[updated] Water Cooling Essential Threads - Overclock.net - An Overclocking Community
post #1 of 99 (permalink) Old 08-19-2007, 10:39 AM - Thread Starter
STG3 VET
Juggalo23451's Avatar
Rep: 1174 (Unique: 756)
In an effort to limit the number of stickies in this section, we've gone ahead and made the Water Cooling Essential Threads. Here you'll find a link to all the important threads for this section. I encourage the water cooling community to have a look and reply with links to any threads we might have missed. We will be updating this thread as time goes by. Special thanks to Burn & ira-k for their contribution.
Link redo by Okt00
Water cooling guides
Water cooling guide for noobs
How to setup and install a water cooling setup/loop 3 Part video
how to bleed a water cooling loop new
how to fill a water cooling loop new
how to install tubing for water cooling new
Water cooling basics101l(vid)
Water cooling basics and setup (Rev.1)
Water cooling parts for High end and budget suggestions
Water Cooling FAQ to get n00b's started
[Guide] How to put together a basic loop
Watercooling Guide
planning for a computer build and w/c
Watercooling- In English
Assembling Your Watercooling Setup
CPU blocks/ flow rates
Summer water block round-up 2014
Sterns_water_block_comparison
Hall of Blocks: CPU *Updated Often*
Another round of waterblocks on i7 -HESmelaugh
More waterblocks on i7 tested-HESmelaugh
Some waterblocks tested on i7-HESmelaugh
[Review] 22 CPU Waterblocks tested - Roundup
flow rates
BlockHeads: the thread
Block Flow Rates - Martin
Stinger V8 Flow Rate Test Results - Martin
Cpu Water block installs
Raystorm install
GPU Water block installs
XSPC_GTX670
Koolance GTX590XSPC 7970
Pump install on reservoirs
XSPC Dual 5.25" Bay Reservoir for the 3xx series
Chipset
EVGA X58 Classified waterblocks roundup - HESmelaugh
Fittings
One 1/2" Elbow = 4' of 1/2" ID Tubing (Test Results)
Mother of all Elbows..? - Martin
The Elbow Showdown, Copper is King - Martin
Pump/mod/noise testing/tops
Choosing the Correct Water Cooling Pump
My Ported D5 Test Results - Martin
MCP655 (D5) Port and Polish Mod - Martin
martins pump noise more testing thread
Laing DDC 3.2 (MCP 355) Pump Top Test Comparison
Roundup: Bay Reservoirs & Laing Tops
Radiators
360 radiator shoot out
bundymania user review triple radiator 360 roundup (new)
another 360 round up
Huge Radiators: Roundup - HESmelaugh
TFC Monsta Testing Complete - Martin
Flow rate
Bonnie Heater Core Flow Rate Test Results - Martin
Fans
Fan & Sound Tools Mini Test - Methods & <1000RPM fans
Fan testing Part 1 - Martin
Fan Testing Part 2 (Radiator Tests & Videos) -MartinFan Testing Round 4, GT vs Noctua vs Silverstone vs Yate vs Rosewill
Fan Testing Round 5 (Working Thread)Are "NANO" Bearings the new sliced bread?
Fan Testing Round 6 (50 Fans Tested and Counting!)
Maintenance
High Temps? A guide to improvement - 5 tests - Martin
Cleaning your loop after bacterial/ algae 'infection' (With pictures)
How to clean your CPU waterblock from Oxidation
How to clean a radiator
Water cooling stores
Stores to Buy Watercooling Gear
Picture gallery
OCN Water Cooling Club And Picture Gallery
Case suggestions
Water Cooled Case suggestions
DIY
Made a youtube video on zipties as a remedy for kinks
DIY Pump Dampening
How To: Make any Sized shroud in 2 minutes
How To: Build A Performance Shroud
How To Make A Dual Heater Core Fan Shroud...
How to Silence a Via Aqua
Barbs for heatercore?
Acrylic Polishing
pipe bending 101
Calculations
Radiator Thermals and Radiator Calculators by Martin
Flow Rate Estimator Spreadsheet V1.6
Part 1-Temps With and With-Out Shrouds
Others/testing
Pump head vs Flow rate
FAQ: Planning and Installing Your Liquid Cooling System
A reason to only used distlled water
Another Distilled VS Tap water Example
Yes, Another Car Radiator Thread--56K Warning! - (Hardcore water clocker rig..)
