[updated] Water Cooling Essential Threads - Page 10 - Overclock.net - An Overclocking Community
post #91 of 99 (permalink) Old 09-05-2018, 11:57 PM
toolmaker03's Avatar
Rep: 76 (Unique: 59)
Quote: Originally Posted by Okt00 View Post
Just looks like the base URL's changed a bit. This list should work.
if you go through, and actually click on all of them. what you will find, is that more than half of the links, drop you on the forums page for OCN.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is online now
post #92 of 99 (permalink) Old 09-06-2018, 06:34 AM
News Fiend
ryan92084's Avatar
Looks good I only found 4 broken links How To: Build A Performance Shroud, How To: Make any Sized shroud in 2 minutes, 360 radiator shoot out, and bundymania user review triple radiator 360 roundup (new)
All the missing martin's content is sad.
Okt00's list works quite well as noted above.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #93 of 99 (permalink) Old 09-06-2018, 07:07 AM
no, you are right I should have calcified what I meant. yes the links take you to where it says it will but the corasponding links are broke making the first link useless.
here is a example.
if you click on block flow rates - martin it takes you here.
https://www.overclock.net/forum/61-w...ml#post4904052
and this is where the first link tells you that you are going. the issue is that you have not actually got to the information you are looking for yet. now, if you click on any of the corresponding links to get the information you are looking for, this is where it drops you.
and several of the first links, lead you to secondary links, that do this.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #94 of 99 (permalink) Old 09-06-2018, 07:27 AM
News Fiend
ryan92084's Avatar
here is a example.
https://www.overclock.net/forum/index.php
Ah, right. Most of the links are easy enough to fix but it is tedious. Basically have to add "forum/##-" in the middle of all the links.
https://www.overclock.net/water-cool...-pressure.html
needs to be
https://www.overclock.net/forum/61-w...-pressure.html
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
post #95 of 99 (permalink) Old 09-06-2018, 08:13 AM
Old and in the Way
iamjanco's Avatar
Rep: 70 (Unique: 45)
My guess is that when VS moved the forum to the VBulletin platform, they relied too much on older VBulletin tools they'd typically use to update things like link structures in embedded content. If so, that's unfortunate. A developer well versed in such migrations could have put together one or more scripts that checked those embedded links in the database itself for proper structure, using search and replace patterns designed to address them globally. Doing so would have also minimized issues like the one associated with broken images hosted on OCN, by provisioning for changes to image srcs (the URL of an image) as well. That is, as long as the names of the image files didn't change as a result of the migration.
For instance, an overly-simplified example of two links follows, one of which currently works, and one that doesn't:
working link: https://www.overclock.net/forum/61-water-cooling/411797-block-flow-rates-martin.html#post4904052
broken link: https://www.overclock.net/water-cooling/407027-last-one-my-q6600-cpu-waterblock.html
Given the examples above, using the proper tools and/or correct custom scripting, overclock.net/water-cooling/ in the broken link would have been replaced with overclock.net/forum/61-water-cooling/ everywhere, resulting in the correct path to that page in this instance:
https://www.overclock.net/forum/61-water-cooling/407027-last-one-my-q6600-cpu-waterblock.html.
Naturally, with respect to the new forum structure (as well as the non-forum content included in OCN's standalone pages), you'd have to account for all variations in your script(s). That includes any changes that might be necessary as far as (e.g.) permalinks to single post pages are concerned; and/or any links that might be dynamically built.
All that said, I won't comment on how long all of that might have taken though, at least not at this point in time and in a definitive way, because a review of the new site's structure would have to be accomplished first to ensure a comprehensive fix.
Certainly not more than the seven months it's already been though.
iamjanco is offline
post #96 of 99 (permalink) Old 09-07-2018, 02:16 PM
In VB's Basement
ENTERPRISE's Avatar
Apologies for the linking issues, I am currently discussing this with the developers to see if we can update the links so that the linked content prior to the migration is accessible again via the original link.
ENTERPRISE is offline
post #97 of 99 (permalink) Old 02-26-2019, 03:23 PM
cms062407's Avatar
Rep: 0
I reckon there was no further development with the devs? So many good links that many of us would like to check out
cms062407 is offline
post #98 of 99 (permalink) Old 02-27-2019, 02:11 AM
In VB's Basement
ENTERPRISE's Avatar
This is something that will be getting looked into in the future, but not the near future unfortunately. This is out of my direct control.
Need help with your account or something forum related ? Please use our Contact Us form
post #99 of 99 (permalink) Old 02-27-2019, 03:26 AM
News Fiend
ryan92084's Avatar
For the time being I've updated the OP with link fixes @Okt00 did earlier. I'm not sure how much help it'll be with a lot of the links in those threads being dead but it is something.
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
