OCN Water Cooling Club And Picture Gallery - Page 4809 - Overclock.net - An Overclocking Community
post #48081 of 109596 (permalink) Old 08-19-2013, 04:14 AM
Retired Staff
derickwm's Avatar
Rep: 379 (Unique: 291)
derickwm is offline
post #48082 of 109596 (permalink) Old 08-19-2013, 04:22 AM - Thread Starter
Hardware Rep
B NEGATIVE's Avatar
Rep: 789 (Unique: 492)
B NEGATIVE is offline
post #48083 of 109596 (permalink) Old 08-19-2013, 05:54 AM
Retired Staff
derickwm's Avatar
Ah it's already on order, just whenever the post gets it here.
Not allowed to post photos but I think this bit of news is relevant to enough people here:
http://www.ekwb.com/news/385/19/Two-new-custom-PCB-GeForce-GTX-780-water-blocks-in-the-works/
derickwm is offline
post #48084 of 109596 (permalink) Old 08-19-2013, 06:03 AM
briddell's Avatar
Rep: 42 (Unique: 42)
I want a block for the 780 HOF, though. Pastel White on a nickel plated block with a white PCB. I would punch babies to get it.
If you can't run, you walk. If you can't walk, you crawl. If you can't crawl, you find someone to carry you.
~Malcolm Reyonlds~
Ignorance is the prison that the people are kept it.
briddell is offline
post #48085 of 109596 (permalink) Old 08-19-2013, 06:15 AM
Retired Staff
derickwm's Avatar
derickwm is offline
post #48086 of 109596 (permalink) Old 08-19-2013, 07:01 AM
freitz's Avatar
Rep: 48 (Unique: 35)
Wow, I want to do a ITX rig just so I can use that board.
EVODOT SM8 Build Log // Synology Owners Club // *Official* CaseLabs Owners Club! // CaseLabs MERLIN Owners Club //Corsair Graphite Club // OCN Water Cooling Club // EK Club
PC: I7 7700k // EVGA GTX TITAN X (pascal) // 32GB Dominators 2400 // ASUS 270G // CaseLabs BH4
Mac: Macbook 2015 Space Gray// Core M 1.3ghz // 512GB SSD // 8GB
CAMERA: Leica M240 // 35mm Summilux F1.4 FLE // 50 APO // Sony A7II
SYNOLOGY: DS1516+ // 2x 4TB WD RED NAS
freitz is offline
post #48087 of 109596 (permalink) Old 08-19-2013, 07:06 AM
defiler2k's Avatar
Rep: 45 (Unique: 39)
Warning: Spoiler! (Click to show)
Originally Posted by steelkevin View Post
Thanks for answering to part of my post smile.gif.
I wouldn't invest in two 1/4 sensors even if they weren't so expensive. I was expecting you lot knew about some cheap sensors like with LEDs but I guess I'll have to cash out 20€ then :/.
I know how to calculate Delta temps, I was wondering if it was done @idle or full load but I think somebody answered that and said you had to do it once the liquid's temp was stable (so not right after booting up).
As for opening the reservoir while the pump's running I guess I'll have to find out on my own since it looks like not a single one of you knows...
EDIT:
So yes, you can remove a reservoir's cap while the pump is running without it overflowing which means that I've lost a lot of time when filling my loop. I used to fill the res, close it, run the pump and repeat until the loop was full... this means I could've just turned the pump on and poored the liquid into the reservoir until the loop was full tongue.gif.
My Delta T° is between 4.7°C and 5.2°C so that just taught me there's nothing wrong with my loop and it's running great (Martin's liquid lab says 5°C is extreme performance, 10°C decent and 15°C bad or something like that).
For the testing I used a single sensor which is why the reading can't be 100% accurate since I wasn't reading both temps at the same time and ambient may have changed. I booted the computer and used it for a good 30-45minutes and then ran IBT Maximum Ram / Xtreme Stress mode for five runs and wrote down the highest water T°.
Does anybody here have any experience with the Fractal Design Arc Midi R2's dust filters ? For the testing the top and side pannels were removed and so was the front dust filter / mesh thing and my CPU never went above 60°C (HWMonitor, RealTemp and HWiNFO64), last night with a 28°C ambient instead of ~22.5°C my max CPU temp under max / Xtreme IBT was 72°C with everything on the case.
EDIT:
forget about the Arc Midi R2's dust filters, they were much filthier than they looked. I closed my bathroom's sink and ran water through the front dust filter + mesh and the water was full of dust. I couldn't do that with the top dust filter because it's way too big so I just used the bath tub but I guess it would've been even worse.
Sorry I totally forgot that part of your question, glad you found out. I actually leave the fill port open after the pump has been primed enough to not run dry at any point while I'm filling the loop. You don't want to have the pump run dry at any point. I cap it once Im ready to walk away to leak test.
If you add GPU's to your loop you should look at your coolant temps under heavy load, acrylic components start to deform if the fluid goes beyond 50C.
defiler2k is offline
post #48088 of 109596 (permalink) Old 08-19-2013, 07:50 AM
Linux Lobbyist
WebsterXC's Avatar
Rep: 78 (Unique: 71)
Originally Posted by gdubc View Post
That looks pretty similar to the mips blocks for the Asus MVE if you ask me! I do like it though. I really ike the OC Force board also...nothin like a little overkill!!
EK has had that design way before MIPS. Both have their own unique aspects though.
By the way, it may not be super cost efficient, but making blocks on request would be incredible. I know so many people dying yo water cool their AMD boards but have no options. Even though Intel holds more of the enthusiast PC market, allowing the option of someone send their board to you and fabricating a waterblock would be awesome.
I don't own a CNC/Mill though, so that may be extremely difficult and impractical.
WebsterXC is offline
post #48089 of 109596 (permalink) Old 08-19-2013, 07:51 AM
Retired Staff
kcuestag's Avatar
Rep: 334 (Unique: 210)
Not sure this has been posted or not, but I present you the most beautiful water cooling rig I've ever seen:
That thing is ART, I love the way he is routing the coolant!
The "NoMoreUpgradesUntilXmasPC" Build Log
GPU's: HD5850 > HD5970 > 2x HD6970 > 2x GTX580 > 3x GTX580 >
> 2x GTX680 > 2x HD7970 > R9 290X > 2x R9 290 > GTX970 > 2x R9 290X >
> GTX980Ti > 2x GTX980Ti > 2x GTX1080 > 2x GTX 1080 Ti
kcuestag is offline
post #48090 of 109596 (permalink) Old 08-19-2013, 07:55 AM
Linux Lobbyist
WebsterXC's Avatar
I think this was posted in one of Jeffinslaw's build logs, but it needed to be posted here. I agree; the ingenuity and acrylic work is just incredible.
