OCN Water Cooling Club And Picture Gallery - Page 4806 - Overclock.net - An Overclocking Community
post #48051 of 109596 (permalink) Old 08-18-2013, 02:37 PM
golfergolfer's Avatar
Rep: 53 (Unique: 32)
Originally Posted by freitz View Post
Looks Great. Did you make that case?
No I didnt, it was made by Dwood the artisan here. There is a wait list in Sheloved E's artisan thread if you are interested in one
"One mile of highway gets you one mile, one mile of runway gets you anywhere..."
(")_(")
w a t e r c o o l e d - c o r e - 1 0 0 0
c o m p a c t - s p l a s h - 0 0 8
golfergolfer is offline
post #48052 of 109596 (permalink) Old 08-18-2013, 05:17 PM
Retired Staff
kcuestag's Avatar
Rep: 334 (Unique: 210)
For those with EK waterblocks (If you have a RIVE, better) or those with knowledge about it, I'm going to get these blocks for my Rampage IV Extreme off a friend (Pic from his rig):
And I was wondering if they'll match the height of my EK Supreme HF Plexi (CPU Waterblock) so that I could use 90º adapter/fittings and do straight lines between them. Do you guys think that will be possible? Or these blocks combined with my CPU block will be uneven? Not sure if I explained my self properly. tongue.gif
The "NoMoreUpgradesUntilXmasPC" Build Log
GPU's: HD5850 > HD5970 > 2x HD6970 > 2x GTX580 > 3x GTX580 >
> 2x GTX680 > 2x HD7970 > R9 290X > 2x R9 290 > GTX970 > 2x R9 290X >
> GTX980Ti > 2x GTX980Ti > 2x GTX1080 > 2x GTX 1080 Ti
kcuestag is offline
post #48053 of 109596 (permalink) Old 08-18-2013, 05:48 PM
Computer Art
Jameswalt1's Avatar
Rep: 304 (Unique: 206)
Warning: Spoiler! (Click to show)
You will need extenders, they do not sit even.
post-flame-small.gifTEARS IN RAIN A Blade Runner inspired build (2017)post-flame-small.gif
post-flame-small.gifPARVUM WARFARE An Advanced Warfare themed build (2014)post-flame-small.gif
post-flame-small.gifPARVUM TITANFALL A Titanfall themed build (2014)post-flame-small.gif
post-flame-small.gifROBOCOP A Robocop themed 900D build (2013/14)post-flame-small.gif
Jameswalt1 is offline
post #48054 of 109596 (permalink) Old 08-18-2013, 05:53 PM
Retired Staff
kcuestag's Avatar
Since I'm using tubing (Not acrylic) and only CPU/Mobo blocks (No RAM) you reckon it'll be fine without the extenders?
kcuestag is offline
post #48055 of 109596 (permalink) Old 08-18-2013, 05:59 PM
Computer Art
Jameswalt1's Avatar
EDIT: Actually, looking at it, it may be a little tight without an extender, using a compression fitting. I would just invest in a few short extenders just in case.
post #48056 of 109596 (permalink) Old 08-18-2013, 06:01 PM
Retired Staff
kcuestag's Avatar
Damn, I wish I had someone with my very same configuration to try it out. tongue.gif
kcuestag is offline
post #48057 of 109596 (permalink) Old 08-18-2013, 06:15 PM
MykaAurora's Avatar
Rep: 3 (Unique: 3)
Get extenders. Or you'll end up like mine. Warning: Spoiler! (Click to show)
Freakin' tight. Worst of you're using Primo ADV LRT, it's really stiff.
MykaAurora is offline
post #48058 of 109596 (permalink) Old 08-18-2013, 06:27 PM
Retired Staff
kcuestag's Avatar
By extenders do you guys mean this? http://www.ekwb.com/shop/accessories/fittings/adapter-fittings/ek-extender-g1-4-nickel.html
kcuestag is offline
post #48059 of 109596 (permalink) Old 08-18-2013, 06:34 PM
defiler2k's Avatar
Rep: 45 (Unique: 39)
Originally Posted by steelkevin View Post
I need to get a temp sensor but right now I want to know my delta.
Can I open my reservoir while the PC's on and dip the sensor that's currently giving me ambient temps into it or will the reservoir overflow ?
Do you calculate Delta on idle or running prime or IBT ?
And about the temp sensors, I want a basic 1/4" plug that I can just have at the bottom of the reservoir but they all seems quite expensive (16-20€) is there an ebay shop with cheap ones people here use ?
I use the XSPC G 1/4 sensors I have two of them to measure the fluid that is leaving the hottest point of the loop (GPUS) and the fluid that is returning to my reservoir. I also use this to check how much of a difference I see in temps when running the fans in the case at certain speeds.
You would measure Deltas in fluid by subtracting the ambient vs the coolant temps at the points you are checking.
defiler2k is offline
post #48060 of 109596 (permalink) Old 08-18-2013, 06:38 PM
Computer Art
Jameswalt1's Avatar
You could use those, but Bitspower has an array of different sizes in different finishes that will help to better get a precision fitment.
Here's an example search of what I mean:
http://www.frozencpu.com/search.html?mv_profile=keyword_search&mv_session_id=fheupkP2&searchspec=Bitspower+G+1%2F4%22+Thread+Fitting+Extender
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
