New 3900X build- my first attempt at water cooling. Custom hardline loop. - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 07-13-2020, 08:27 AM - Thread Starter
Rep: 0
Loving this PC. I have some minor complaints about the case, but everything else has performed as expected or better. I do get some coil whine from the video card under heavy loading, but I've heard much worse though. I know the monoblock is total overkill, but I really like the flow wheel indicator as a quick check that the pump is flowing.
The Alphacool rads have a lot of ports, so I took advantage of that have a drain valve at the front of the case, and ports up high to fill from. Draining and filling the loop is cake. I have temp sensors in the other empty ports.
I am surprised at the amount of power the system can draw. I've seen sustained loads over 750W with my kill-a-watt meter. The 750W power supply was all I could find at the time, I really wanted an 850W or a 1000W model. I will upgrade the PSU when I do a CPU and GPU upgrade down the road.
The cooling capacity of the loop is phenominal. The water temps barely rise no matter how much heat is dumped into the loop. When you are sitting at the desk, you can't tell- but when you stand up, you feel this layer of heat up high that the PC has dumped into the room. It makes one hell of a space heater.
Looking forward to Zen3 chips, and better GPUs down the road. A GPU swap will only take two new runs max with my setup, and they are the two most easily accessible runs.
Name:	Idle Temps.PNG
Name:	Folding on Water.PNG
Name:	Big Red Machine - Copy.jpg
Big Red Machine
(11 items)
Ryzen 9 - 3900X
ASUS ROG Crosshair VIII Hero
ASUS 2070S
Corsair Dominator Platinum
Sabrent Rocket
ASUS ROG Swift
Phanteks Enthoo Primo SE
Operating System
Win 10 Pro
Acer Nitro XV272U
Keyboard
Corsair K70 MK2
Mouse
Corsair Ironclaw Wireless
ProEng-EM is offline
post #2 of 8 (permalink) Old 07-18-2020, 01:40 PM
Rep: 3 (Unique: 2)
Looks good.
Those extra ports on the radiators are underrated.
Mxj1 is offline
post #3 of 8 (permalink) Old 07-27-2020, 03:40 AM
Rep: 0
Is that Idle temps? Mine sits around 100-105F if im lucky it will go down to 85-86
haz2k90 is offline
post #4 of 8 (permalink) Old 07-27-2020, 05:00 AM
New to Ryzen
chas1723's Avatar
Rep: 2 (Unique: 2)
How does that system peg 750 watts?
Sent from my SM-N950U using Tapatalk
3800x
(18 items)
3800x
Asrock x570 Taichi
EVGA 980ti
G.Skill Trident Z Neo
Western Digital BLACK SERIES
Samsung 830 Series
Samsung 850 Pro Series
Silicon Power M.2-2280 NVME Solid State Drive
Optical Drive
LG UH12NS29 Blu-Ray Reader, DVD/CD Writer
SeaSonic PRIME Ultra Titanium 750 W 80+ Titanium Certified Fully Modular ATX Power Supply
EK EVO Copper CPU block
EK Titan X Copper GPU block
Alphacool NexXxos XT45 360 Radiator
Alphacool NexXxos XT45 420 X-Flow Radiator
Aquacomputer Aqualis 150mm
Phanteks Enthoo Series Primo Aluminum ATX Full Tower Case
Operating System
Windows 10 Home
BenQ SW271 27.0" 3840x2160
chas1723 is offline
post #5 of 8 (permalink) Old 07-27-2020, 07:07 AM
I can count to potato
Fluxmaven's Avatar
Rep: 55 (Unique: 23)
Not OP but if you're referring to those LCD temp screens, I'm pretty sure that's liquid temps based on their hwinfo screenshots.
As another point of reference my 3900x is sitting at 39c under light load with 29c liquid in a 25c ambient room. My rig is never completely idle, so I rarely see it go below 37c.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
64GB TridentZ 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is offline
post #6 of 8 (permalink) Old 07-30-2020, 09:37 PM
Bartdude's Avatar
Rep: 4 (Unique: 3)
Nice job on the hardline tube, see too many builds that use hard 90's etc. instead of bending the tube.
"No s*** lady, does it sound like I'm ordering pizza!"
Corsair 900D
(29 items)
Intel E4790k Haswell
Asus ROG Maximus VII Watchdogs
EVGA 1080 SC Gaming
Samsung SSD
Samsung SSD
Samsung SSD
Optical Drive
LG Blu Ray Rewriter
Corsiar AX1200i
EK XTOP Revo Duel D5
2X EK Radiator 360 PE
EK Supremacy EVO
EK 1080 Full Cover Waterblock
Aquero 6 XT
Aquero MPS 400 Flow Sensor
9X Gentle Typhoon Fans
Aquacomputer Hubby7
4x Aquacomputer Splitty9
Aquacomputer Poweradjust USB 3 Ultra Version
Corsiar 900D
Operating System
Win 10 Pro 64
Asus ROG Swift PG279Q 27" 2K WQHD 165Hz IPS G-Sync 2K Gaming Monitor
Keyboard
Razer Blackwidow Soft Touch
Keyboard
Razor Orbweaver
Mouse
Razer Deathadder 3500DPI
Mouse
Razer Mouse Mat
Audio
Sound Blaster X-Fi Titanium Fatal1ty Champion Series
Audio
Yamaha RX-V381 5.1 Channel Receiver Amplifier
Audio
Tannoy 5.1 Speakers
Bartdude is offline
post #7 of 8 (permalink) Old 07-30-2020, 09:43 PM
sev1's Avatar
Rep: 0
Damn that’s nice!
sev1 is offline
post #8 of 8 (permalink) Old 07-30-2020, 09:59 PM
Been around...
garyd9's Avatar
Rep: 20 (Unique: 17)
Very nice build. I can't even imagine the amount of time and effort that went into it. While some of your component choices aren't the same as I would make, it's still damn nice.
For myself, I doubt I'll ever go hard tubing. Every time I start to consider it, something happens to remind me how much flexibility soft tubing gives me. (For example, I can re-paste my CPU without ever draining my loop, and if a soft tube ever gets in my way, I can easily just push it to the side.) Of course, I also have a bunch of ugly soft tubes sticking all over...
Ryzen 9 3900X
Asus Crosshair VIII Hero
NVidia RTX 2070 Super Founders Edition
G.Skill Ripjaws 32GB 3600 CL16 (Hynix DJR @ 16-16-19-21)
Samsung 970 EVO Plus
Seasonic Prime TX-750
EKWB Velocity CPU Water Block
HWLabs 360GTS Radiator
EK-XTOP with D5 Pump
Monsoon MMRS tube Res
Thermaltake Core X5
Operating System
Windows 10 Pro x64
Asus PB328Q 32" WQHD
Asus 25" 16:10 (forgot the model number)
Keyboard
Ducky Shine 5
Mouse
Logitech G900
Mousepad
Corsair MM300
garyd9 is offline
