[Official] Heatkiller Club - Page 367 - Overclock.net - An Overclocking Community
post #3661 of 4538 (permalink) Old 05-13-2019, 06:17 AM
GAN77's Avatar
Rep: 2 (Unique: 2)
Quote: Originally Posted by Watercool-Jakob View Post
If the pwmcable is not connected, the pumps run with roughly 60%. When connected, they can be controlled from 20-100%.
Thank you again for your help!
GAN77 is offline
post #3662 of 4538 (permalink) Old 05-13-2019, 12:03 PM
pmc25's Avatar
Rep: 7 (Unique: 7)
If I put your nickname to the correct order, it seems as if it shipped today.
Thank you, it did indeed ship today. Indicating a Thursday delivery.
Unrelated question:
Are you guys planning to revisit your AM4 blocks? With it now being an open secret that Ryzen 3 chips will include both 12 and 16 core CPUs, when overclocked, even at 7nm, these are likely to output a lot more heat than the Ryzen 1 & 2 8 cores. If that wasn't the case, then the X570 boards wouldn't be getting beefier VRMs and heatsinks. Maybe more fins or a different design for the block would help?
Also, another nag re: the Radeon VII block. Any progress?
pmc25 is offline
post #3663 of 4538 (permalink) Old 05-14-2019, 02:14 AM
Hardware Rep
Watercool-Jakob's Avatar
Rep: 84 (Unique: 44)
Unrelated question:
Zen2 blocks:we are aware of the new design and are currently trying to get a test sample to determine how our current block performs on that layout. Dependingon that data, we will make the call if a dedicated block is necessary.
Radeon VII block: no update, sorry.
Chat with me in the Official Watercool HEATKILLER Club on OCN
Find all our gear at
http://WATERCOOL.de
Find out if there is a customized HEATKILLER water block for your...
GPU | Motherboard
And don't forget to follow us on...
Twitter | facebook | instagram
Watercool-Jakob is offline
post #3664 of 4538 (permalink) Old 05-15-2019, 03:34 PM
Rep: 6 (Unique: 6)
@Watercool-Jakob , does this on this fit in this (150mm clearance) horizontally?
lb_felipe is offline
post #3665 of 4538 (permalink) Old 05-16-2019, 04:28 AM
News Fiend
ryan92084's Avatar
I could be wrong but I believe the original O11 from your link has a larger than 150mm clearance. Did you mean the dynamic/air?
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #3666 of 4538 (permalink) Old 05-16-2019, 07:38 AM
Rep: 6 (Unique: 6)
In Lian Li's website, it is told whatever PC-O11 has just 150mm (in some parts, it is 159mm what is confusing). E.g. according some Newegg customers's reviews, Aorus RTX 2080 Ti WB doesn't fit horizontally. It is 159mm width.
Though this is a PC-O11D, if whatever PC-O11 has the same clearance, it shows up that that graphics card doesn't fit:
The question is if the Strix RTX 2080 Ti outfitted with a Heatkiller IV fits inside a PC-O11 (any one) horizontally.
post #3667 of 4538 (permalink) Old 05-16-2019, 07:40 AM
Hardware Rep
The only information that I can give you is that our block is 137mm wide on the widest part, including the terminal. I don't know if the "150mm" clearance is measured from the MB tray, the MB itself, or the top of a PCIe Slot. So I can't make a final statement on wether it will fit in this specific case. Please contact Lian Li directly for more information on their definition of "clearance".
But my personal guesstimation is that it should just work out.
http://WATERCOOL.de
GPU | Motherboard
post #3668 of 4538 (permalink) Old 05-16-2019, 09:08 AM
Rep: 6 (Unique: 6)
Okay. Fair enough but what is the width of the combo (Strix RTX 2080 Ti + Heatkiller IV)?
Edit:
Or even better, what is the width increase (if there is some one) when Heatkiller IV is attached to Strix RTX 2080 Ti?
post #3669 of 4538 (permalink) Old 05-16-2019, 09:19 AM
News Fiend
ryan92084's Avatar
Though this is a PC-O11D, if whatever PC-O11 has the same clearance, it shows up that that graphics card doesn't fit: https://youtu.be/NTvsW0x3pi0?t=660
The D is the dynamic so again it depends on which version of the o11 you are asking about, there are several. The air/dynamic/razer are the ones with potential clearance issues. They maintain a list gpu waterblock list for those models here but unfortunately don't test heatkiller blocks but they have been pretty decent about answering questions if you contact them.
The older o11 models (like your link) are a little bigger and don't have the staggered motherboard tray. I thought their clearance was better but after poking around it might just be a little different.
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
post #3670 of 4538 (permalink) Old 05-16-2019, 10:11 AM
Rep: 6 (Unique: 6)
Both PC-O11 and PC-O11D have same specs as regards graphics cards clearance. See image below. The same is with CPU cooler clearance: 150mm.
Update: If PC-O11's specs page says it is 150mm clearance for graphics card and if an 159mm card (Aorus RTX 2080 Ti WB) didn't fit inside PC-O11D (whose specs page says it is 159mm for VGA and 155mmm for CPU cooler), then PC-O11 is narrower than PC-O11D, right?
Anyway, what is important is how much Strix RTX 2080 Ti's size is increased by using a Heatkiller IV.
