**Project Terminated**: M17 Water Cooled Laptop - Overclock.net - An Overclocking Community
post #1 of 81 (permalink) Old 03-27-2009, 12:14 PM - Thread Starter
yutzybrian's Avatar
Rep: 94 (Unique: 82)
Ok so I finally have been able to work a little bit more on this project and decided it was time for a Build Log. Sorry for not posting updates sooner but I went to state competition one weekend and Kentucky the next weekend.
***56k Warning*** May take a while to load. I had dial up until a few months ago so I know how it goes.
The goal here is to watercool my M17 laptop while keeping the case as stock as possible. I am also trying to build a portable box to house the res, rad, and pump. Hopefully I can figure out how to wire an old laptop battery into the box to run the pump and fans. Here is the current CPU cooler. Underneath the pipes on the left side is the Northbridge chip. Might try and cool that also.
Parts:
Swiftech MCP355 Pump
XSPC Top for MCP355
X-Flow Black Ice Xtreme II Radiator
Yate Loon 120mmx20mm Medium Speed Fan x4
Bitspower 5.25" Bay Reservoir
Koolance 3/8" Quick Disconnect L-Bracket
Koolance F Splitter (3/8" to 2 1/4")
3/8" Clear Tubing (for inside the cooling box)
3/8" UV Orange Tubing (for in between the cooling box and laptop)
1/4" Clear Tubing
Bitspower Black Sparkle G1/4" Barb Fitting for 3/8" ID
As you can see I'm running out of desk space.
The case proved to be a bit tricky. I didn't want to have to fabricate a full metal box (it would be very heavy) but I also didn't have anything laying around the house that would work. Finally found a tackle box on clearance at Kmart that should work.
I then mounted the reservoir to the lid
Just got the fans yesterday. I didn't have any screws that could mount it to the radiator so I had to run to Meijer real quick and get some (9pm at night after work, Menards and Lowes were closed). I have them configured in a push-pull setup. I read on other threads that other people who set up their rads like this were very satisfied with the results so I figured what the hell I'll do it.
Cut the holes for the airflow
The Koolance GPU waterblock. Looks nice.
Definitely won't need lapped. It's mirrored finish already.
Leak tested everything using two laundry baskets
Tested it for about 40min and everything worked perfectly. I then went to install it and found out that the water block didn't include any screws that fit the holes on the laptop. I popped the lock ring off of two of the screws on the air cooling water block and then made a bracket using an Antec 900 slot cover I had laying around. Turned out to be a decent bracket. I also stuck one of the ramsinks included with the water block on the chip by the CPU (I think its the NB).
I don't have a battery to wire in yet so my setup will be using a 100W power supply I borrowed from my teacher to run the pump and fans. It's not exactly a mobile solution yet (Unless I lug my UPS around with me ).
Also I cut the holes to mount the QDC bracket in. I had to cut the bracket down so it would sit flush with the side.
Temps are down a lot! Used to run in mid-40s.
Now to update the BIOS so I can overclock
I had to clear out some of the casing to make room for more tubing. It didn't weaken the laptop's frame one bit.
2nd block came so I installed it on the GPU. Threw a ramsink on each of the 4 ram chips.
Tubing redone and managed to fit the splitters inside the case.
Battery (4600mAh NIMH) works. Wired it into a switch, inline fuse, and a male 4-pin molex connector.
Mounted battery in the lid
Made two grills out of chicken wire and screen. Not the most professional but they'll do.
Mounted the switch for the battery into the lid.
This made it quite interesting to use my laptop for a few days while spray painting the tackle box. I started on a Saturday but couldn't work on it again til the following Wednesday due to rain Sunday-Tuesday (Yes I did the painting outside, didn't have any other place to do it).
Dryed, reassembled, and set up. I left the switch out so I could run the power wire in through the hole. Should be getting a charger for the battery next week though so I can disconnect the ugly gray psu sitting on top.
*****Final Update 5/25/09*****
I am very sorry to say that every effort to run the MCP355 pump off of a battery failed. I could not get it to start whatsoever. Without everything running off of a battery it takes away the portability of a laptop and therefore becomes useless. I am back on air cooling now at stock clocks. I will be selling all the parts and possibly even the laptop on ebay (If I sell the laptop I'm building a desktop and getting a netbook for internet and college). One day when I have more money and also plan it out better I will do this again, sucessfully. Thank you everyone for your comments, you'll never know how much they were appreciated.
yutzybrian is offline
post #2 of 81 (permalink) Old 03-27-2009, 12:35 PM
unl3a5h3d's Avatar
Rep: 45 (Unique: 42)
Wow, this should be interesting... Can't wait to see more..
Main: Macbook Pro -- RSA Protector -- Double Helix "Molecule" cable -- AKG K702
Portable: Ipod Classic 160Gb w/ LOD -- RSA Protector -- Twag Whiplash Audio Balanced cable -- Custom Triple.Fi 10 Pro (Fisher Customs)
unl3a5h3d is offline
post #3 of 81 (permalink) Old 03-27-2009, 03:01 PM
arekieh's Avatar
Rep: 226 (Unique: 176)
subd
Hey, at least call of duty's going green! unlike battlefield 3
Modern warfare 3=made out of 100% recycled materials
Quotes (Click to show)Warning: Spoiler! (Click to show)
I laughed when I read he heard a loud pop, that must have been his idiocy booting up.
indeed, this is just amazing. gotta hand it to the lady. she's got some real balls.
My Trading Rep: HWC OCN Heat Ebay
arekieh is offline
post #4 of 81 (permalink) Old 03-29-2009, 01:08 PM - Thread Starter
yutzybrian's Avatar
post #5 of 81 (permalink) Old 03-29-2009, 01:12 PM
ML Infamous's Avatar
Rep: 24 (Unique: 24)
Good Luck with this,
Xbox Live Gamertag: ML Infamous
Aumotocnic "An unfortunate member of the overclock.net insomnia club"
ML Infamous is offline
post #6 of 81 (permalink) Old 03-29-2009, 01:15 PM
do not go to the airport with this lappy when you are done lol, you might get arrested
G|F.E.A.D|Killa is offline
post #7 of 81 (permalink) Old 03-29-2009, 01:17 PM
FS19 Addict
Rick Arter's Avatar
Rep: 350 (Unique: 310)
Very cool idea this should be great project rep+
Rick Arter is offline
post #8 of 81 (permalink) Old 03-29-2009, 01:23 PM - Thread Starter
yutzybrian's Avatar
Nope just gonna go to Arbys. I've never flown in my life.
post #9 of 81 (permalink) Old 03-29-2009, 01:40 PM
mfb412's Avatar
Rep: 77 (Unique: 69)
wow, sub'd
RIP Dad
mfb412 is offline
post #10 of 81 (permalink) Old 03-29-2009, 01:48 PM
Rep: 46 (Unique: 41)
nice GL cant wait to see how this turns out
f16-r1 is offline