Heat Dump Discussion
Info: Using teflon tape
Original Thread Organized By Juggalo23451 10/11/2014
Spoiler!
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><p><a href="https://www.overclock.net/water-cooling/913181-water-cooling-guide-noobs.html#post11984918">Water cooling guide for noobs,parts,setup install case suggestions,etc</a></p><span></span><p><a href="https://www.overclock.net/water-cooling/962044-upgrade-time-update-2-3-18-a.html">Case labs TH10/ build log (2 gtx 590s) water cooling oh my</a></p><span></span><p><a href="https://www.overclock.net/water-cooling/528648-heatkiller-club.html">Founder of the Heatkiller Club</a></p><span></span><p><span>W</span><a href="https://www.overclock.net/water-cooling/601449-water-cooling-cases.html">ater cooling case suggestions</a></p></div></div>
Juggalo23451 is offline
post #2 of 99 (permalink) Old 08-19-2007, 10:43 AM
CyberDruid's Avatar
Rep: 2585 (Unique: 1242)
Great Googly Moogly that's a lotta stickiness
August 13th, 2011 sad-smiley-002.gif Happy trails, may we meet again.
CyberDruidPC is History
CyberDruid is offline
post #3 of 99 (permalink) Old 08-19-2007, 11:01 AM
Retired Staff
Rep: 1192 (Unique: 550)
Got it book-marked....Thats just about a one stop shop there....Thanks for taking the time to put them all in one stickie...
***Beware all ye Men born of Woman, beware the Hemogoblins...biggrin.gif...If you argue with a Troll the Troll wins. Do not feed the Trolls.***
***TOS***OCN's Professionalism Initiative*** An Emphasis on Quality of Content***Frozen Path. Sub-Zero Cooling Club***
***E8500 @ 5736 Mhz** E8600 @ 5751Mhz***E8400 @ Dead piece of junkQuote:
Originally Posted by Patch
Makes sense. Trolls have nickel plated red blood cells. Helps their copper based hemogoblin deal with the high aluminium content in their spleens.
ira-k is offline
post #4 of 99 (permalink) Old 08-19-2007, 12:45 PM
Martinm210's Avatar
Rep: 1163 (Unique: 706)
Nice, I made it into a sticky too..
Just noticed the heatercore barb thread, just what I was looking for.
Martinm210 is offline
post #5 of 99 (permalink) Old 08-23-2007, 10:08 AM
venar303's Avatar
Rep: 3 (Unique: 3)
wasn't there one about the "chemistry of flluids" or something that talked about what to add to the liquid to make it "wetter?"
I think that'd be a good addition.
*edit
http://www.overclockers.com/tips1153/
venar303 is offline
post #6 of 99 (permalink) Old 11-02-2007, 05:32 PM
I'm trying to get a WC gear and performance database going, that I think will help many in comparing performance, but also those interested in getting into WC and want first-hand accounts of results. If it could be reviewed for possible inclusion in this thread, it'd be much appreciated.
Thanks Trans!
Heru is offline
post #7 of 99 (permalink) Old 12-18-2007, 04:54 PM
Traeumt's Avatar
Rep: 36 (Unique: 31)
Thnx alot for these sticky it ll help me alot when my tt bigwater comes back from guarantee
done
Traeumt is offline
post #8 of 99 (permalink) Old 07-26-2008, 06:48 AM
Rep: 1 (Unique: 1)
I'm very new to all this. I have worked around computers for ages, but never used a water cooling system.
This is fantastic I shall be using it for when i come to water cool my new uber PC
Cheers
cheers.gif British Overclockers Club
captainjack15 is offline
post #9 of 99 (permalink) Old 08-20-2008, 01:34 AM
very nice even tho its ancient!
Monst3r is offline
post #10 of 99 (permalink) Old 07-19-2009, 08:26 PM
rpavur's Avatar
Rep: 2 (Unique: 1)
rpavur is offline
