Flow rate? - Overclock.net - An Overclocking Community
Flow rate?
post #1 of 25 (permalink) Old 07-15-2020, 02:42 PM - Thread Starter
Just hangin' out
Arctucas's Avatar
Rep: 36 (Unique: 35)
Flow rate?
For a custom loop; D5, 420 rad, CPU block only, 1/2 I.D. tubing, what should I expect (ballpark range) for flow rate?
I realize there are many variables for rad and block restrictions, but I am only looking for a general idea.
PC
(15 items)
9900K
eVGA Z390 DARK
eVGA RTX2080 FTW3 ULTRA
GSKILL F4-4500C19D-16GTZKKE
SAMSUNG 960EVO
Optical Drive
TSSTCORP SH-223L
CORSAIR AX1200
LIANG D5, XSPC DUAL BAY RESERVOIR, HEATKILLER IV PRO NICKEL, THERMOCHILL PA140.3, AEROCOOL 140MM SHARK FANS
THERMALTAKE XASER VI
Operating System
W7 U X64 SP1
LG 32GK650F
Keyboard
LOGITECH
Mouse
LOGITECH
Audio
Auzentech X-Meridian 7.1 2G
Audio
Z-5500
Arctucas is offline
post #2 of 25 (permalink) Old 07-15-2020, 04:54 PM
Rep: 354 (Unique: 268)
Assuming it is a modern cpu block with low psi drop and given radiators are not restrictive..flow should be 2gpm..ish with D5 full speed. D5's on speed 4 much quieter, still should at least 1.75gpm ish. As long as at least ~1gpm, doesnt affect temps much.
You can play with martins liquid lab flow estimator linked below, also has temp changes per flow rate for 200W load. Just plug in D-tek fuzion V2-stock as it simulates avg flow of more modern cpus blocks, EkVel, heatkiller IV, koolance 390, etc. Then can choose D5 vario pump on chart and see how much estimated flow from various components and speed, have to have excel though.
http://martinsliquidlab.petrastech.c...Estimator.html
Z390 GB Aorus Master // 9900k 5.0gz 1.325v bios// 2x8GB 4133 16-16-16-36 1.47v // 2080ti FTW //intel optane nvme OS, samsung 1Tb 960 pro nvme games
Cooling 2x280 rads with NF-A14 PWM, heatkiller IV cpu block, gpu block, F31 suppressor case
opt33 is offline
post #3 of 25 (permalink) Old 07-16-2020, 02:57 AM - Thread Starter
Just hangin' out
Arctucas's Avatar
See my sig for components. 1/2 inch soft tubing.
I bought a Koolance INS-FM17N Coolant Flow Meter and ADT-FM03 Flow Meter Frequency Adapter.
I plugged the adapter into my Corsair Commander.
Both AIDA64 and HWiNFO report ~700mL per minute. I thought that seemed a bit low.
In no way should it be misconstrued that I do not disagree.
https://valid.x86.fr/52sqs5
PC
(15 items)
9900K
eVGA Z390 DARK
SAMSUNG 960EVO
Optical Drive
TSSTCORP SH-223L
CORSAIR AX1200
Operating System
W7 U X64 SP1
LG 32GK650F
Keyboard
LOGITECH
Mouse
LOGITECH
Audio
Audio
Z-5500
Arctucas is offline
post #4 of 25 (permalink) Old 07-16-2020, 03:35 AM
Shawnb99's Avatar
Rep: 66 (Unique: 47)
That’s WAY to slow. 700ml=0.185 gallons. The bare minimum is 0.5GPM so you’re not even half of that. Ideally you want 1GPM, you need to look at adding a second pump.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #5 of 25 (permalink) Old 07-16-2020, 04:00 AM
Back at it again.
Avacado's Avatar
Rep: 106 (Unique: 80)
I honestly think you can achieve 2GPM easily with that D5. I'd wager at pump 80% maybe 1.5 GPM.
23664 Time Spy https://www.3dmark.com/spy/13047865
[email protected] Stats https://folding.extremeoverclocking....e.php?u=207393
i9 9900k @5.1GHz 1.34v
ASUS Prime Z390-A 1504 BIOS
Evga 2080 Ti Black Gamer +220 Core
Evga 2080 Ti Black Gamer +150 Core
4x8GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w G+
EK CPU/GPU/RES
2x aCool UT60 RADs
Lian Li O11 Dynamic XL (White)
Operating System
Windows 10
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is online now
post #6 of 25 (permalink) Old 07-16-2020, 04:56 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 452 (Unique: 299)
Or the Corsair Commander is completely screwing up the data. Because, you know.....buggy Corsair hardware with buggy Corsair software and Corsair being completely incapable of doing anything correctly in liquid cooling.
ciarlatano is offline
post #7 of 25 (permalink) Old 07-16-2020, 06:00 AM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
rate is about what you want it to be, and you want it to be around 1 gallon per minute, which is somewhere around 220 liters per hour if I remember correctly.
note you'd want higher overall flow if you're splitting your flow to multiple GPUs and cooling your board/memory. Hell, at that point you'd even maybe genuinely benefit from a split loop, idk. still seems unlikely.
Add me on Steam, same name
skupples is offline
post #8 of 25 (permalink) Old 07-16-2020, 06:44 AM
Like ciarlatano said, something is off. you have 1 rad (not restrictive), same cpu block as me heatkiller IV (pressure drop only 0.87 psi at 1gpm ie not restrictive) and D5 pump/res.
I have same cpu block (heatkiller IV), 2 rads, D5 setting 4 and gpu block. My flow is 1.2 gallons per minute measured the most accurate way ie inlet tubing draining gallon of distilled over time, which I test with new builds.
So either as ciarlatano pointed out your corsair commander and adapter is very inaccurate or you have a blockage somewhere or your pump has severe issues, even at setting 1 or pwm pump at lowest setting should not be that low with just cpu block/pump rad loop.
opt33 is offline
post #9 of 25 (permalink) Old 07-16-2020, 01:36 PM - Thread Starter
Just hangin' out
Arctucas's Avatar
OK, thanks guys, I thought something seemed wrong.
Guess I am tearing it down...
EDIT: I was monitoring it in HWiNFO, went from minimum of 526mL/min to max of 1,159 mL/min. Sounds like failing pump to me. Agree/disagree?
PC
(15 items)
9900K
eVGA Z390 DARK
SAMSUNG 960EVO
Optical Drive
TSSTCORP SH-223L
CORSAIR AX1200
Operating System
W7 U X64 SP1
LG 32GK650F
Keyboard
LOGITECH
Mouse
LOGITECH
Audio
Audio
Z-5500
Arctucas is offline
post #10 of 25 (permalink) Old 07-16-2020, 01:57 PM
ciarlatano's Avatar
I would bet the Corsair Commander can't make heads or tails of the input from the flow meter, or that the flow meter or frequency adapter is bad. If that was your flow, your temps would have likely increased very noticeably. When you turn the pump up to full speed to you see movement in the res? Because you probably wouldn't with the flow rates that are being reported.
