[Official] Corsair Hydro Series Club - Page 2 - Overclock.net - An Overclocking Community
post #11 of 28489 (permalink) Old 11-20-2009, 04:31 AM
Rep: 50 (Unique: 48)
add me in too..
jus odered mine..will arrive in 3-4 days yipeee..
No Fancy Signatures
dragonxwas is offline
post #12 of 28489 (permalink) Old 11-20-2009, 05:39 AM
mav2000's Avatar
Rep: 69 (Unique: 58)
Am not completely bowled over with the results, but maybe theres something wrong...just want to check with u guys....I have mounted it with the tubes on the top side of the case and the corsair logo right side up. I used Mx2, using a card to spread it over the CPU and I have two yateloons at high speed on the rad pushing air out of the case. I have two 60-70 cfm fans on the side window pushing air in...so I am really wondering what the issue here is.
Its also takes a good amount of time to cool down...is this normal...my pump runs at around 1300-1350 rpm and is on 100% all the time. The two yateloons are running at 2000 rpm all the time....i tried the rad out with 1450 GT's and the yateloons make little to no difference while being a lot louder...what do u guys suggest?
Man, my Baram was better than this.
mav2000 is offline
post #13 of 28489 (permalink) Old 11-20-2009, 05:48 AM
ryanrenolds08's Avatar
Rep: 195 (Unique: 170)
Add me add me! I will upload pictures as soon as possible.
ryanrenolds08 is offline
post #14 of 28489 (permalink) Old 11-20-2009, 06:14 AM
Killhouse's Avatar
Rep: 167 (Unique: 120)
You have the same processor as me, granted I'm still at stock but I get around 32C idle and never more than 48C load. Not sure about ambients, quite warm english weather
What sort of temps are you hitting? Sounds like you should be lower than me with that setup.
~ Killhouse's Worklogs ~
COMPLETE: Paroxysm :: Scratch ATX Acrylic Case Worklog
COMPLETE: Eyas :: Scratch mITX Acrylic HTPC Case Worklog
COMPLETE: Computer Desk :: Large Computer Desk
~ Clubs ~
Owner of The Official Corsair H50 Hydro Series Club
Killhouse is offline
post #15 of 28489 (permalink) Old 11-20-2009, 06:25 AM
mav2000's Avatar
Well yes I am around the same...the C2 revision does run hot...so around 31-32 idle and 48 load on Prime...the baram gave me 29-30 idle and 48 load as well....so not all that much better for stock..
Does it take a long time to cool down for u as well...
Ambients are around 23-24 degrees.
mav2000 is offline
post #16 of 28489 (permalink) Old 11-20-2009, 06:25 AM
Toan's Avatar
Rep: 28 (Unique: 24)
Put me on the list ill post a pic up when i get home from class
Toan is offline
post #17 of 28489 (permalink) Old 11-20-2009, 06:42 AM
Killhouse's Avatar
It cools down from max load to idle temps in about 3-4 mins I'd geuss. I'll post some OCCT graphs later, when I'm done working
~ Clubs ~
post #18 of 28489 (permalink) Old 11-20-2009, 07:13 AM
mav2000's Avatar
Done...i'll get OCCT and run it to...let me know what settings ure running.
mav2000 is offline
post #19 of 28489 (permalink) Old 11-20-2009, 07:37 AM
ntuason's Avatar
Rep: 175 (Unique: 155)
i7 980x + CF 6970
(11 items)
i9-9900K @ 5.2GHz 1.39v (Direct-Die)
ASUS ROG Maximus XI Apex
ASUS ROG RTX 2080 Ti O11G
Trident Z Royal @ 4200MHz CL18
970 EVO Plus NVMe M.2 500GB
860 QVO 1TB
BarraCuda 8TB
Cooler Master MasterWatt Maker 1200
Swiftech H360X3 + Nemesis 360 GTX + Barrowch 200mm Boxfish
Lian Li PC-011 Dynamic (White)
Operating System
Windows 10 19H2-1909 64bit
Samsung CHG70 32" QLED, 1ms 144Hz
Keyboard
Logitech G815 Tactile
Mouse
Logitech G Pro Wireless
Mousepad
Logitech G840
Audio
Kanto Yu4 + Kanto SUB8 8-Inch
Audio
Audeze LCD-4
i7 980X 3003B475* @ 4449.1MHz 1.45V (6C-12T)
ASUS Rampage III Extreme - 1208 BIOS
ASUS ROG Strix GeForce GTX 1660 Ti
6GB Corsair Dominator GT 2009MHz / 7-8-7-20 T1 C7*
RAID 0* OCZ Vertex 3 120GBX2 (OS)+ 4X 2TB WD Green
Seasonic PRIME 600 Titanium
Corsair Obsidian 800D
Operating System
Windows 7 Ultimate 64Bit
Keyboard
Filco Majestouch-2 Cherry MX Red
Mouse
Razor Mamba 4G
Mouse
Logitech G703
ntuason is offline
post #20 of 28489 (permalink) Old 11-20-2009, 09:16 AM
Killhouse's Avatar
Running a standard 1 hour test now: 1h 0 min, medium data set, priority normal. Hyperthreading disabled. I'll post back in an hour.
~ Clubs ~
