[Official] Corsair Hydro Series Club - Page 1989 - Overclock.net - An Overclocking Community
post #19881 of 28489 (permalink) Old 12-18-2011, 03:15 PM
Mergatroid's Avatar
Rep: 179 (Unique: 144)
The screw size you're looking for is: 6 x 32 x 1 1/4" #6 machine thread, 32 threads per inch, 1.25" long.
Nukeyork
(19 items)
i7 10700K
ASUS Prime Z490-A
Gigabyte RTX 2070 Super OC
Corsair RGB Pro 3200MHz
ADATA
Optical Drive
ASUS BW-12B1ST Blu-ray RW
Corsair AX750
Thermaltake Water 3.0 Ultimate
Corsair 760T
Operating System
Windows 10 64 pro
HKC c340 34" Ultrawide 3440 x 1440
Keyboard
Redragon RGB 10-Keyless
Mouse
Logitech Lightspeed G903
Audio
On Board
Other
Thermaltake X 5G Superspeed USB 3.0 Hard Drive Dock
Other
Logitech Driving Force GT Steering Wheel
Other
Thrustmaster T.Flight Hotas X Joystick
Other
Razer Orbweaver Chroma RGB Mechanical Gaming Controller
Other
Ergotron LX Desk Mount LCD Arm
Mergatroid is offline
post #19882 of 28489 (permalink) Old 12-18-2011, 05:49 PM
flowtek's Avatar
Rep: 63 (Unique: 57)
i got what you described about the screw, fits perfectly on the rad thumb.gif,.. thx merg
4.1Ghz with DeepCool IceEdge << this one long gone
383
4.1Ghz with H60 Pull
400
4.1Ghz H60 PushPull
382
SmallFFT, i think 25 minutes is enough for now just to make sure.. never touch 65c thumb.gif
526
well.. for $70 i think its now doing its job very well, im surprised, i was thinking about buying the $220 EK set but then such a waste on an old dual core .. but im pretty sure that i can still use this H60 to cool my next 2600K, probably next year thumb.gif
thx so much
flo
EDIT: both fans running between 1800-1900, it fluctuated.. i thought the SickeFlow will stick to 2000rpm, but anyway... happy now smile.gif
30c Ambient
flowtek is offline
post #19883 of 28489 (permalink) Old 12-19-2011, 04:28 PM
Mergatroid's Avatar
That's great. Nice to see such a good result. Glad that fan worked out.
Nukeyork
(19 items)
i7 10700K
ASUS Prime Z490-A
ADATA
Optical Drive
Corsair AX750
Corsair 760T
Operating System
Windows 10 64 pro
Keyboard
Mouse
Audio
On Board
Other
Other
Other
Other
Other
post #19884 of 28489 (permalink) Old 12-23-2011, 07:06 AM
Rep: 473 (Unique: 380)
So I'm moving my H50 from an LGA1366 to an LGA775 system, and I'm having the time of my life (not) taking the pieces of plastic that go in each corner of the ring-shaped thing that's part of how the cooler is attached. Talking about the pieces of plastic through which the screws go, just to be clear. How the hell does one take those out of the metal ring? There's a little plastic thing you can push to take one side out, but then on the other side there's another, immovable plastic notch that is preventing me from doing anything. I don't want to apply too much force since I don't want to bend the metal ring. Is there a trick to it I'm not getting?
Edit: never mind, it was just the one that was being a pain. I broke it in the process of removing it. The others came out easily by using a flathead screwdriver as a lever. Probably won't be using it in another system, so it's no problem that the one's broken.
Shub is offline
post #19885 of 28489 (permalink) Old 12-26-2011, 10:59 PM
Rep: 107 (Unique: 96)
i just picked up a h60 should be in this week. hows the h60 compair to the rest of the h series.
HERE I IS biggrin.gif my top cpu's
E5200 3.6GHZ********** E8600 4.4GHZ ***********Q9650 4.3GHZ
E7200 3.8GHZ********** E8400 4.2GHZ ***********Q9550 4.25GHZ
headphone setup- schitt bifrost dac - Hifiman EF5 tube amp - Hifiman HE-4 orthodynamic headphones
valtopps is offline
post #19886 of 28489 (permalink) Old 12-28-2011, 06:33 PM
Mergatroid's Avatar
Right in the middle of the pack. It's a good cooler.
Nukeyork
(19 items)
i7 10700K
ASUS Prime Z490-A
ADATA
Optical Drive
Corsair AX750
Corsair 760T
Operating System
Windows 10 64 pro
Keyboard
Mouse
Audio
On Board
Other
Other
Other
Other
Other
post #19887 of 28489 (permalink) Old 12-29-2011, 08:28 PM
Rep: 5 (Unique: 5)
quick question! Do ap-15 work with the h100 fan controller? The rep at the store said only the stock 3pin corsair fans adjusts speed or 4 pin pwm fans. He said regular 3 pin fans will just run full speed.
Corrupt is offline
post #19888 of 28489 (permalink) Old 12-29-2011, 08:45 PM
*cough*Stock*cough*
Rep: 230 (Unique: 200)
Carter, can you explain that in *English*?
Leviathan
(17 items)
Cheapshot Reborn
(8 items)
Charred
(10 items)
Xeon E5-2690
Biostar TPower X79
PNY GTX 660 2GB
Dell GTX 645
Gskill Ripjaws 4x2GB 1600mhz
Seagate Barracuda 500GB
Seagate Barracuda 1.5TB
Western Digital Caviar Blue 640GB
Patriot Pyro 60GB
Seasonic G550
Xigmatek Gaia
Xclio Nighthawk
Operating System
Windows 7 Ultimate
Acer S230HL
Lenovo Thinkvision L171
Keyboard
Logitech K120
Mouse
Logitech MX310
Xeon X5650
Gigabyte X58A-UD3R
Asus GTX 460 1GB
Gskill PI 3x2GB DDR3-1600
500GB Western Digital
EVGA 500B 500W Bronze
Corsair H50
Operating System
Windows 7 Ultimate
AMD Phenom II x4 940
M3A78-EM
G.skill 2x2GB DDR2-800
OCZ 2x2GB DDR2-800
Samsung Spinpoint 40GB
Western Digital 1TB
Antec Neo ECO 400W
Xigmatek Gaia
Rosewill R102-P-BK Black
Operating System
Windows 7 Ultimate 64-bit
Cyrious is offline
post #19889 of 28489 (permalink) Old 01-02-2012, 04:27 PM
Mergatroid's Avatar
The rep at your local store is full of crap. The stock H100 fans are normal 3-pin fans. You can use ANY fans on the H100. As a matter of fact, even if you plug in a 4-pin PWM fan, it still gets controlled the same way as a 3-pin fan (voltage regulation) as the H100 block does not contain a PWM controller.
Tell your rep he should stop making things up, or link you to the information he claims is true.
Nukeyork
(19 items)
i7 10700K
ASUS Prime Z490-A
ADATA
Optical Drive
Corsair AX750
Corsair 760T
Operating System
Windows 10 64 pro
Keyboard
Mouse
Audio
On Board
Other
Other
Other
Other
Other
post #19890 of 28489 (permalink) Old 01-03-2012, 09:22 PM
I'm here lol
trivium nate's Avatar
Rep: 11 (Unique: 11)
whats teh latest corsair h cooler? ive got the h50
trivium nate is offline
