If you want to go below that you will need to get exotic. Either a chiller or phase change
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
GTX 1080 FE
WD Black SN750
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Keyboard
Mouse
Glorious Model O
Mousepad
Audio
Audio
Focusrite 2i4 Gen2
Audio
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
WD Blue 3D m.2
Corsair AX760
InWin D-Frame Mini
i7 6700
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
post #5 of 15 (permalink) Old 07-11-2020, 02:30 AM
Kana Chan's Avatar
Rep: 16 (Unique: 14)
Are the pumps running at 100%? You could try adding another since each component decreases flow.
Kana Chan is offline
post #6 of 15 (permalink) Old 07-11-2020, 03:19 AM - Thread Starter
Rep: 1 (Unique: 1)
Because I saw 1 guy on reddit who has the same mora and he has 2c drop when water in and out the mora. Feel like my mora does not cool down the water. Does it has the inlet/outlet?
post #7 of 15 (permalink) Old 07-11-2020, 04:08 AM
skline00's Avatar
Fluxmaven is correct.
I also own a MO-RA3-420 pro with 9x140mm fans and haven't used it for quite awhile on my custom cooled builds because the internal rads do so well.
What cpu/gpu combo are you custom water cooling?
9900k-5.0-Krak X72|Asrck Z390 Taichi|32g-DDR4-3200 FlrX|EVGA GTX 2080TI XC | Crsr MP500-480g+ 2-1tb ssds|EVGA 1000W|Thmtake V51|Acer ET430k|Win10-64 home+Oculus Rift
3900x stock Custom WC Optimus WB; 480+360 rads EK D5|MSI X570 Unify|32g-DDR4-3600 TriZ Neo|Asrck Rad VII-EK blk |Sbrent Rocket 1tb NVME4|Crsr RX850|Fractal Define 7XL|BenQ EX3501R
skline00 is online now
post #8 of 15 (permalink) Old 07-11-2020, 04:32 AM
Still here...
iamjanco's Avatar
Rep: 147 (Unique: 66)
^ I'll third what Fluxmaven said, though it would be more helpful if we knew what sort of air you're pushing through the rad (flow rate, static pressure, etc.), cooling liquid flow rate through the rad, and a few other things like the cooling liquid in use (actual product name, dilution, etc.).
I'm guessing that might be a bit over your head at this point in time though, but please correct me if I'm mistaken.
Ref. Modeling the Heat Transfer Through a Radiator. While the equations might appear complex at first glance, they're likely still valid today.
iamjanco is online now
post #9 of 15 (permalink) Old 07-11-2020, 04:39 AM - Thread Starter
Rep: 1 (Unique: 1)
[email protected], 2080ti 2190mhz/8200. Dual pump mcp35x2 straight from reservoir to mo-ra3 so flow rate should be good. Noctua nf a20 fan. I saw jay2cents has 1c delta with 4 480 rad so I added the mo-ra3 to my system.
post #10 of 15 (permalink) Old 07-11-2020, 05:13 AM
Still here...
iamjanco's Avatar
You're already pretty close to ambient as is (27c, at load 700w, water temp is a 31c-33c. Ambient is 24c-25c.). If you want cooler regardless of what's been said on Reddit and/or what jay2cents said, lower your ambient temp, perhaps using an air conditioner. You could also try posing the question to jay2cents and see what sort of response you get.
In any event, you've already got a similar thread up and running on techpowerup's forum. I'm not sure you'll find different answers here, but it doesn't hurt to try
Good luck
@ThrashZone
